COMPLETED 5th Gen 4Runner BBK upgrade for 2nd Gen Tacomas
Discussion in 'Technical Chat' started by nudavinci64, Aug 4, 2017.
  1. May 10, 2020 at 12:36 PM
    #281
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    The front brakes always do the majority of braking work regardless of the setup. I wouldn’t have any concerns about the brakes being “unbalanced”
    TacoFMS likes this.
  2. May 10, 2020 at 12:41 PM
    #282
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Yes, I know taht they typically do a majority of the work in a front engine car but they are balanced with the rears for vehicle weight and balance, suspension design, etc. This will surely change the bias to some degree and I thought someone may have already looked into how much and what performance changes to expect.
  3. May 10, 2020 at 1:18 PM
    #283
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    I may have posted the differences earlier in the thread but either way the change is likely not large enough to cause major bias changes.
    Even in cases where Toyota/TRD sells a big brake kit it’s usually a larger change.
    Jeff
  4. Jun 9, 2020 at 2:38 PM
    #284
    Hatfield405
    Hatfield405 Member
    Oklahoma City
  5. Jun 22, 2020 at 3:58 PM
    #285
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    Any update on this?
  6. Jun 22, 2020 at 4:14 PM
    #286
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    MY50cal likes this.
  7. Jun 29, 2020 at 8:41 PM
    #287
    Sea to Sky
    Sea to Sky New Member
    Lions Bay
    09' DC TRD OffRoad
    Are people still experiencing the soft pedal issue if they order what MACH375 suggested ?
    or was this a speed bleeder / air issue in previous posts or Master cylinder ?
  8. Aug 3, 2020 at 4:39 PM
    #288
    nudavinci64
    nudavinci64 [OP] Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I have an OffRoad and cant swap my master. Some softness but overal it was solid. I recently found out my truck is 7k lbs and likely the cause of any degraded braking performance. Truck is HEAVY! I now have the Wilwoods which I think was a great upgrade. I have a set of DBA 4000 rotors going on next. Also seeing if there are any other pads I can use with the calipers. The 4runner kit with a good set of rotors and some solid truck use pads will be key. Also if you are looking for low speed or high speed. Many race pads may not give you the performance you want compared to low speed stopping. Also if your truck is heavy there is another factor most people do not factor in. GVWR of the Tacoma is 5500 and I am at 7k so thats playing alot into my performance engine and braking wise.
    mr.trd and zippsub9 like this.
  9. Aug 5, 2020 at 9:09 PM
    #289
    TacoTuesday1
    SD CA
    found eBay seller asking $30/caliper for these, claiming they're the bigger 5th gen 4runner
    What's going on here?
    1. seller claims it's new. How? Did they cast it at home from soda cans?
    2. why does it not say 14WA? I thought 5th gen T4R calipers say "14WA"?
    example: left ear says "14WA"
  10. Aug 5, 2020 at 9:35 PM
    #290
    nudavinci64
    Robert
    likely knock off calipers. The OEM ones do say 14WA. If you want low budget you can get remans from some of the local auto parts stores for 60-70 each.
  11. Aug 6, 2020 at 1:54 AM
    #291
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Post 2016, 14WA all became 14WB cast. I have 14WB up front and 14BD in the rear. The only difference in between A and B are the mounting hole sizes went from m12 to m14. You still get the 3mm larger pistons though.
    truckinducks likes this.
  12. Aug 6, 2020 at 12:58 PM
    #292
    nudavinci64
    Robert
    How did you factor for the bigger mounting holes? just eye it? also I thought it was 1mm bigger? If the newer ones are 3mm that could be another difference
  13. Aug 6, 2020 at 1:29 PM
    #293
    zippsub9
    Halfmoon, NY
    14 DCLB
  14. Aug 6, 2020 at 1:58 PM
    #294
    nudavinci64
    Robert
  15. Aug 6, 2020 at 7:27 PM
    #295
    Jeff Lange
    Calgary, Canada
    Hard to know exactly, but if you look closely you can see that the LH and RH are both the same picture that has just been flipped and the photoshopped. It even looks blurry in the area where the casting mark would be. Could be junk castings from China, could be "rebuilt" OE stuff. Hard to know exactly.
    As for the casting mark, what was said is correct. 2010-2015 (up to May, 2015) 4Runner and GX460 used 14WA calipers with M12 bolts, 2015-2021 (from May, 2015) use 14WB calipers with M14 bolts. Other than the mounting bolts, the calipers are idential, both have 48.1mm pistons. The Tacoma has 45.4mm pistons.
    Jeff
  16. Aug 11, 2020 at 1:24 PM
    #296
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    What are the OE caliper part numbers - it’s basically the same price for them as remanned, but on a parts site a 2011 4Runner had 14wb.
    Nevermind I just saw that they updated it from the factory. I wonder if there’s a sleeve that Toyota sells.
  17. Aug 11, 2020 at 2:05 PM
    #297
    nudavinci64
    Robert
    not sure pretty easy to get the 14WA bonkers for the sleeve. I actually need to clean up mine and sell them. I think I’ve seen them for $60- $70 each maybe a bit more.
  18. Aug 11, 2020 at 2:43 PM
    #298
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Eh? Lol. Yeah I ordered some spacer material off of the other guy’s thread link. Best I can do locally is drill out some near-sized SAE tube just until the metric tube comes in. OEM were only $156 each. I have a bad impression of remanned stuff for the most part on important parts (not an OEM Nazi by any means though) from being a regular watcher of South Main Auto on YouTube. That said I decided on a remanned first gen Taco 01-04 booster since it’s necessary for the Sequoia mc swap on 1st gens as I could buy about 5 of them for the price of OEM.
  19. Aug 11, 2020 at 2:46 PM
    #299
    zippsub9
    Halfmoon, NY
    14 DCLB
    hell I would’ve just cut you some and mailed it out. Nothing crazy on the sheath. I got all four calipers, rotors, loaded with pads at 5k miles off a 19 gx460 for $400 at a local junkyard.
    Dalandser[QUOTED] likes this.
  20. Aug 11, 2020 at 4:22 PM
    #300
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I appreciate it! I found 300mm (1 footish) 12mm ID x 14mm OD to be delivered here by Thursday for $12. I’m curious what the Toyota techs would do if they replace the calipers on a 2010 4Runner as not many of them are set up with a machine shop.
    Finding Toyota parts at a junk yard in Los Angeles / Southern California is as likely as finding buried treasure at the beach unfortunately. I got OEM GX470 rotors (for my first gen taco) for $120 total and 14WB Calipers for $312 total. I’ll be into this about $8-900 by the time I get a remanned 01-04 Taco brake booster (96-00 use a dual diaphragm that doesn’t work with a Sequoia MC) and an adapter kit with a Sequoia MC which I got from SOS that is made for an 00-06 Tundra, but should bolt up to the 01-04 booster. Phew lol.
    zippsub9[QUOTED] likes this.
