Comprehensive 5-lug 2nd gen lowering info.
Discussion in 'Street Trucks' started by tcBob, Nov 4, 2012.
  1. Aug 5, 2013 at 7:34 AM
    #161
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Pretty sure it is, at least I thought it was:banghead:
    Lol, the mods did so I wouldn get the ban hammer. I was two pitchers deep and had been on pirate 4x4 so I was in a dgaf attitude btt I got around to replying.:D
  2. Nov 28, 2013 at 7:45 AM
    #162
    Lpfan420
    Lpfan420 Well-Known Member
    06 base 4x2
    Ok so I have read this entire thread begin to end and I have a few questions.
    1) With the DJM 3/4 drop kit how far doe the bottom of the body sit off the ground?
    2) Someone mentioned that they felt DJM notch plate wasn't quite good enough and that one should be welded in. Can I get a bit more detail as to why that is?
    3) When I bought my taco it had an aftermarket exhaust pipe already installed. It is angled down and ends about half way between the rear axle and the back of the cab. When I lower the truck will that cause any issues?
    Additional info about my truck:
    2006 base model
    4cyl 5 speed man
    standard cab
    Like one of the other members I'm a complete noob to modifying my vehicle and am greatful for the info.
  3. Nov 28, 2013 at 8:15 AM
    #163
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    How low are you planning on going?? Do you wanna be slammed or are you looking for more of a performance stance?
  4. Nov 28, 2013 at 12:57 PM
    #164
    Phil Dammit
    Your Mom
    Tempe, Arizona
    1) it's a 3" drop at the front, the 4" keeps it level. Trucks sit higher in the rear.
    2) a welded connection is stronger than a bolted connection
    3) should be fine, will be louder though.
    Search whitney houston thread for pics of what I went through to get lowerdz
  5. Nov 28, 2013 at 1:15 PM
    #165
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    Exactly what Phil said I had mines dumped and it was way too loud inside the cab cuz it will be closer to the ground causing the sound to be trapped I got sick of the inside drone so I had ny exhaust redone to the back
    DJM 3/4 kit is perfect to be lower without beibg too low if you considered about road conditions and driveways and speedbumps
    I'd suggest XII performance stock height coils to stiffen the front as for notch if you get the djm notch I'd suggest welding it for strength mines is only bolted
  6. Nov 28, 2013 at 2:13 PM
    #166
    Phil Dammit
    Your Mom
    Tempe, Arizona
    If he's going to weld, just get a beefed weld in, or fab his own. Yes to the XII PERF stock heights, get xr billys, and you can get used front arms for cheap on xr underground for cheap. Djm just raised their prices.
    Btw I'm selling stock height springs and struts. Way low mileage
  7. Nov 28, 2013 at 10:57 PM
    #167
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Yup agreed haha I plan to have a nee notch fabbed up djm notch ain't cutting it
  8. Dec 3, 2013 at 12:57 AM
    #168
    Lpfan420
    06 base 4x2
    What are billys?
  9. Dec 3, 2013 at 3:16 AM
    #169
    Lpfan420
    06 base 4x2
    Also where can I find a beefed weld in notch?
  10. Dec 3, 2013 at 5:45 AM
    #170
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Streettacos.net I believe
    Billstein struts, check your pm box, I sent you a link to the ones I have for sale
  11. Dec 3, 2013 at 7:38 AM
    #171
    Phil Dammit
    Your Mom
    Tempe, Arizona
  12. Dec 3, 2013 at 5:13 PM
    #172
    III
    III Active Member
    Kailua, HI
    2011 blk XR
    i think it's offline... :p
  13. Dec 4, 2013 at 12:36 AM
    #173
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
  14. Dec 4, 2013 at 7:01 AM
    #174
    Phil Dammit
    Your Mom
    Tempe, Arizona
    My b, it is streetacos.com
    You got lost in all the subscribed threads. I did say add yourself if I missed you:p
  15. Dec 4, 2013 at 10:12 AM
    #175
    jmarquez808
    Jess
    Hawaii
    Broke my heart ha ha ha
  16. Dec 8, 2013 at 4:28 AM
    #176
    Lpfan420
    06 base 4x2
    Prolly a dumb question but I figure I'll get an answer faster here than anywhere else. Are the hood scoops that come stock on some of the tacomas functioning or just for show?
  17. Dec 8, 2013 at 6:15 AM
    #177
    Phil Dammit
    Your Mom
    Tempe, Arizona
    You can make them functional if you bought the OZ boost turbo kit or had the diesel. Otherwise no
  18. Dec 12, 2013 at 6:04 PM
    #178
    Kavik
    Kavik Kavik
    Texas, DFW
    Is your truck boosted yet Phil?
  19. Dec 13, 2013 at 12:52 AM
    #179
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    I want boost!!
    OZ boost raised their pricing to $3400 wth mayn
  20. Dec 13, 2013 at 7:34 AM
    #180
    Phil Dammit
    Your Mom
    Tempe, Arizona
    No :(, Christmas killed the funds. Lookin at a house to rent on Sunday though, which means I can finish my bobber and then sell it to BOOST!There is video of a URD s/c 09 with 36-37 swampers. It was fast for having all that rotational weight.
    Dont think their kit will work with our 2tr, the dont get the same exact motor.....:(
