Convert SR5 to TRD
Discussion in 'Off-Roading & Trails' started by Trailrash, Aug 20, 2011.
  1. Aug 20, 2011 at 7:34 PM
    Trailrash
    Trailrash [OP] New Member
    I just joined the world of Tacoma (2009 4x4 SR5). I will do some minor offroading - nothing crazy.
    What would you recommend for skid plates to get close to TRD protection?
    Thanks!
  2. Aug 20, 2011 at 7:42 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    welcome! and go aftermarket! i hear the TRD skids plaits are not the best and can be pretty weak!
  3. Aug 20, 2011 at 7:46 PM
    Trailrash
  4. Aug 21, 2011 at 4:15 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    3 plates...
    IFS skid,T-case and trans. skid.
  5. Aug 21, 2011 at 3:55 PM
    babsgt
    babsgt New Member
    Dallas
    06 4x4 4Q2
    ARB Bumper, Warn winch, Demello sliders
    TRD makes skid plates?
  6. Aug 21, 2011 at 4:16 PM
    gottahot1
    gottahot1 Well-Known Member
    T.D.
    Arizona
    08 BLUE double cab 4x4 short bed Sport TRD
    'Caribe' fog light mod - Power port always on mod - Defrost A/C override mod - Illuminated 4x4 switch - Read diff breather relocation
    Hi Trailrash,
    I have a TRD 4x4 and the skidplated are basically worthless. I definitely recommend aftermarket skids.
    I'm not aware of any "mild" aftermarket skidplates but be sure to compare the thickness and additional support (if any) between brands. 3/16" is pretty common and should give you peace of mind even as you surpass mild wheeling.
    Fit is important so find a company who makes all three pieces (IFS, trans/oil pan, transfer case) and buy them as you can afford them.
    Which one do you get first? I've found that my transfer case and exhaust are the most prone to being bashed. Your experience might be different.
  7. Aug 21, 2011 at 4:29 PM
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    09 BSP SR5 DC 4x4
    285/70/17 Dynapro MTs, Shrockworks front bumper, Armortech rear bumper
    If you ar going to do a skid upgrade do it right the first time and go with the Budbuilts or a set from Kevin at Armortek Offroad.
    Even mild offroading can go bad at times
  8. Aug 21, 2011 at 4:34 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    And sliders to save your rocker panels.
  9. Aug 21, 2011 at 7:55 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    33's,armor,crawler,dents, ect
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    IMO you will need sliders before you need skids. While the stock skids arnt bomb proof they definatly do the job.
  10. Aug 22, 2011 at 8:31 PM
    brp
    brp Well-Known Member
    You should also check out the yellow wire mod. Your Sport does not have all of the limited slip differential capabilities it could in 4 Low. All you have to do is cut a wire and you gain some capability. Search for it on this site.
  11. Aug 22, 2011 at 8:49 PM
    brp
  12. Aug 24, 2011 at 2:10 PM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    The main thing that puts the TRD apart from SR5 or other packages is the rear diff locker and bilstien shocks.
    I was not aware there's any difference in the skid plates.
  13. Aug 25, 2011 at 10:13 AM
    Chickenmunga
    Chickenmunga Nuggety
    Hillsboro, Oregon
    08 TRD Offroad DC 4x4 (read the build)
    VERY much agree. You can get away with alot before needing skids. I consider sliders a necessity.
    TRD OR has a brush plate. Basically a tin plate to keep junk away from the underside of the engine area.
    From factory you can add the grey TRD skid plate to any model, but as said.... why?
  14. Aug 25, 2011 at 10:29 AM
    gottahot1
    T.D.
    Arizona
    OK, sorry for the newb question, but mine is both a TRD and SR5. What's up with that?
  15. Aug 25, 2011 at 11:14 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Do a search on this site as well as others, you will find thousands of posts telling you what is included in each package.
