Cooling issues? Not anymore
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Deo taco, Aug 25, 2020.
  1. Sep 11, 2020 at 7:47 PM
    #281
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Not sure if this if OP wants me to start a new thread, as I am piggybacking off this idea. But hopefully we can collectively brainstorm for anyone else looking to upgrade the cooling in the 3rd gen.(that's what TW is for right?!) Disclaimer; I have no intentions to sell these..just a project for my personal truck.
    I first started making some brackets to attach the fan
    They would work, but I felt like it needed a little more rigidity. After looking at the OEM unit, the mount is integrated around the entire circumference of the fan motor. So I set off and purchased a whole new unit from GM, bracket and all
    Here is the new radiator; CSF #7082 (which is actually made for 2nd gens, but will fit 3rd gens will a small modification I will go over later) also pictured is the OEM 3rd Gen shroud installed, and the new fan.
    2nd Gen radiator mounts holes are larger diameter (1.150") compared to the 3rd gen which is smaller(sorry didn't measure)
    A quick search for some bushings/hardware and we are back in business to mount it.
    Clutch fan removed.. frees up ALOT of space!
    Now the fun part... cut apart the stock GM fan. I only needed it for the support arms/brackets
    Ground down and cleaned up the edges. Mocked up to the stock shroud
    I knew it would be close by eyeballing, but we are still 3/8" off from meeting up with the shroud diameter. My plan is to make some small spacers and put a through bolt/nylon nut from each support arm into the shroud. Now when this thing spins @ XXXXXRPM I won't have to worry as much. Between the new fan and the aluminum radiator it should be SUPER COOL. Next is hooking up the electronics. The PWM module has been back ordered, but should be here next week:D
  2. Sep 11, 2020 at 7:54 PM
    #282
    Lateralus01
    Lateralus01 Well-Known Member
    2018 Cement Tacoma TRD OR DCSB 4x4
    @MESO thanks for sharing. I’m in for this as a solution for the underwhelming A/C on hot days here in Nevada. Not liking the 62 pages of garbage the TSB offers for a pusher fan.
    OP what’s the latest on your efforts?
  3. Sep 11, 2020 at 7:55 PM
    #283
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Very cool. Did you buy the one I linked you from Amazon? Haha rock auto has it too for a little cheaper
    you could 3D print some spacers similar to this section, maybe 4 of them and it would be super solid
  4. Sep 13, 2020 at 2:34 PM
    #284
    TheTacoChrist
    TheTacoChrist Well-Known Member
    Dick
    2018 TRD PRO Taco
    Lettuce removed Ghost pepper sauce added Subbed: Tortured baby cow for tofu.
    Looking forward to this being sold as a kit. Count me in.
    AxisCab and Ol'gray mare like this.
  5. Sep 13, 2020 at 2:45 PM
    #285
    MESO
    State of Jefferson
    No I ended up getting it from Scoggin-Dickey which is one of the biggest GM parts dealer. Same price but free shipping and was here in a few days. Be careful as I have seen some that look like OEM replacements but are not label SPAL, and look like an inferior casting body.
    I already have the spacers tested and they are super beef. They taper down into the stock plastic fan frame and sandwich to the fan shroud. 2 bolts will go through each. I feel more than confident with this mounting.
    These were just quick mockup prints for fitment. Final ones will be printed this week on the HP MJF.
    Torspd, JG358, 12TRDTacoma and 8 others like this.
  6. Sep 13, 2020 at 4:02 PM
    #286
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Nice, I'll need a couple of sets if/when in production.
    Ol'gray mare likes this.
  7. Sep 13, 2020 at 4:07 PM
    #287
    Xtra_yota
    Xtra_yota Well-Known Member
    Sacramento
    2017 Tacoma SR, 5MT
    AxisCab likes this.
  8. Sep 13, 2020 at 4:23 PM
    #288
    anthony250f
    Anthony
    San Diego, CA
    Would it fit having the 3 mounts on the left/right and having the wires come straight up? Would fit better that way with the larger alum radiator. Fj shroud doesn’t have the overflow bottle in the way like the Tacoma one
  9. Sep 13, 2020 at 4:36 PM
    #289
    MESO
    State of Jefferson
    Technically you could rotate it anyway orientation and use as little as 3 brackets(triangulated). I wanted overkill so I’m putting a bracket each stock arm(7). Also the way they are clocked, there is a gap where there are no arms/brackets which works perfect because that’s where the overflow is. The best part is the fan only sticks out ~1/2” past the shroud
  10. Sep 13, 2020 at 4:47 PM
    #290
    anthony250f
    Anthony
    San Diego, CA
    Very cool. Would definitely work for me. Fj shroud is smooth all the way around. If I just cut 1/2” out at each mount the fan would be flush, provided that there’s enough room to the radiator. Would definitely solve this issue
  11. Sep 13, 2020 at 4:48 PM
    #291
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I dont think it does, it doesnt apply to manuals either. Its something to do with the transmission cooler blocking a bit of the air flow, and there is such a razor thin margin for working that just that blockage makes it not work.
  12. Sep 13, 2020 at 5:05 PM
    #292
    Xtra_yota
    Sacramento
    2017 Tacoma SR, 5MT
    ahh I was actually thinking that as I posted - thanks for the clarification. Guess I’m glad I’m MT with no tranny cooler lol
  13. Sep 15, 2020 at 10:47 AM
    #293
    kcx23
    kcx23 Member
    Los Angeles
    Torspd and Ol'gray mare like this.
  14. Sep 15, 2020 at 11:02 AM
    #294
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    @MESO strikes again!
    a PWM fan would be awesome
  15. Sep 16, 2020 at 6:30 PM
    #295
    MESO
    State of Jefferson
    I was just impatient and didn't want to wait lol. It's the same as 2nd gens but now has aluminum bushings.
    She's in!
    Final brackets
    Was going to put the allen head one the outside(where the recess is) and lock nut on the inside but the fan was alot closer than I anticipated. So they went in the other way
    Clearance
    It's strong AF. I have no doubts it will hold together. It actually stiffened up the whole plastic shroud.
    BYE BYE clutch fan!
    Room to spare:)
  16. Sep 16, 2020 at 6:34 PM
    #296
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Awesome
    MESO[QUOTED] likes this.
  17. Sep 16, 2020 at 6:34 PM
    #297
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    If there is that much room on mine when done it'll be perfect!
    uploadadventure likes this.
  18. Sep 16, 2020 at 6:46 PM
    #298
    MESO
    State of Jefferson
    P.S I used HPS radiator hoses for a 2nd gen and they worked out perfect.
  19. Sep 16, 2020 at 7:55 PM
    #299
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    Sent you a pm
  20. Sep 16, 2020 at 8:16 PM
    #300
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Why fer? HPS makes 3rd gen hoses.
