Cooling issues? Not anymore
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Deo taco, Aug 25, 2020.
  1. Aug 26, 2020 at 8:49 AM
    #141
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Spouse
    Torspd, wahoobie and tonered[QUOTED] like this.
  2. Aug 26, 2020 at 8:53 AM
    #142
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That would be my question:
    Kev250R[QUOTED] likes this.
  3. Aug 26, 2020 at 8:53 AM
    #143
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    100%! :D
    BigWhiteTRD[QUOTED] likes this.
  4. Aug 26, 2020 at 9:04 AM
    #144
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    We have Homer Simpson as a great example of that..
  5. Aug 26, 2020 at 9:09 AM
    #145
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    He might have been partly right?
    Looks like a 2021 Bimmer SUV? :rofl::rofl:
    Torspd, wahoobie and crashdb[QUOTED] like this.
  6. Aug 26, 2020 at 9:11 AM
    #146
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    If the torque output is limited, then I'd expect a mpg increase if this is indeed more efficient.
    tonered[QUOTED] likes this.
  7. Aug 26, 2020 at 10:13 AM
    #147
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    you can't see it.....you gotta feel it!
  8. Aug 26, 2020 at 10:46 AM
    #148
    Deo taco
    Deo taco [OP] Well-Known Member
    2017 trd pro in cement grey.
    Lots to come
    you guys cant look at it that way. the torque command is from driver request. if the dirver say i need this much pedal to go 75 down the highway the truck makes that happen and provides to the torque to do so. but with an engine driven fan that torque required to go doen the highway thru the air and turn everything has the fan torque added to the system. cant go 75 down the highway WITHOUT the fan spinning. the loss is always there. if its deleted and the e fan doesnt need to run not there is ) parasitic loss and the engine commands less to go 75 and burns less gas.
  9. Aug 26, 2020 at 11:21 AM
    #149
    Kheiron
    Kheiron @Koditten Pirate Radio member #003
    Kevin
    Powell, WY
    2017 OR DCSB QS
    Kenwood d710g, high speed pheasant mod
    I’ve read this whole thread to this point and I am definitely interested. It’s 120 out here regularly and I could use the extra cooling. During recoveries and general wheeling, things get HOT.
  10. Aug 26, 2020 at 12:02 PM
    #150
    Ol'gray mare
    Ol'gray mare Well-Known Member
    West, Tx
    2017 MGM DCLB TRD OR Geared, locked and tuned, rear disc brakes. 2018 TRD PRO White boss' bone stock
    Build thread coming soon.
    AxisCab likes this.
  11. Aug 26, 2020 at 12:11 PM
    #151
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Yes and it definitely fixed it for some people. I’m adding in a larger all alum radiator
  12. Aug 26, 2020 at 12:14 PM
    #152
    Deo taco
    Lots to come
    be very careful there, a radiator only works once are is passed thru. alot of aftermarket companies do NOT design fin density per the vehicle and can create high pressure zones in FRONT of the rad with little air passing thru. those work if you have a very aggressive say e fan to back it up. i have done the math on single pass vs dual vs 3 and there is almost no gain from dual to 3 bc of the slow down of the water system due to the restrictions in the rad. bc you have taken a single pass rad with say 30 routes for the water to pass thru and now have 10 and it has to do it 3 times.
  13. Aug 26, 2020 at 12:22 PM
    #153
    anthony250f
    Anthony
    San Diego, CA
    Have you seen this thread? This radiator has been very successful
    https://www.tacomaworld.com/threads...mance-radiator-for-our-trucks-finally.539151/
    The increased capacity makes a massive difference.
    I personally modified the oem fan clutch to pull more air, at the cost of robbed horse power I’m sure. I also have a pusher fan for slow situations. Truck never gets hot at idle, yet runs super warm at freeway speeds in 100+ degree temperatures. The increased coolant capacity should help a bunch.
    MattCowsmasher likes this.
  14. Aug 26, 2020 at 12:52 PM
    #154
    Deo taco
    Lots to come
    I have not seen the rad but I can tell you that no oem runs pusher fans bx it blocks air at highway speeds. Thats actually hurting your system. The air at speed does not have time to get around the fan motor and into the rad fins it covers. So that creates a dead spot in the rad at highway speed
    Torspd likes this.
  15. Aug 26, 2020 at 1:23 PM
    #155
    anthony250f
    Anthony
    San Diego, CA
    no oem runs a pusher fan? That’s not true. There’s an entire toyota TSB to add a pusher fan to the ac condenser.
    definitely don’t disagree with you on the fan blocking the air though. Definitely not an ideal set up.
    TireFire likes this.
  16. Aug 26, 2020 at 1:24 PM
    #156
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    Thank you for posting this as this is exactly what I’ll likely be upgrading to! Pound for pound even a two-row aluminum radiator will dissipate heat much more effectively than one with plastic tanks will.
    Torspd likes this.
  17. Aug 26, 2020 at 1:42 PM
    #157
    BigWhiteTRD
    Ted
    Can you provide ANY support for these statements. I may be wrong, but these kind of statements often sound good, but have no basis (often times).
    I would love to see some kind of data (airflow data, thermal imagery, something) because I am having a very hard time justifying that it is dramatically different front vs rear...
    Convince me.
    Shellshock, Kev250R and tonered like this.
  18. Aug 26, 2020 at 1:46 PM
    #158
    Deo taco
    Lots to come
    https://www.holley.com/blog/post/ho... puller fan on the,it is behind the radiator.
  19. Aug 26, 2020 at 1:46 PM
    #159
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    While not the data points your looking for, its a pretty old company thats been doing performance for a long time.
    https://www.holley.com/blog/post/how_to_choose_an_electric_radiator_fan/
  20. Aug 26, 2020 at 1:47 PM
    #160
    Deo taco
    Lots to come
    pusher fans ride almost on the rad fins. that means air at 70mph has to go around the motor, with momentum and turn back behind it and get routed into the fins that run straight thru the rad.
