Crush Gaskets On Drain Plugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blm, Dec 30, 2022.
  1. Dec 30, 2022 at 6:53 AM
    blm
    blm [OP] Well-Known Member
    Getting ready to change the fluids in my 2013, 4cyl, manual 5 speed. Planning on trans fluid,transfer case and differential. Was wondering if just the drain plugs on these have the crush gaskets or do the fill plugs have them as well? Anybody have a source for these gaskets?
  2. Dec 30, 2022 at 7:04 AM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    TnShooter likes this.
  3. Dec 30, 2022 at 7:11 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    I keep this taped to my tool box.
    08TacoTrD, Hook78 and 2015WhiteOR like this.
  4. Dec 30, 2022 at 7:14 AM
    MikefromCT
    CT
    2013 TRD OR DCSB
  5. Dec 30, 2022 at 7:18 AM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    hoffengineering likes this.
  6. Dec 30, 2022 at 7:34 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I just use Teflon tape, have for years without an issue.
  7. Dec 30, 2022 at 8:26 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I never use Teflon (PTFE) tape where it could get inside the engine. If I have to seal threads on a drain plug (which, for example, my 1962 Triumph TR3 likes) I use PTFE joint compound. Less chance of a solid piece getting into the internals.
    Small risk, yes, but for about the same effort I play it safe.
    But on my Toyotas and Lexus, I use OEM washers.
  8. Dec 30, 2022 at 10:18 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    I've used copper crush washers on all my vehicles for years and years. Plugs on oil pans, transmission, diffs, etc.—works like a charm.
    I buy a similar assortment pack for all the vehicles I work on + a 12MM set because apparently I have a lot of M12 plugs I need to drain. :rofl:
  9. Dec 30, 2022 at 10:32 AM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    Agreed on the PTFE tape. PTFE is compatible with the fluids for sure, but the threads on the plugs aren't meant to be sealing and using a washer is far more fool proof.
  10. Dec 30, 2022 at 10:38 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Those copper type work fine the first time. But I never had much luck reusing them. The old crush style I’ve reused multiple times.
    Maybe it was just my experience?
    But they work fine if you use a new one each time.
