Cupholder Modification
Discussion in '1st Gen. Tacomas (1995-2004)' started by jrallan26, Dec 31, 2006.
  1. Dec 31, 2006 at 11:53 AM
    jrallan26
    jrallan26 [OP] Well-Known Member
    Iowa
    2004 White D-Cab TRD
    On my Tacoma the cupholders are pathetic. The plastic "fingers" keep on tearing apart. I have replaced these numerous times.
    This time I replaced the fingers on my cupholder with thick neoprene from an old mousepad. Works great.
    Cost - 0$
    Total time - 1 hour at most
    Tools needed
    1 Philips screwdriver
    10 mm socket and rachet (sp)
    socket extention (not needed but helpful)
    sharp scissors
    Please dont ask for pics, the wife took the camera with her.
  2. Jan 4, 2007 at 4:25 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Hey jrallan26 yea samething happen to me on my 03 but when I went to replace those fingers, I found out that Toyota has changed the material to a rubber material not that soft sponge stuff.
    P/N 66995-AD011
    P/N 66995-AD021
    cost about 4 bucks.
  3. Jan 4, 2007 at 4:30 PM
    jrallan26
    Iowa
    I bought some of those also. They also tear after a while. Thats why I made these out of neoprene. Works much better!
  4. Jan 5, 2007 at 8:17 AM
    Shore Guy
    Shore Guy New Member
    If the wife comes back send a photo, same issue here and curious as to how you modified. Cheers
  5. Jan 5, 2007 at 10:22 AM
    jrallan26
    Iowa
    Basically what I did was I used the old fingers in the cupholder as a pattern and cut new ones out of neoprene (mousepad).
    I will take a couple pics later on.
  6. Mar 17, 2009 at 4:35 PM
    MCRANEY
    MCRANEY WARTHOG
    CRESTVIEW FL
    03 Tacoma 4WD SR5 TRD
    3" Lift 285/75 16R Tires Aries Stainless Steel Grille Guard, KC Lights
    good idea, i called just toyota just to get the rubber replacements and they told me i had to buy a whole new center console. yea right. i am going to do this modwith mine, thanks
  7. Mar 18, 2009 at 3:13 AM
    03coma
    New Jersey
    2015 DCSB TRD, SR5
    Mcraney here are the p/n's for the 03 tacoma
    P/N 66995-AD011
    P/N 66995-AD021
    cost about 4 to 5 dollars
  8. Mar 18, 2009 at 7:52 AM
    MCRANEY
    MCRANEY WARTHOG
    CRESTVIEW FL
    thanks
  9. Mar 18, 2009 at 8:25 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    X2. Got these at the dealer, better quality than the original.
  10. Mar 22, 2009 at 1:11 AM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    2015 TRD Sport 4wd
    Icon Coilovers, Magnaflow, K&N Intake
    I ordered these from this website and they cost me $8. They are the new style that don't tear apart like the the older ones. I figured I could spend the $8 and not trace out the old ones and cut up a mouse pad (good idea though). I almost did that when I went to the dealership and they told me I had to buy the whole console. Idiots!
    http://www.trdparts4u.com/PD-CUP-TABS.aspx?MakeID=1
  11. Mar 22, 2009 at 11:52 AM
    Choco Taco
    Choco Taco Sprayin' Paint like Its my Job
    South Dakota
    01 D-CAB SR5
    2" Lift 265/75/16' MT's Homemade Prerunner Bar
    I'll do you one better. Go to McDonalds and hit up the dollar menu. Buy a fruit and Yogurt Parfait. Take the lid off said parfait and put it in your cupholder upside down. voila! your cupholder now holds 12 oz. cans without tipping over
    :D
  12. Jun 3, 2009 at 1:24 PM
    22b22
    22b22 Well-Known Member
    Northern California - East Bay
    03 DoubleCab PreRunner TRD SR5
    OME 881/N91S - front Wheeler 5-pack/N85 - rear
    I just ordered these at the local Toyota Stealership $7.87 and they'll be here in a few days.
    thanks for the part numbers!
  13. Nov 7, 2012 at 9:22 AM
    hkdontoyotas
    hkdontoyotas Active Member
    Can someone tell me how many of each part number would make a complete set. I know there are different sizes and all my tabs are missing so I have nothing to reference for the sizes. Thanks
  14. Nov 7, 2012 at 9:32 AM
    DD03SR5
    DD03SR5 Well-Known Member
    Derek
    Ontario,Canada
    03 SR5 4X4
    Deckplate,5100's,eibach's,Wheelers AAL,
    i bought some 1/8" rubber gasketing and used the old ones as templates. and cut them all out. its awesome now nothing is tipping over. the only thing is they are stiff, but they are working in a bit now
  15. Nov 7, 2012 at 9:34 AM
    Madjik_Man
    Colorado Front Range
    Don't buy the same material. Do this:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/14384-cup-holder-thingies-2.html#post2138962
    Far superior. Total cost $2.50
    Exactly
  16. Nov 7, 2012 at 9:38 AM
    hkdontoyotas
    i would use the gasket material but i have no tabs left for templates. i did find this quote that helps out if anyone needs the correct info:
    Ok, The dealership I use just confirmed that there are only 5 of them. The way it works is that the two that are cloest to eachother are actually 1 tabe that is double sided if that makes since, 1 side sticks in 1 cup holder and the other side sticks in the other cup holder. Here is what you need:
    Part Number 66995-AD010 Quantity 4
    Part Number 66995-AD020 Quantity 1
    these may be the older material. i believe the new material used is ad011 and ad021
  17. Nov 7, 2012 at 9:45 AM
    Madjik_Man
    See attached for a template. Don't resize it or "fit to page" Just print as is.
    I'm telling you, the 1/8" gasket material is VASTLY superior to the material you'll buy from the dealership... at a fraction the cost.
