Custom Billet Shift Knob for Toyota Tacoma (2-1/4" diameter). ***Utilizes factory boot.***
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by 7r41lbr34k3r, Feb 15, 2018.
  1. Sep 7, 2019 at 4:17 PM
    #2001
    arcticrobot
    arcticrobot Well-Known Member
    2017 TRD Sport manual
    USPS messed up delivery and I got this piece of art today instead of Thursday. Filled engraving with wifes black nail polish. Here are some preinstall pics. Awesome piece, TrailBreaker!
  2. Sep 7, 2019 at 4:33 PM
    #2002
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    Each of the colors is a different thickness. So, knowing the thread pitch, each shim will back off the amount the knob turns in. I found that resting the shims on top of the shifter stalk was tricky and the shims sometimes slid off as I was installing the knob. A little dab of grease will help hold it in place. Or you can put a dab of grease on the shim and drop it down inside the shifter knob. Then use pencil or small screw driver to get it to lay flat then thread on the shifter knob. There is a link in the OP's signature, that goes over the shim procedure.
    tonered and TeecoTaco like this.
  3. Sep 7, 2019 at 5:02 PM
    #2003
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    As I recall, each colour shim denotes amount of degrees reduction to max turn. Rick has the chart somewhere in here...so if you are ove spun by 90 deg then it's 2 blue or something of that nature. Might be 1 orange and 1 yellow to solve the equation.
    And ya, dab of grease helps it sit...but if your math is off makes it harder to fish out lol
  4. Sep 7, 2019 at 5:03 PM
    #2004
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I had a chance to drive around a bunch today and test out the new shift knob.
    The verdict: I love it.
    I love the knurled delrin ring. It's the perfect balance of slippy and grippy without being too harsh. The weight of the Ti is pretty much perfect. I found though that I really want to lower the shifter by at least 1.5". The URD STS raises it by 3/4" - 1" and I just don't like it that high. I'm going to see if I can source the right threading die and take care of that.
    7r41lbr34k3r[OP] and tonered like this.
  5. Sep 7, 2019 at 5:39 PM
    #2005
    fatboyfirebass
    Yup, there is a bit of "Kentucky windage" involved in determining the angle needed. I did have to "sneak" up on it when I got close. But I ended up stopping a little short. In the install instructions he mentions that the shims will compress a bit in the first few days and then the knob will over rotate a bit, so you will need to go back and add a blue shim. I was lucky enough that I was able to get it to end up about the amount that a blue shim would add, so I stopped there and let the shims compress and then tightened it right into position.
    Yes, if you have to get the shims back out, it will be one of the rare times you need that pick with the weird little offset tip, to stand the shim up on end and then GENTLEY tap the open end of the knob down on the table to get the shims back out.
  6. Sep 7, 2019 at 7:22 PM
    #2006
    TeecoTaco
    SW Ontario
    Xacadackley...I got lucky first time thru. Well that and I texted Rick and asked him for the math.
    Y'all gots his number ya?
  7. Sep 7, 2019 at 7:33 PM
    #2007
    fatboyfirebass
    I don't have his number, lol. But I do actually use those same types of shims to set up some of my machines at work, so I have a little practice with them. Of course, in this application, there is an extra step in converting the metric thread to SAE, or shim thickness to mm first, before you can determine which size to use. Luckily, Rick had already done that in the shim instructions.
    TeecoTaco[QUOTED] likes this.
  8. Sep 7, 2019 at 7:53 PM
    #2008
    TeecoTaco
    SW Ontario
    Yup...it's in the instructions here somewhere...if as a community we can discover Mandi in Phoenix, we can locate the shim specs here
  9. Sep 7, 2019 at 7:55 PM
    #2009
    lapoltba
    CT - 06076
  10. Sep 7, 2019 at 8:03 PM
    #2010
    TeecoTaco
    SW Ontario
  11. Sep 8, 2019 at 1:56 AM
    #2011
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
    5A283B60-F0EF-4C52-8E2F-3BEFA8F5F485.jpg 3F54CCAF-F088-46E3-AAD6-E7EDC97B25AB.jpg This came out perfect .... can’t wait to get the shift kit installed
  12. Sep 8, 2019 at 2:11 PM
    #2012
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    What Pioneer stereo you got stuffed in there?
  13. Sep 8, 2019 at 2:14 PM
    #2013
    oostroma
    oostroma (Boomer)
    Ontario
    Is that a switch you have in the pocket behind the shifter?
  14. Sep 8, 2019 at 2:27 PM
    #2014
    su.b.rat
    su.b.rat broken truck
    Core shifter? you're gonna love it.
    fake4x4[QUOTED] likes this.
  15. Sep 8, 2019 at 3:00 PM
    #2015
    little bear
    little bear Well-Known Member
    Barry Hobson
    Canadian, Texas
    silver streak 2017 Tacoma trd sport 4dsb 6sp MT
    Black badges, TRD pro grill, clazzio seat covers, falken wild peaks AT3W 265 70R17, Fuel Trophy wheels, taco tunes 10" sub and Jl Audio all around speaker upgrades, dynamat doors and interior, Meso's interior lights, gasshole, waterproof led bed lights, headstrong progressive leaf pack, bilstein 5100's with OME 887 coils, ecgs bushing, nfab nerf bars, cbi t3 aluminum bumper
    Avic 8400 and I absolutely love it
  16. Sep 8, 2019 at 3:26 PM
    #2016
    oostroma
    oostroma (Boomer)
    Ontario
    Did you post the installation on TW?
  17. Sep 8, 2019 at 4:01 PM
    #2017
    little bear
    Barry Hobson
    Canadian, Texas
  18. Sep 8, 2019 at 6:17 PM
    #2018
    Thehighesttree
    Thehighesttree Active Member
    Benjamin
    2018 Cement TRD OR Manual
    It’s a ID badge with a clip on it
    tonered likes this.
  19. Sep 8, 2019 at 7:28 PM
    #2019
    oostroma
    oostroma (Boomer)
    Ontario
    It gave me an idea. I want to relocate my ECT button to somewhere closer to the shifter. I never thought of that location until I saw something in the pic you posted.
  20. Sep 8, 2019 at 8:30 PM
    #2020
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
