Custom Rocker Switch Group Buy - Limited Time! - Ships NOW! - Blitzpro
Discussion in 'Group Buys' started by Blitzpro, Aug 18, 2014.
Thread Status:
Not open for further replies.
  1. Aug 27, 2014 at 4:00 PM
    #41
    catattacksdog
    catattacksdog Well-Known Member
    Not Steve
    Not Kentucky
    07 dc
  2. Aug 27, 2014 at 4:45 PM
    #42
    Blitzpro
    Blitzpro [OP] Well-Known Member
    After skimming through the thread, it seems to me the modification requires you to break the green wire connection. We could configure a switch to do that, however, having it light up when you press it is a bit more complicated and would be a custom bodied switch.
    You can use one of our regular switches, and I can configure it to have the top LED independently wired - meaning it'll stay illuminated regardless of what position the switch is in - and when you press the top of the actuator, it will turn your ABS off. The bottom LED would not light. This can be done with our stock switches and would not cost any extra. Or you can reverse this orientation.
    We would basically flip the orientation of the actuator cover on our standard switch so pushing the top of the switch would deactivate your ABS. If you would rather the bottom of the switch light up with text, you would have to push the bottom of the actuator in to deactivate your ABS.
    Here's a quick picture to more easily explain your options. Let us know what you'd like to do and we can send you an invoice.
  3. Aug 27, 2014 at 6:22 PM
    #43
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Somewhat interested in the above as well, as I have the ABS killswitch too.
    So what I'm seeing is there is no way to have (this would be what I would personally want)
    Have the ABS symbol always lit up, and using option 1, flipping down the switch turns on the "off" LED, indicating it is now off.. and when the ABS is on (switch flipped up) the "off" LED turns off.
    If that makes sense.. lol
  4. Aug 27, 2014 at 6:31 PM
    #44
    catattacksdog
    Not Steve
    Not Kentucky
    07 dc
    In a perfect world I want exactly what moose1988 is talking about.
  5. Aug 27, 2014 at 6:34 PM
    #45
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :thumbsup:
    I may just stick with my trusty ol' metal toggle switch. The indicator lights on the gauge cluster are enough to let me know when its engaged or not.
  6. Aug 27, 2014 at 6:46 PM
    #46
    Blitzpro
    What you guys want can be done. I was only offering the above options because there isn't any extra cost to do those options for you guys. If you'd like the switch to behave as you guys described, I'd need to find out what voltage that green wire is putting out.
    From there I can make the PCB for the circuit in order for the LEDs to behave in the manner you guys described.
    The additional cost for a custom switch like that is about $25. Let me know if that's the route you'd like to take. If so, I can bring a Tacoma in to test to make sure it doesn't interfere with any of the functions of the ABS.
  7. Aug 27, 2014 at 6:49 PM
    #47
    catattacksdog
    Not Steve
    Not Kentucky
    07 dc
    So total for the switch? I think thats the way I would like to go! Can you make a switch turning my 4.0L into a monster V8?
  8. Aug 27, 2014 at 6:52 PM
    #48
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    Sub'd....
  9. Aug 27, 2014 at 6:59 PM
    #49
    Blitzpro
    Total would be $25 plus what a regular SC1 switch is going for on the group buy page.
    I'd really want a switch to turn a 4.0 into a monster V8 too, lol. Unfortunately those switches are usually attached to an even more monster sized invoice.
  10. Aug 27, 2014 at 7:03 PM
    #50
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Good to know! :thumbsup: thanks guy from Blitzpro! Lol :cheers:
  11. Aug 27, 2014 at 7:37 PM
    #51
    Blitzpro
    Haha, you're welcome.
    -Ty (not as in thank you, but that's what people call me)
  12. Aug 27, 2014 at 7:46 PM
    #52
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    got it. :thumbsup:
    ya know what would be awesome.. and this is a long shot.. but if you guys offered prewired/set up switch banks.
    for instance.. my plan is to use my sunglasses holder for my switches. It can house 5-6 switches and looks very clean. several members here have done this setup with great success. Me on the other hand.. am completely dumbfounded when it comes to wiring switches. My 2 right now dont even light up how they should.
    If a premade setup was available.. I, and I'm sure others, would gladly pay the cost.
    just have it include the switch bank, the switches that the buyer chooses, and then some basic wiring behind them with short pig tails so maybe we can just crimp the ends together or atleast labeled.
    I would love to have it show up, cut the hole in the sunglasses holder, install, and then connect some wires and its good to go.
  13. Aug 27, 2014 at 7:52 PM
    #53
    Blitzpro
    Can you link me to a thread where this bank is in the sunglass holder?
    I can definitely do something like this for you guys. Make the panel and pre-wire all the switches with labeled pigtails.
  14. Aug 27, 2014 at 7:59 PM
    #54
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    that would be AMAZING!!
    Im first!!! lol
    one sec.. ill edit this and add a link.
    BGR (BrutalGuyRacing) was the first one I saw with this.. there could have been others.. but I'll give the credit to him for now. first page of his build.
    http://www.tacomaworld.com/forum/2nd-gen-builds/229440-bgrs-build-thread.html
    another.. http://www.tacomaworld.com/forum/lighting/149014-rocker-paddle-switch-sources-4.html#post5748487 sorry these arent too thought out/detailed.. just doing quick searches for these switch locations.
  15. Aug 27, 2014 at 8:01 PM
    #55
    2011supercoma
    2011supercoma Well-Known Member
    nola
    sr5 4x4, trd supercharged
    trd supercharger, afe cai, doug thorley lt hearders, magnaflow exhaust, rcd 4.5" lift with ome 883 springs, cbi ditch light mounts with rigid industry D2 spot lights,
  16. Aug 28, 2014 at 9:18 PM
    #56
    Tovar28
    Tovar28 Well-Known Member
    David
    Chino,California
    05 prerunner TRD sport
    bilstien 5100s in front @ 1.75 bilstien 5160 in rear,general HD 4 leaf pack, 20% tint in front 5% rear, 40 inch led bar ,Kc daylighters , Aries bully bar , aries side steps ,black housing headlights ,factory roof racks ,snugtop camper shell, plastidip rims, bfg ko2 tires
    Can you guys make one that looks like this?
    (Got the pic off a member)
  17. Aug 28, 2014 at 9:53 PM
    #57
    Blitzpro
    That looks like the front of an FJ if I'm not mistaken. Are you looking for an FJ silhouette or Tacoma silhouette?
    Regardless, yes we can draw something like that for you. :)
  18. Aug 28, 2014 at 10:42 PM
    #58
    Tovar28
    David
    Chino,California
    Tacoma haha oops!
  19. Aug 29, 2014 at 12:05 PM
    #59
    Blitzpro
    Got a 2nd gen Tacoma in today to work on a bit. May have something for you guys next week :D
  20. Aug 29, 2014 at 12:19 PM
    #60
    Andrew K
    Andrew K yeah...im a newbie
    Andrew
    Chesapeake, VA
    05 SR5 4x4
    camper shell, rod racks, not much. its a fishing truck
Thread Status:
