CV Axle Confusion.
Discussion in '1st Gen. Tacomas (1995-2004)' started by takern, Oct 7, 2010.
  1. Oct 7, 2010 at 11:21 AM
    takern
    takern [OP] Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    I need to replace my CVs on my truck and I called Autozone to see if they had any in stock and the guy i talked to wasnt helpful to say the least. he said all they had in stock was a half shaft instead of a full cv axle. is the cv axle two shafts or do they call the entire assebly the half shaft? Also, what is this $100 core charge they are going to charge me for?
  2. Oct 7, 2010 at 11:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    They call the entire assembly a half shaft. It takes two half shafts per truck; a right and a left.
  3. Oct 7, 2010 at 11:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    A core charge means you have to bring the replaced part back in to get the $100 charge back. It's common among alternators, starters, etc. They reuse pieces from the the replaced part.
    Here is one half shaft.
  4. Oct 7, 2010 at 11:26 AM
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    A core charge is what they charge you at firs but you get it back when you bring your old axle in, since they rebuild these.
  5. Oct 7, 2010 at 11:27 AM
    kcbmx
    Marco
    2tr-fe 4wd
    beat me to it lol
  6. Oct 7, 2010 at 11:27 AM
    takern
    Tanner
    Virginia
    ok thak you it makes more sense now. i was trying to figure out how in the world i was going to separate the shafts.
    Ok here is another question. Autozone only has half shaft in stock so is there another store that offers the lifetime warranty that i could see if they have 2 of them before getting AutoZone to special order a second one?
    Oh, and are the shafts side specific or are they universal for both sides. Thanks
  7. Oct 7, 2010 at 11:33 AM
    98tacoma27
    Ben
    Not Beech Creek
  8. Oct 7, 2010 at 11:41 AM
    takern
    Tanner
    Virginia
    Ok. thanks for the help guys. i called napa and they offer a 3 year 36000 mile warranty and they are olnly $56 per axle so i think im gonna give those a try since the autozone guy asked me if i need front or rear cv axles... Pickin them up saturday and hopefully put them on sunday assuming i dont run into any rust or stuck bolt issues
  9. Oct 7, 2010 at 7:09 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Autozone has a lifetime warranty, break or wear out they provide you replacements
  10. Oct 7, 2010 at 8:09 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    get the ones with the lifetime warranty.
  11. Oct 7, 2010 at 8:15 PM
    vicstacoma
    vicstacoma Guest
    i just replaced both of my cv axles about a month or so ago. I bought mine at Oreily's and they have lifetime warranty. I paid $65 bucks per axle and both axles for drivers side and passenger side are identical.. same part #... It's actually a pretty easy job and you should be able to get it done in about 2 hours or so.
  12. Oct 7, 2010 at 8:25 PM
    pittim
    Pennsyltucky
    Boujee Prius
    yeah doesnt seem too bad.
    fwiw, here's a step by step write up on how to change em out.
    http://www.tacomaworld.com/forum/technical-chat/21192-how-change-cv-axle-01-04-add-tacoma.html
  13. Oct 8, 2010 at 5:54 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
