Dakar Add-A-Leaf Installation?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gunn_runner, Jan 25, 2018.
  1. Jan 25, 2018 at 7:42 AM
    gunn_runner
    gunn_runner [OP] www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Looked but couldn't find a thread on installing the OME add-a-leaf on my Dakar leaf pack. Just trying to see the job before I do it.
    thanks.
  2. Jan 25, 2018 at 7:54 AM
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
  3. Jan 25, 2018 at 8:01 AM
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    Ah cool. Saw it at the end of your thread. So the leaf pack comes out and needs to be disassembled, new Add-A-Leaf goes in, and then reassembled and re-installed.
    Did you notice the ride being a lot stiffer on the rear afterwards? Does it yield the roughly 15mm of additional lift as stated?
    Thanks!
  4. Jan 25, 2018 at 8:11 AM
    magneticwhite88
    Brandon
    OC, CA
    :thumbsup: Wasn't my thread I've just read so much on suspension work I remember coming across it.
    The ride will probably be a little stiffer especially if you're bed is empty. I want to say it may lift it more than what the add a leaf calls for but I'm not positive on that...When I finish my rear end I will be going the same route, add a leaf with extended length Fox's with resis
  5. Jan 25, 2018 at 8:32 AM
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    I hear ya. After shimming my front OME with 886, I'm dangerously close to having bro lean. If I add a rear plate bumper, which I want to do soon, I'll need those AAL's.
    magneticwhite88 likes this.
  6. Jul 23, 2018 at 1:27 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Just to correct in case people use this as a reference.
    If your leaf pack is already installed and you only want to add (or remove) a leaf it doesn't have to come off the truck completely.
    Just undo the axle ubolts and lower shock mounts, take out the center pin and you can add/remove leaves
  7. Sep 16, 2018 at 10:59 AM
    BadgerBoy
    BadgerBoy Well-Known Member
    Brad
    Canton, Ga
    17' TRDORMT (Sold); 07' FJC
    https://www.tacomaworld.com/threads/my-17-tacoma-trdor-progression-most-of-it.673916/
    Doing this on my Dakar medium pack, the AAL has 3 holes and I'm not sure how it goes in. Looks like it would go between the top spring and the second. Anyone that has done this the help would be appreciated.
  8. Sep 16, 2018 at 12:48 PM
    TireFire
    Olympic Peninsula
    Holes at ends are for isolators, hole in middle for retaining bolt.
    You'll want to slide it in so you got a longer one on top and a shorter one below
    JDKred likes this.
  9. Sep 16, 2018 at 1:10 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
  10. Sep 16, 2018 at 2:48 PM
    BadgerBoy
    Brad
    Canton, Ga
    Thanks guys, I figured it out. All done
  11. Oct 9, 2018 at 11:07 AM
    WorKinJoB
    WorKinJoB Well-Known Member
    Drew
    2017 Tacoma Sport 4x4
    OME lift, 887, Dakar packs 265 70 17 duratracs Snugtop GB sport
    Did you have to buy Longer U-bolts or did the ones that come with the Dakar mediums work?
  12. Oct 9, 2018 at 11:11 AM
    BadgerBoy
    Brad
    Canton, Ga
    No need for different U-bolts
  13. Oct 9, 2018 at 11:13 AM
    WorKinJoB
    Drew
    how much did adding the HD leaf change the ride and how much lift did you get out of it? Thanks for any info.
  14. Oct 9, 2018 at 11:15 AM
    BadgerBoy
    Brad
    Canton, Ga
    sent you back a PM
  15. Oct 14, 2018 at 1:01 PM
    heffer
    heffer Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
    Can you send me this info also. Also curious to know
    boston23 likes this.
  16. Oct 15, 2018 at 1:04 PM
    BadgerBoy
    Brad
    Canton, Ga
    I was sagging with the Medium pack got about 400lbs extra out back, when I changed my front springs to 700lb ones I had the bro lean. front was about 1/2" higher than the back. With the AAL in I was back to about an inch higher in the back. The ride is still good no noticeable difference.
  17. Oct 15, 2018 at 7:35 PM
    heffer
    Jeff
    Los Angeles
    Thanks. Getting mine in this week. Dual swing out rear high clearance plus drawers and tools has been making my rear end sag a bit. Been lagging on getting this done
  18. May 18, 2019 at 8:21 PM
    JDR07
    JDR07 Well-Known Member
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    I am about to do this mod... do you guys have any tips? I plan on leaving the leaf springs mounted to the truck
  19. Jul 2, 2019 at 3:11 AM
    DrFunker
    DrFunker Well-Known Member
    Just did the AAL install last week.
    Took the packs off the truck to make it easier to work with. Glad I did it that way.
    Ride felt a little soggy over bumps before, this definitely tightened things up a bit after. I really like the ride and height now.
    Going to check DS angles once it settles a bit. Have some take off shutter, but nothing terrible.
    for reference:
    ** I am riding with an ARE shell on the bed as well. A modified leaf pack with the top OL leaf removed and squeak pucks installed on the leafs.
    ** In the front are 6112s set at the 4th notch. 2nd gen Tacoma.
  20. Aug 24, 2021 at 4:21 PM
    FW_Taco
    FW_Taco Well-Known Member
    2019 Tacoma TRD Off-road 4x4
    Do you know if the OME AAL comes with the friction pads. If not, do you need them or can it be installed on its own?
