Dakine Truck Pad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrew8404, Mar 21, 2011.
  1. Mar 21, 2011 at 8:45 AM
    andrew8404
    andrew8404 [OP] Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    I was looking into purchasing the Dakine Truck Pad to haul my mountain bike. Does anyone have experience with this pad on there 2nd Gen Tacoma? Also, what size do I get? The large or small?? I sadly don't have a tape measure to measure the tailgate width. Thanks for the help.
  2. Mar 21, 2011 at 9:11 AM
    The Yellow Dart
    The Yellow Dart Well-Known Member
    Nick
    Seattle
    07 //SR5 4x4
    OME 2.5" Lift, TC UCAs, LEER Cap, Sleeping platform, PA20-TOY
    Do you have a cap or tonneau of some kind?
    I would avoid the truck pads. Your bike still moves around on hard corners unless you bungee it down or something.
    For much cheaper, I would get a Delta bike mount that attaches to the OEM bed rails and you just set your fork on it when traveling. They're like $15.
    If you really want to go with the truck pad, though, the tailgate width is 52.9". So go from there.
  3. Mar 21, 2011 at 9:14 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I've seen those Dakine truck pads on tailgates before. What is the main purpose for them, I couldnt really figure them out?:confused:
    shift96 likes this.
  4. Mar 21, 2011 at 9:32 AM
    EVILSTI
    EVILSTI Well-Known Member
    Ray
    Catskill, NY
    1994 FZJ80 / 2022 Tacoma TRD Pro
    2022 Tacoma TRD Pro ......................................... 94 FZJ80 Land Cruiser Slee 6" lift kit 37" KM2s 17" procomp wheels Snorkel .......................................... SOLD: 06 TRD OFF ROAD OME Suspension lift kit with: Front OME 90000 shocks, 886 coils, top plate spacers, complete OME Dakar leaf spring packs, Front Diff drop kit, Rear N182 shocks, OME trim spacer, OME carrier bearing drop bushings, American Racing Chambers 16X8, Yokohama Geolandar A/T-S 285/75-16s (Winter tires), BFG MT KM2's 285/75-16, satoshi grille mod, TRD CAI, AP front bumper, AP skid plate, Cobra 75 WX ST CB, 2' Firestik antenna, Pioneer Avic-U310BT, Beefed Sliders, LR UCA's, Tinted Headlights, AP Rear bumper, DTLTH, Smittybilt XRC10 comp winch, Yellow top D35, pAP custom Transmission Skid ;-) , NFab spare tire holder, DT Pipe Bomb,
    Get the small. U could always use an old blanket or something like that. I've done that and sometimes I just use whatever I have at the time thats soft. :D
  5. Mar 21, 2011 at 9:35 AM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    The bikes still have the ability to tip over, or slide.... although your tailgate will be protected, your bike will not.
    you are better off doing this....
  6. Mar 21, 2011 at 9:44 AM
    EVILSTI
    Ray
    Catskill, NY
    ^^ Thats great if you have regular quick release and drop outs. But if you have a thru axle you will need an adapter for that to work or if you have a triple clamp setup its not going to work. Get the Dakine mat or a blanket and a bungee and you will be fine.
  7. Mar 21, 2011 at 9:46 AM
    magnew
    magnew Well-Known Member
    Ft. Collins, CO
    TRD
    I have a small Dakine pad on my truck, I love it!!!! it so much easier than taking off the front tires, I can haul 4 bikes with no problems. My 2010 enduro doesn't tip at all, my friends 5.75 tips just a bit. To solve that problem we use a bungee cord in his front wheel and secure it to the hitch. it a great pad fo sure
  8. Mar 21, 2011 at 9:47 AM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Touche!
    I mainly use mine for my road and tri bikes, which have the quick release. I don't have a hard core mountain bike....
  9. Mar 21, 2011 at 10:00 AM
    andrew8404
    ANDREW
    Albuquerque, NM
    Yeah, I have these cleats I got on eBay and they work but don't fit my bike very well and they tend to get loose so the bike rattles a lot and even fell over this week. That's why I was looking at the pad.
    TacoMD93 likes this.
  10. Mar 21, 2011 at 10:10 AM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Mine cost around $35 each I believe. My tri bike is rather pricey, so I didn't want to chance it falls around. It locks in great, and Ive even had 3 bikes loaded up for a race, and no problems at all.
  11. Mar 21, 2011 at 11:01 AM
    eachin
    eachin Well-Known Member
    Calgary Alberta Canada
    2009 Tacoma Dbl Cab Long Bed, TRD Sport
    All pro font bumper with warn m8000 winch, 4xInnovations sliders, CBI rear wraparound bumper, allpro exped leaf pack, fox 2.0 rear shocks, OME front suspension (886), some other stuff
    c/p from my post in another thread:
    A couple of things to add about the pickup pads.
    You CAN run the large version on the 2nd gen tacomas, yes, it's too big, but you're talking about 1cm over overlap on each side, this is a way better option than not covering the entire tailgate which WILL eventually result in scratches when you shake the bikes out of position on bumpy fireroads.
    Also, the dakine pickup pad is too thin, and prone to wear to the point where the padding is virtually non existent in places if you actually use it. I'd strongly recommend considering a little extra padding underneath it. I run pipe insulation over the top of the tailgate to protect the down tube on my bikes, and I put a couple of towels, or a padded moving blanket under the pad for a little extra padding to protect the tail gate.
    and yes, wash the under side of the pad, and the tailgate periodically or it will scratch your tail gate.
    It's not perfect, but it's cheap, works well, and I've fit 6 mountain bikes in the back of my old short bed, there's no other way you can possibly do that with all the wheels still on the bikes.
    Oh, and I'd consider taking the pad in at night unless you garage your truck. Mine was stolen right off the truck while it sat in front of my house, and I live in a pretty quiet/safe neighbourhood.
    A bungee cord works great for holding everything in place.
  12. Mar 21, 2011 at 12:27 PM
    Stack Knots
    Stack Knots Well-Known Member
    Dan
    Pittsburgh,PA
    2012 Tacoma Off-Road
  13. Mar 21, 2011 at 1:30 PM
    andrew8404
    ANDREW
    Albuquerque, NM
    They have the pads on Amazon for 60 bucks which is a pretty deal. I think I may bite the bullet and do it.
  14. Mar 21, 2011 at 3:45 PM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    These are great. they lock, fit perfectly for the tacoma and the C/S is outstanding..
    http://www.rockymounts.com/Locking_Clutch_p/012.htm
    For Thru Axles:
    http://www.rockymounts.com/FlyTrap_p/0150.htm
  15. Jun 16, 2011 at 11:30 AM
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    I have the Dakine Small truck pad for my 2011 quad cab tacoma, it works wonders since I ride a downhill bike and it doesnt have a quick release for the 20mm through axle. The bike fits in perfect and doesnt move at all. My road bike will probably shift slightly but i havent seen any bikes tip over to the point of sliding out of the pad. Its a quick easy way to haul bikes, and cheap.
  16. Jun 16, 2011 at 11:39 AM
    PS78
    Rancher
    2011 DCSB TRD OR
    Dakine truck pad all the way
    tallen316 and cragginshred like this.
  17. Jun 16, 2011 at 11:40 AM
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    ^^^ Nice set up and really nice bikes....
  18. Oct 9, 2012 at 6:29 PM
    ekms377
    ekms377 Well-Known Member
    DFW,TX
    '12 TRD 4X4
    Do you use the straps? Seems like a pain to fish them through the bottom. Also, do you use some type of tie down or bungee??
  19. Oct 9, 2012 at 6:34 PM
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    I have a dakine small truck pad on my 4runner and it works perfectly. 1 ratchet strap on the bikes holds them vertically on any corner.
    Highly recommend it; it is a lot more convenient than taking a rim on and off the bike.
  20. Feb 6, 2014 at 4:17 PM
    BikeRipper
    BikeRipper New Member
    Do you guys leave the pad on all the time or take it off when your not hauling bike?
