Dash Cam or GoPro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by batlou, Nov 18, 2020.
  1. Nov 18, 2020 at 6:56 AM
    batlou
    batlou [OP] Well-Known Member
    2018 Tacoma TRD Off Road
    Nothing...yet
    I am looking at adding a camera to my Truck. It has the little GoPro clip already on the windshield from the factory. Question is does anyone have a suggestion as to what to use there. I am considering a GoPro or a DashCam but don't know which.
  2. Nov 18, 2020 at 7:11 AM
    Aqualoon
    Aqualoon More stickers!
    Minnesota
    2019 Off-Road DCSB Cavalry Blue
    Skydvrr and Anton338 like this.
  3. Nov 18, 2020 at 7:33 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Dash cams are less likely to have your truck broken in and stolen for, they're also built for loop recording, long up times, and can be bought with a super capacitor for the extreme heats associated with being stuck in the windshield.
    They're also often set up to have a 2nd rear camera input which is great feature, and gps position and speed data if you care about that sort of thing.
    Dash cams are also a lot cheaper.
    I have this one:
    A129
    https://www.amazon.com/gp/aw/d/B07DL8MS1T?psc=1&ref=ppx_pop_mob_b_asin_title
    I had a ROAV/Anker one, absolutely hated it, or rather the video quality was good but I had the touch screen buttons fail on me, the battery swell up like road kill and the mandatory app you had to download and set up a VPN with was so slow and clunky and you couldn't do anything with your phone while the video was downloading couldn't import the vids to your PC had to watch them in the app wich took ages to open, the videos were encrypted and used a non standard format, speaking of format the cam kept corrupting the SD card reformating the card and anything recorded would be lost the list goes on using it was less preferable to pulling teeth out of a dumster fire abortion.
    My A129 I pull the SD card pop it in my phone or PC and boom everything is there.
    Save the Go-Pro for trail riding.
    Dash cam left ram ball under mirror for the go-pro when 'f-roadin'!
    :mudding:
  4. Nov 18, 2020 at 7:45 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    I have the same one, it's awesome. But mine mounts to the go pro mount with this
    https://www.shapeways.com/product/PJSDBHAWB/gopro-compatible-clip-to-rexing-dashcam-mount
    Just clip it in and it goes right on the GoPro mount.
    Key-Rei[QUOTED] likes this.
  5. Nov 18, 2020 at 7:51 AM
    rene2193
    rene2193 Active Member
    Rene
    1999 tacoma extended cab TRD 4wd
    I plan on ordering this one while it’s on sale. Has great reviews
  6. Nov 18, 2020 at 7:51 AM
    StPeteTaco
    StPeteTaco Well-Known Member
    TRD Sport
  7. Nov 18, 2020 at 7:54 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
  8. Nov 18, 2020 at 8:23 AM
    batlou
    Nothing...yet
    Thanks for the reply's. I was not necessarily looking for full time recording, mostly just for when I am off road. So is the GoPro the way to go if I plan to just use it for that? Did I understand that correctly?
    imjustabill1970 likes this.
  9. Nov 18, 2020 at 8:23 AM
    imjustabill1970
    imjustabill1970 Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    I'm curious if there is an adaptor for the GoPro mount to just mount a cell phone there to film some wheeling trips?
  10. Nov 18, 2020 at 8:31 AM
    LivinOnEdge
    Land of The Lost
    If you're just going to use it to wheel, the GoPro is 100% what you want.
    Key-Rei and imjustabill1970 like this.
  11. Nov 18, 2020 at 8:39 AM
    batlou
    Nothing...yet
    Thanks, I was looking at the other thread referenced and like the Garmin Mini solution. Seems simple and small. Only reason I considered the GoPro is so that I can take it in and out as needed. I also Mountain Bike and would be fun for that as well as other outdoor activities. Off Roading is new to me so I thought it might be entertaining to video some of it.
  12. Nov 18, 2020 at 8:42 AM
    LivinOnEdge
    Land of The Lost
    Use a GoPro, many more mounting options, well known and alot more universal. Whatever you do though, get the Black Version of 7 or up, 4k and image stabilizers are a must.
