Dash rings mods
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheSmash133, Oct 2, 2012.
  1. May 3, 2013 at 9:39 PM
    #201
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Wow, thanks Smash. :)
    I hate my silver rings and am going to do them flat black to make them disappear.
  2. May 9, 2013 at 9:41 PM
    #202
    tooter
    Greg
    Los Angeles
    Just did my rings flat black... :)
  3. May 11, 2013 at 9:16 AM
    #203
    MIAtaco
    MIAtaco Well-Known Member
    Brian
    Miami FL
    2010 tacoma base lifted
    2.75" front lift 2.5" rear, pro comp es3000 rear shocks w/ orange shock boots, custom exhaust, k&n cold air intake, 20" led light bar behind grill, aftermarket grill, T-rex3 eyelids, pioneer HD radio
    How did you do the tweeter rings?
  4. May 11, 2013 at 9:44 AM
    #204
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    Remove your door panel and pop them out from the back. I believe they have 2-3 plastic pieces that are melted that you need to cut, but mine literally popped right out.
  5. May 11, 2013 at 2:33 PM
    #205
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    This. And there are 3 plastic beads you can either cut off or melt and soften and may be able to reuse them when installing. Either way, I would suggest super glue or some adhesive when reinstalling them. I didn't and my driver door tweeter ring kept popping off if the door was closed too hard. Just to save you from having to take it all apart again later down the road.
  6. May 11, 2013 at 6:38 PM
    #206
    MIAtaco
    Brian
    Miami FL
    Thanks, now I'm a little nervous about it lol
  7. May 11, 2013 at 6:45 PM
    #207
    Toyota Tech31
    Debary, Florida
    No need, I pulled my door panels and literally popped my rings right off before I even realized about the 3 little plastic melted tab thingys. Not hard at all and like the Chad said, drop some super glue or maybe double sided tape and you'll be good to go for reinstallation.
  8. May 12, 2013 at 12:45 AM
    #208
    tooter
    Greg
    Los Angeles
    Silicone also works well at securely reattaching things you don't want to vibrate loose, but may want to remove cleanly at a later date. :)
  9. May 12, 2013 at 12:47 AM
    #209
    tooter
    Greg
    Los Angeles
    I used my favorite... Rustoleum high temp flat BBQ black. ;)
    It's good advice to remove the dash first and release the tabs from the back with a small screwdriver. I would have destroyed my rings trying to pry them off from the front.
  10. May 21, 2013 at 9:32 PM
    #210
    Jabe
    Jabe Active Member
    Gabe
    San Jose... Oxnard
    05 PreRunner SR5
    Blacked Out Badges, Tint, Mag-lite brackets, Ammo Box Mod
    Great write up. Did this mod this weekend. Whats the easiest way to paint the steering wheel emblem? I wanna paint that next.
  11. May 21, 2013 at 10:53 PM
    #211
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
  12. May 23, 2013 at 5:58 PM
    #212
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    did dash rings along with a/c vent trim in red
  13. May 23, 2013 at 9:10 PM
    #213
    Fiend13
    Chad
    Looks good! What color did you use?
  14. May 24, 2013 at 9:03 AM
    #214
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    rust-oleum satin red. primed them first then sprayed a few coats.
  15. Sep 29, 2013 at 2:07 PM
    #215
    mainewoodsballer
    mainewoodsballer YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
    Do you have a write up on how to do the trim around the vents?
  16. Sep 29, 2013 at 3:26 PM
    #216
    Fiend13
    Chad
    For that you basically have to remove your a/c panel, radio, and then unbolt and unsnap the surround piece out. Once out pop the vents off and tape. It's easy to do but can be time consuming.
  17. Sep 29, 2013 at 3:29 PM
    #217
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    The a/c trim is one piece, so I sprayed the red first, then once it was dry, taped off the a/c trim at the existing lines and sprayed the black. Actually have had a lot of people as if it is stock.... i say nope, did it myself :cool:
  18. Sep 29, 2013 at 3:29 PM
    #218
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    Beat me to it
  19. Sep 29, 2013 at 4:04 PM
    #219
    mainewoodsballer
    Ol' Waltah
    Maine
    Oh ok. does anyone have like a darker color that they used? Like A dark green or something? I have a pyrite mica color and wanted something close to that. id be curious to see what it looks like. Except duplicolor doesn't make my color :(
  20. Sep 29, 2013 at 4:19 PM
    #220
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    My red is a darker satin color but I've made that my accent color for the whole truck
