Defects or Issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 007Tacoma, Apr 29, 2007.
What kind of issues/defects are you having with your Tacoma?
  1. Electrical Issues (wiring, lighting, gauges, starting, battery, etc...)
    10.1%
  2. Strange Noises (clunking, whirring, popping, etc...)
    23.1%
  3. Wind Noise (excessive wind noise in the cab at any speed)
    14.1%
  4. Vibrations during Acceleration
    13.3%
  5. Vibrations during Cruising
    10.2%
  6. Vibrations during Deceleration
    7.7%
  7. Lunging or Jumping in RPMs
    14.0%
  8. Other issues (please describe in your post)
    11.6%
  9. None (I am blessed)
    34.7%
  1. Jun 19, 2009 at 8:16 PM
    #301
    Climber
    Climber Well-Known Member
    New Mexico
    09 4x4 Double CabSR-5
    Something in the rear end clunks when I release brakes or on initial acceleration (one or the other, not both). Felt more than heard.
    Transmission downshifts 2 gears after low speed cornering around town, or when going over speed bumps. Races engine, figures out it needs to upshift, does so abruptly. Can't be good for the tranny.
  2. Jun 19, 2009 at 8:19 PM
    #302
    Climber
    New Mexico
    PS I also have the lunge forward problem after a full stop. I agree, it's probably the shift to first, increases the torque to the wheels at constant engine RPM. I've learned to leave room.... Wife doesn't like it.
  3. Jun 21, 2009 at 10:58 PM
    #303
    Massy
    Massy Member
    09 PreRunner
    My truck lunges as well. It's not cool. Has anyone tried to have this fixed? What did the dealer say to shut you down?
  4. Jun 25, 2009 at 4:42 AM
    #304
    navyrt
    navyrt ROLL TIDE ROLL!!!!!!!!!
    Has any had the problem of the light on the AC/heat control panel not working when headlights are on? It just the one on left side (behind the on/off/fan speed knob). I can tap the front and it will come on, but know it takes several minutes of tapping for it come on. Any ideas on the problem or a fix?? Thanks!!!
  5. Jun 25, 2009 at 4:57 AM
    #305
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I was changing my oil last night and saw a problem. The drivers side outer CV boot is leaking grease. I could not find any visable cracks but I think the grease is coming from the edge of the metal band that holds it on. The band did not seem loose so I really don't know why it is leaking. My truck only has 10,025 miles on it. Calling the dealership this morning and setting up an appointment. I have not checked yet if there is a TSB for this problem.
  6. Jun 25, 2009 at 10:42 AM
    #306
    Jimbo
    Jimbo Well-Known Member
    North Louisiana
    07_4x4_Access Cab_V-6_Manual-6_Silver Mica
    None yet
    I had the exact same problem twice on the same side. They replaced the boot clamp the first time around and in two weeks the metal band came loose again! I took it back in and they ordered the whole boot kit replacement package. They cleaned it up and installed it and I haven't had another problem out of it for many months. Strange that I had that happen since I never had much off-roading at all that could have caused a problem. I would think things should be alot tougher that that under a Taco and not have problems? Good luck.
    By the way, that happened on my truck at around maybe 20,000. I got 31,500 now.
  7. Jun 25, 2009 at 11:56 AM
    #307
    hillbillynwv
    Fairmont, WV
    I drop off my truck tonight after work. Service manager said it's all under warranty and bring it in. Hopefully they will fix it right the first time.
  8. Jun 25, 2009 at 12:22 PM
    #308
    Jimbo
    North Louisiana
    None yet
    They probably will it the first time. For some reason just changing the metal band that failed didn't do it the first time on mine. Maybe just a fluke. Service Manager said this doesn't happen often and I hope he was truthful.
    I'll be out of warranty soon, so I had the suspension TSB done and a few minor things since I've had it. It's been a good truck. Only thing they couldn't fix is an annoying clutch pedal bushing squeak that gets worse the hotter the interior of my truck gets (I could take it in on a hot day and get it done, but its a pain setting it all up). I think I can fix that though. I also get an annoying A/C fan ticking or squeaking, but I pulled it out and found out what it was and fixed it for the most part.
    The best thing I ever followed through on was getting that TSB for suspension replacement done. My truck handle way better although a bit stiffer ride and has better load capacity. I do recommend it though.
  9. Jun 26, 2009 at 12:27 PM
    #309
    hillbillynwv
    Fairmont, WV
    Just called the dealership and they said my truck was fixed. I asked what was wrong with the CV boot and they said it had a faulty band. They replaced it, hopefully it's fixed but time will tell.
  10. Jun 29, 2009 at 5:00 AM
    #310
    hillbillynwv
    Fairmont, WV
    Picked up truck Friday, the new band dislodged and was flopping on the boot when I looked at it Sunday morning. I dropped it back off at the dealership last night. My local dealership "never" fixes things right the first time.
  11. Jun 29, 2009 at 7:15 AM
    #311
    Jimbo
    North Louisiana
    None yet
    Man, sorry to hear that happened to you too. They didn't fix mine right the first time either. Like I said earlier they just tried to put another band on the boot the first time. I don't know why that didn't work? Mine has been good since the boot kit replacement. Seems there are some faulty boot band suppliers out there causing the problems?
  12. Jun 29, 2009 at 9:19 AM
    #312
    hillbillynwv
    Fairmont, WV
    Just talked to the dealership, they've ordered a boot kit and it will be in tomorrow. Looks like my truck is getting fixed in the order same as yours. I had a feeling replacing the band wasn't going to fix the problem.
  13. Jul 2, 2009 at 7:18 AM
    #313
    hillbillynwv
    Fairmont, WV
    Another CV boot disaster update.....the mechanic didn't like the band that came with the boot kit, he ordered another different type. It came in and he installed it. He test drove it and it fell off. They ordered a brand new half shaft for it and it should be in and installed today. I dropped my truck off Sunday night and today is Thursday and hopefully I will get it back today. What a fiasco over one band! For my inconvience, they put a exhaust tip on for me that I asked for. I should had asked for the TRD skid plate instead.
  14. Jul 11, 2009 at 3:09 PM
    #314
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    1) 2009
    2) 2.7l
    3) 4x4
    4) Access Cab
    5) SR5 Package
    6) After longer highway trips (1hour plus) the clutch chatters sometimes when idling. I push in the clutch pedal and it goes away. I've heard the 2009's are having problems with the clutches and i'm getting kind of nervous about it. I'm gunna have the dealer take a look at it when it goes in for its first oil change in 2weeks... they probably won't find anything wrong:frusty:
    can't say i've had the windshield or bed noise though... weird
  15. Jul 11, 2009 at 5:14 PM
    #315
    jiles111
    jiles111 Well-Known Member
    Abilene, TX
    09 RegCab 4x4 Super White
    About #6. Try this.. Turn your AC off and the clatter disappears. I have no idea how it is related. When the AC is on and with the clutch is out you will hear clatter. Push the clutch in and the noise goes away. Turn the AC off and that noise goes away completely. Weird huh :eek:
  16. Jul 11, 2009 at 5:20 PM
    #316
    ttylerr
    Tyler
    09 MGM 4Banger 4x4
    hmm, i cant see how the a/c compressor would effect the clutch that way... sounds more like a pilot bearing... but it doesnt do it all the time
  17. Jul 11, 2009 at 5:49 PM
    #317
    jiles111
    Abilene, TX
    Did you try it yet?
  18. Jul 13, 2009 at 1:06 PM
    #318
    MicahsTaco
    MicahsTaco Member
    Micah
    Edwards, Colorado
    06 TRD Sport Red
    3" Lift,TRD Cold Air Intake, 20"x10" XD Rockstars, Nitto Terra Grappler Tires
    1) 2007
    2) V6
    3) 4WD/Traction Control
    4) DoubleCabShortbed)
    5) TRD Sport
    6) My issues are minor but annoying. 1. When dome light set to door the light frequently doesn't work unless I force the switch further towards "Door" (necessary almost every time I get in vehicle). 2. Overhead Temp Gauge/Compass recently stopped working. 3. Rattle sound coming from rear driver side when turning left. 4. Tire Pressure Warning Light always on.
  19. Jul 13, 2009 at 1:16 PM
    #319
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    you can fix the temperature guage with a quick and easy solder fix, there will be a couple solder connections that have cracked from the bumps over time, I took mine off, took it inside, soldered it, and put it back in all in less than 20 minutes and it now works :)
  20. Jul 13, 2009 at 1:22 PM
    #320
    MicahsTaco
    MicahsTaco Member
    Micah
    Edwards, Colorado
    06 TRD Sport Red
    Here is a link to the Overhead Console Fix:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/18497-overhead-console-fix.html
