Definitive lube how to
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thillman, May 14, 2017.
  1. May 14, 2017 at 8:01 PM
    Thillman
    Thillman [OP] Well-Known Member
    '12 Tacoma TRD Off-Road
    this isn't a how to.ill probably get some blasting for this but I'm wondering/requesting after some empty search results if there is anything out there on the greasing of zerks and joints as is recommended every 30k for those of us doing all our own maintenance.
    I could crawl under my truck and just start greasing but I have no idea what the standard procedure is for 2nd gens on the driveshaft, suspension etc. 2012s for me. The thought has started to bug me the more I'm hearing my suspension squeak
  2. May 14, 2017 at 8:08 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I grease all mine with every oil change. U-joints get as many pumps as it takes to get clean grease coming out of all 4 caps. At that time I also do a 5 tire rotation.
    scottalot and DrFunker like this.
  3. May 14, 2017 at 8:28 PM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    Good post.
    Thanks windsor, good to know.
  4. May 14, 2017 at 8:28 PM
    UncommonLife
    UncommonLife Well-Known Member
    Alan
    Salida, CO
    2009 TRD Sport DCSB
    ^^^Best advice you'll get
  5. May 15, 2017 at 1:26 PM
    Thillman
    Can anybody point out the location and how many of the zerks
  6. May 15, 2017 at 1:29 PM
    DrFunker
    DrFunker Well-Known Member
  7. May 15, 2017 at 3:29 PM
    Thillman
  8. May 22, 2017 at 5:49 AM
    Thillman
    I was under the truck this weekend, and could not for the life of me find any zerks, do the newer models have them?
    winguyen likes this.
  9. May 22, 2017 at 6:03 AM
    Pigpen
    Dan
    Northwest Montana
    I do the rear at about 2500 miles. Front gets greased with oil change at 5k.
  10. May 22, 2017 at 6:05 AM
    winguyen
    winguyen Well-Known Member
    Kevin
    Watertown, MA
    2014 Pyrite-Mica DCSB TRD Off-Road
    My 2014 does not have any zerks
  11. May 22, 2017 at 6:33 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Certain models don't have zerks. Are your trucks 2wd? I'm almost certain the 4wds have zerks. Also, the link above that shows the zerks is not the same across the models that have zerks.
  12. May 22, 2017 at 6:38 AM
    winguyen
    Kevin
    Watertown, MA
    I have a 4wd and no zerks. When my buddy had it up on the alignment rack we looked for them but there were none. I had my drive shaft replaced under warranty last year for some vibes and the one they put on doesn't have zerks. I bought the truck used and never got around to checking the original driveshaft for zerks so I'm not sure if I had them to begin with.
  13. May 22, 2017 at 8:36 AM
    Thillman
    So no grease needed for these models I guess
    Reminds me of the sealed transmission unit with "lifetime fluid"
  14. May 22, 2017 at 8:38 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Something sounds off.
  15. May 22, 2017 at 4:06 PM
    moondeath
    Pa, Gardners
    Before my sport, I had an off-road. It definitely had zerks. Are you checking in the right spots. This is where they are on my sport.
    https://www.tacomaworld.com/threads/drive-shaft-lube-points-2nd-gen-4wd.225161
    Just noticed you said original drive shaft. If that's a different shaft, then that's probably it. Like I said, almost certain 4wd models have the zerks on the oem equipment.
  16. May 22, 2017 at 4:16 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    In for the lube title. Disappointed.
    EatSleepTacos and scottalot like this.
  17. May 22, 2017 at 4:27 PM
    moondeath
    Pa, Gardners
  18. May 22, 2017 at 5:03 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Since I keep it lubed with fresh stuff, I use grease from Walmart. No need to spend extra money for stuff that gets thrown away every 3K miles (yes, I use the old school timeframe).
    scottalot[QUOTED] likes this.
  19. May 22, 2017 at 5:03 PM
    winguyen
    Kevin
    Watertown, MA
    It was replaced by the dealer with an OEM shaft. I was physically standing under the truck with my buddy who also owns a Tacoma and has greased the driveshaft on his truck, we didn't see any zerks.
  20. May 22, 2017 at 5:29 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    The only grease I have ever used that didnt come from Walmart is Lucas which I use for the front wheel bearings on my '40.
    scottalot likes this.
