Defrosting mirrors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Icebrg123, Oct 22, 2020.
  1. Oct 22, 2020 at 8:14 PM
    Icebrg123
    Icebrg123 [OP] Active Member
    New england
    2014 quad cab 4x4 base model
    Would i need a switch to operate the defrost feature if i were to swap my base model mirrors out?
    Mirrors are consistently fogged in the morning, Living in the North East.
  2. Oct 22, 2020 at 8:19 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  3. Oct 23, 2020 at 12:21 AM
    TeXanTRD
    TeXanTRD Well-Known Member
    2013 TX TRD
    If you search for heated mirrors on here, you’ll find a thread where a guy throws together kits using the Highlander OEM mirrors, various switch types of your choosing, and all the wiring you’ll need.
  4. Oct 25, 2020 at 2:52 PM
    Icebrg123
    New england
    Thanks man!
  5. Oct 25, 2020 at 3:00 PM
    jibski
    jibski Well-Known Member
    Josh
    Arvada, CO
    2009 Silver 2.7 AC 4X4
  6. Oct 25, 2020 at 4:21 PM
    TeXanTRD
    2013 TX TRD
  7. Oct 25, 2020 at 4:28 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    I used similar heater pads as the one mentioned above. I also found a time delay relay from Wolstentech to control the time the heater pads are turned on. Total parts cost was about $100; bench testing and install time was about 20 hours.
  8. Oct 25, 2020 at 4:35 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Where in NE?
  9. Oct 25, 2020 at 4:46 PM
    jibski
    Josh
    Arvada, CO
    Yeah disassemble to adhere and run wires.
    road2cycle I’ve been wanting to put a delay on mine for when I forget to turn them off. Thanks for the reminder. Do you remember where you got yours?
  10. Oct 25, 2020 at 5:20 PM
    road2cycle
    Sonoma County, CA
  11. Oct 25, 2020 at 5:23 PM
    Icebrg123
    New england
    Super cheap! I’ll be making this purchase asap. Thanks!
  12. Oct 25, 2020 at 5:24 PM
    TacoTuesday1
    FL
  13. Oct 25, 2020 at 6:39 PM
    ABA180
    East Bridgewater MA
    I'm sure it wasn't 20 hours, so am I thinking 20 minutes or 2 hours?
  14. Oct 25, 2020 at 6:50 PM
    TeXanTRD
    2013 TX TRD
    Eh, I’d believe it. It’s a decent amount of wire to run. Every time I tear my dash apart it ends up taking longer to do whatever that I plan for.
  15. Oct 25, 2020 at 6:57 PM
    jibski
    Josh
    Arvada, CO
    Depending on how involved his bench testing was. But no, just install on these could be done in 4 hours or less I’d say.
  16. Oct 25, 2020 at 7:45 PM
    road2cycle
    Sonoma County, CA
    There are a bunch of steps involved in completing this mod since lots of items need to be disassembled, modified, and reassembled. You’d probably be surprised once you get started.
    How long it takes to complete the job depends on how meticulous you are. I believe in taking it slow and doing the job right the first time. I definitely could have cut corners and shaved some time off the install, but I would not have been satisfied with the quality of the install.
    tasnowma and TeXanTRD like this.
  17. Oct 25, 2020 at 8:05 PM
    ABA180
    East Bridgewater MA
    Absolutely, do it right and you don't have to do it again. Not something I've thought about in this particular case but I get in general the surprises that come up, especially with you coming up with the process.
  18. Oct 25, 2020 at 8:27 PM
    road2cycle
    Sonoma County, CA
    I can’t take all the credit for coming up with the process. There were a few really good threads on this forum that I referenced to get a general idea of what needed to be done. But of course there were some unanticipated hiccups along the way.
