Delete
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ace7196, Jan 16, 2018.
  1. Jan 16, 2018 at 7:39 AM
    ace7196
    ace7196 [OP] Member
    Delete
    Mtn Mike likes this.
  2. Jan 16, 2018 at 8:01 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I've done nothing, but I've got a fiberglass shell and a few totes in the back.... Should be about 300. I've done nothing. Don't seem to have issues.
  3. Jan 16, 2018 at 8:21 AM
    MSCOFF
    MSCOFF Well-Known Member
    Mark
    CT
    2017 SR5 AC 4WD
    I put Helwig EZ550 set to keep the rear at the original height after I put a Leer cap on.
    TRD-OffRoad_Ben and Mtn Mike like this.
  4. Jan 16, 2018 at 8:31 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    Sumosprings here. No real negatives.
    arnette64 likes this.
  5. Jan 16, 2018 at 8:36 AM
    phsycle
    phsycle Well-Known Member
    CA
    On my old Tacoma, I had a Leer cap. After 8-9 years, the spring began to sag pretty bad. For the first few years, it seemed to be ok. But I wasn't carrying anything heavy back there, either. If I were to get another cap, I would get some helper springs.
  6. Jan 16, 2018 at 10:11 AM
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    Can you show a picture of the 550s installed? Hellwig states that interference with the leaf keeper is likely and ultimately doesn't recommend it. Curious to see your install.
  7. Jan 16, 2018 at 10:11 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i was hauling tile and thinset, total about 500lb, the springs were arced up and the rear was hitting the bump stops when i went over bumps. i will follow this thread as i need to do something too.
  8. Jan 16, 2018 at 10:40 AM
    Lt. Dangle
    Ohio
    Second ones.
  9. Jan 16, 2018 at 10:41 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    Firestone ride rites on mine. I have a roof top tent and bed bars that are about 200lbs. I have had 750lbs of shingles in the bed and couldn’t tell it was there with the air bags pumped up to about 30psi
  10. Jan 16, 2018 at 10:42 AM
    anonymouscuban
    anonymouscuban Well-Known Member
    Alex
    Porter Ranch
    2017 MGM Off Road Double Cab Shortbox
    It's how I like my women. o_O
  11. Jan 16, 2018 at 10:44 AM
    wedgefry
    wedgefry Active Member
    Jordon
    Vancouver, Canada
    2017 Tacoma TRD Off Road DCSB
    I have a constant load of roughly 500lbs give or take. I've got wood storage drawers and a hard shell cap. I added bed stiffeners and sumosprings to alleviate the weight. Seems to be working out well!
    ace7196[OP] likes this.
  12. Jan 16, 2018 at 10:50 AM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    Im with this guy and his cute puppy. I have a Leer 100XR, full drawer system and a prinsu rack. Sumo Springs do the trick for now. I'll do a full leaf pack this year when I lift.
    Sitting level with all of the above plus a RTIC 65 stuffed to the brim + other camping gear.
    anonymouscuban and ace7196[OP] like this.
  13. Jan 16, 2018 at 11:44 AM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    thanks for the pic. how hard to install? do you fill air with air hose or do you have on board compressor? last where did you get them?
  14. Jan 16, 2018 at 11:57 AM
    wedgefry
    Jordon
    Vancouver, Canada
    sumosprings take roughly 10 mins to do on each side.
    take off the tires, loosen the ubolt's remove oem bump stop and put in sumosprings. tighten ubolts and bolt the tires and you're good. sumosprings are sort of a composite foam material, they don't require any air.
    upTOPOverland_Drew likes this.
  15. Jan 17, 2018 at 9:48 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    I am considering Sumos but i have not pulled the trigger yet. Previous trucks I always ran air bags... I haven't found much feedback on the 612s yet. Here is what Sumo said regarding 610 vs 612 on the 3rd gen.
  16. Jan 21, 2018 at 1:01 PM
    Toms 17
    Toms 17 Well-Known Mumbler
    Tom
    Central Ohio
    17 MGM DCSB TRD Sport
    I have also read all the past threads and posts on these Sumo's and have decided to still go with and order the larger (610-40) springs.
  17. Jan 26, 2018 at 6:53 AM
    arnette64
    arnette64 Well-Known Member
    Amos, QC (Canada)
    2016 Inferno TRD Sport Double Cab 4X4
    '16 Inferno TRD sport DC
  18. Jan 26, 2018 at 6:57 AM
    arnette64
    Amos, QC (Canada)
    You can do it without removing the wheels/tires
  19. Jan 26, 2018 at 6:59 AM
    arnette64
    Amos, QC (Canada)
  20. Jan 26, 2018 at 7:13 AM
    Lt. Dangle
    Ohio
    You can feel them.
