diff fluid change questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scottyballz, Feb 26, 2018.
  1. Feb 26, 2018 at 2:49 PM
    scottyballz
    scottyballz [OP] Member
    2015 Tacoma TRD Sport
    Hey everyone,
    Im gonna do my front rear and transfer case fluids on my 2015 TRD sport asap and just wanna make sure i have everything I need.
    do I need LS Diff additiive in my rear diff?
    rear:
    24mm socket, drain and fill torqued to 36 ft/lbs
    3 quarts 75w-90 gear oil
    4 oz LSD additive?
    Front:
    10mm Hex socket, fill torqued to 29 ft/lbs drain to 48 ft/lbs
    1.6 quarts 75w90
    hand pump
    Transfer case:
    24 mm socket, fill and drain torqued to 27 ft/lbs? seems low
    1.1 quarts 75w90
    I got all of this info from a previous thread, just want to make sure nothing has changed on the 15' and if I need the LSD additive in the rear. Thanks in advance.
    REDdawn6 likes this.
  2. Feb 26, 2018 at 2:56 PM
    devkurf
    devkurf Member at Large
    midwest
    You wont need any LSD additive, 09 and up they switched to brake actuated limited slip
  3. Feb 26, 2018 at 3:07 PM
    devkurf
    midwest
    Rick_Taco likes this.
  4. Feb 26, 2018 at 6:57 PM
    Fury
    Fury Well-Known Member
    Just did mine for the second time last weekend.
    Transfer has aluminum gaskets - perhaps the reason for 27.
    Get new gaskets for the 3 drain plugs - torque them before re-filling - cheap insurance against leaks.
    scottyballz [OP] likes this.
  5. Feb 26, 2018 at 8:26 PM
    Markcal
    Markcal Well-Known Member
    One thing I forgot to do that I will do next time is taking it for a drive before replacing the fluids and also use the 4x4 too.
    N919HJ and Rick_Taco like this.
  6. Feb 27, 2018 at 12:28 AM
    scottyballz
    Thanks for all the advice everyone, I appreciate the help!
    Markcal likes this.
  7. Feb 27, 2018 at 10:30 AM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 88K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18 Mods to Buy Short Term: Ultimate Headlight Upgrade Ultimate Fog light Upgrade Wheelers Bump Stops On Board Compressor Mods to Buy Long Term: Billys and 885's OME leafs & Billys
    I've got this on the short list as well, 1) for peace of mind 2) I can afford it and I’ll feel accomplished.
    Question: GL-5 correct?
  8. Feb 27, 2018 at 10:32 AM
    EatSleepTacos
    Randy
    Hampton Roads, VA
    4x4 2005 SR5 AC 6MT
  9. Feb 27, 2018 at 11:10 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    OP. Thanks for the info. Pics would have been sweet too, of the bolt locations. The other threads dont show pics on my PC. Jut a thought , for other members...
  10. Feb 27, 2018 at 12:32 PM
    Rick_Taco
    Rick
    Indiana
    Your first link seems to point back to this thread. Ive tried to search the front diff and transfer case myself but can't seem to find the one you are talking about. Thanks!!
  11. Feb 27, 2018 at 12:39 PM
    YoterHead
    YoterHead Well-Known Member
    I did this one on my own a couple of years ago ( front/rear diffs, not transfer case). Wouldn't do it again simply due to the nasty smell of that diff oil. It lingered in my garage for months, it seemed like.
  12. Feb 27, 2018 at 12:40 PM
    EatSleepTacos
    Randy
    Hampton Roads, VA
    4x4 2005 SR5 AC 6MT
  13. Feb 27, 2018 at 12:47 PM
    Rick_Taco
    Rick
    Indiana
    EatSleepTacos likes this.
  14. Feb 27, 2018 at 1:17 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Maybe you don't want to do this, but I don't bother removing the front diff drain plug anymore (I hate those ridiculous 10mm Allens, always get rounded a bit). Those Allens have caused a lot of cursing over the years. I use a transfer pump to get the old oil out via the fill plug, you'll be able to get the hose to the bottom of the diff and get the old oil out. IIRC, the front diff drain plug is non-magnetic so there's nothing to clean off of it.
    You can replace the front diff fill plug with a 24mm hex from the transfer case, same length, same thread pitch. About $3 from the dealer.
    The 24mm's I use a 6-point socket, and put Amsoil 100k mile Severe gear oil in. Of course, fill plugs out first. Have fun and enjoy the stench!
    devkurf likes this.
  15. Feb 27, 2018 at 1:32 PM
    tacoloco83
    tacoloco83 Well-Known Member
    Justin
    2005 Tacoma TRD Off-Road
    Hey guys, changing my rear diff. I forgot my third bottle of 75-90. Will it be okay til I get to the parts store?
  16. Feb 27, 2018 at 1:39 PM
    EatSleepTacos
    Randy
    Hampton Roads, VA
    4x4 2005 SR5 AC 6MT
    Yikes, you'd only be running on 2/3 capacity, which is pretty low IMO. I wouldn't risk it, personally. Could always drain new stuff out, put old stuff back in, drive to parts store, and then do some more swapping to get all new fluid in.
  17. Feb 27, 2018 at 1:57 PM
    blu92in99
    blu92in99 I hate everyone, equally
    Justin
    Elk Grove, CA
    2005 Tacoma AC 4WD, TRD-OR
    Ask me...
    How far away is the parts store?
  18. Feb 27, 2018 at 3:44 PM
    scottyballz
    everything went smooth today with the fluid change. I was only able to get about 2.7 its into the rear then it started to overflow. I closed the plug up and went and did the transfer case and the front diff to see if the fluid would disperse into the axle a little more, but when I cracked it open about 20 min later it was still flowing out so I figured thats all it wants. Thanks for all the advice with everything! I'm gonna do the manual transmission fluid next. I hear Redline MT-90 is the way to go.
    Rick_Taco and EatSleepTacos like this.
  19. Feb 27, 2018 at 4:48 PM
    devkurf
    midwest
    Sorry about that, I have the link edited to jump to the right page.
  20. Feb 27, 2018 at 7:12 PM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    The front diff drain plug on my '05 is magnetic.
