disable tpms?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Leggo, Mar 4, 2011.
  1. Mar 4, 2011 at 9:16 AM
    Leggo
    Leggo [OP] slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Anyone know if it can be done as a mod to my 2010? I don't want to do the tpms in a can trick. I was hoping I could cut a wire or ground a wire somewhere.
  2. Mar 4, 2011 at 9:19 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    I just pulled the cluster apart and took the led out for it.
  3. Mar 4, 2011 at 9:38 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Use the search function. It will have all the answers! :)
  4. Mar 4, 2011 at 9:47 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    search for pipe bomb mod
  5. Mar 4, 2011 at 9:56 AM
    Leggo
    Newton,Ma.
  6. Mar 4, 2011 at 10:07 AM
    2010Tacoma4x4
    2010Tacoma4x4 "Man Ho"
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Tinted windows, Bug deflector, Rain guards, Bed mat, Rear leaf TSB, Bilsteins front & rear (front set @ 1.75), 16x8 chrome Helo wheels, Toyo open country AT P265/75/R16 tires. CBI bolt on sliders. BSP color matched M1 Satoshi grill. BHLM. UWS low profile black powder coat crosover truckbox. Pioneer DVD/CD head unit - 4 channel amp - front mids & highs - 8" sub box.
    Make sure you read that whole thread in the link posted. The bypass procedure explained in the first post will not work for the 2010. If you read on into the thread there are some other options that will work:cool:
  7. Mar 4, 2011 at 10:42 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Also nice is choosing a way that keeps the system functional for monitoring the spare. I hate having to check air in that thing.
  8. Mar 4, 2011 at 6:46 PM
    Leggo
    Newton,Ma.
    ok now I am confused again. I went and checked the entire thread and did not see anything about 2010 or what would work for that year. Can you clear this up?
  9. Mar 4, 2011 at 6:48 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    it saved me and my tire yesterday....stupid ass stock valve stem caps
  10. Mar 4, 2011 at 6:56 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
  11. Mar 4, 2011 at 7:06 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    X2
  12. Mar 6, 2011 at 7:25 PM
    Leggo
    Newton,Ma.
    ok Now I get it.
    (As you know TPMS disable mod doesn't work on 2007 and up so here is solution instead of grounding blue wire on IJ1 connector you need to put +12V and done - light is off. It draws 6.7 mA only so put fuse 25-50mA to be on safe side.)
