DIY: Gen 2 Illuminated 4wd switch
Discussion in 'Technical Chat' started by maverick491, Oct 31, 2007.
  1. Feb 6, 2017 at 8:53 PM
    #61
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I tried at the Hvac tap but essentially yes
  2. Feb 8, 2017 at 10:55 PM
    #62
    nudavinci64
    Robert
    In the end it was determined the switch is DOA in terms of lighting up. Returning it for replacement.
    For now I have the HVAC plugged back in with no 4x4 switch for now, but have it in case I need it. The problem I am seeing now is my whole HVAC unit is really dim now. Not as right as before I hacked it all up. When I was testing the Helux switch with a battery I did test the HVAC and it lit up super bright so I know the LEDs are still in tact. Any thought was would be shorting the HVAC of its power. Seems as though its not getting enough juice. The dimmer works but again its light.
  3. Dec 10, 2017 at 12:27 PM
    #63
    Michael_Westen
    Michael_Westen Well-Known Member
    NC
    2018 Tacoma Double Cab TRD Off Road Inferno
    I have a 2015 Tacoma TRD and would like to add the light mod to my 4wd switch but would like to know if the 4Runner 4wd switch 84724-35020 & terminal leads 82998-12420 will work and are the best if not only way to go? I saw a post about a LED board but they guys says they will only fit 2005 -2011.
  4. Dec 10, 2017 at 8:29 PM
    #64
    nudavinci64
    Robert
    4 runner is plug and play but a bit ugly. The Helux switch and ring a member makes looks 1000x better. No way to mod the existing switch.
  5. Dec 11, 2017 at 8:05 AM
    #65
    Michael_Westen
    NC
    Would this black out 4wd switch be able to be illuminated 84724-04030?
  6. Dec 11, 2017 at 8:14 AM
    #66
    Muffdiver
    Muffdiver Growing old is mandatory, growing up is optional
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
    Negative. You either have to use the 4Runner switch or the Hilux switch previously mentioned.
  7. Dec 18, 2018 at 8:06 AM
    #67
    DanvilleTrain
    DanvilleTrain Well-Known Member
    Edward LongMember
    2015 Tacoma
    I am getting ready to do this to my 2015 DCSB and was wondering why OP doesn't clearly say he used the lighted 4WD switch to replace the non lighted switch at the end. IOW, to make this mod make sense, we would have to cannibalize the lighted switch knob from the new 4 Runner switch and install it in the non lighted Tacoma switch receptacle after making the mods to the bulb housing and wiring. It's not clear from his OP if the original OEM knob is used or discarded. But it seems to make sense to me that the original knob is discarded and replaced with the 4 runner switch indicator.
  8. Dec 18, 2018 at 9:08 AM
    #68
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    To anyone who wants to do this but doenst want to spend $60 on a switch for just the bulb go here and search for the following part #s from what i saw these are correct.
    https://parts.toyotaofdallas.com/
    82998-12420 youll need 2
    90010-01084 this is the bulb
  9. Dec 19, 2018 at 2:45 PM
    #69
    Muffdiver
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
    The original is discarded and replaced with the 4runner switch. I have the 4runner switch and some wire leads to do this, but i sold my truck before i was able to install. PM me your info and i'll mail them to you for free.
  10. Aug 2, 2019 at 8:43 PM
    #70
    DanvilleTrain
    Edward LongMember
    2015 Tacoma
    I successfully installed the 4 Runner switch in my USA 2015 DCSB today. It was plug and play. No mods were required to change from the OEM Tacoma non lighted switch to the 4 Runner lighted switch. The 4 Runner Switch just snapped into place perfectly. I did add the two wires to the OEM Tacoma 4WD switch harness (OEM on mine had 3 wires, after adding the two illum wires the connector was filled with 5 wires which is max) for the illumination power but was unable to find out which HVAC wires I was supposed to tap into. I would appreciate someone updating this thread with the correct power tap wires from the 2015 Tacoma HVAC switch to identify which of those wires provide the power to the 4 runner bulb.
    TheDevilYouLove likes this.
  11. Aug 6, 2019 at 9:06 AM
    #71
    DanvilleTrain
    Edward LongMember
    2015 Tacoma
  12. Jan 9, 2020 at 12:31 AM
    #72
    aktaco12
    aktaco12 Well-Known Member
    AK
    2012 4x4 DCLB TRD Sport
    Nice straight forward mod but looks much better with the black taco knob.
    jkuniverse and TheDevilYouLove like this.
  13. Jan 12, 2020 at 8:12 AM
    #73
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    is there a write up on I stalling that switch? Is it plug and play on a 2010?
  14. Jan 12, 2020 at 6:32 PM
    #74
    aktaco12
    AK
    No. Only 2011.2-2015 can use the 4Runner plug&play, but still have to add wires for the light.
    If you want to use the 4Runner switch on a pre 2011.2, see post #21.
    To illuminate your stock switch, go back to post #1 or buy a DIY kit HERE.
  15. Mar 31, 2020 at 4:40 PM
    #75
    97duc748
    97duc748 Well-Known Member
    07 Tacoma
    Snugtop, lift, Prinsu Rack and lead foot.
    DIY kit link did not work. I would like to do this on a 2007. I have already tapped the LED light section for 5 other switches. What year 4R switches can be cannibalized? What LED part numbers can be used in the new housing? Is there room in the stock plug to add two additional leads for a plug in?
  16. Apr 17, 2020 at 2:37 AM
    #76
    aktaco12
    AK
  17. Nov 10, 2020 at 4:19 PM
    #77
    massaker
    massaker New Member
    Michael
    2015 Silver Sky Tacoma TRD
    Did you ever figure this out? Mine is dim also after the mod.
  18. Jan 31, 2022 at 4:40 AM
    #78
    DellGriffith
    DellGriffith New Member
    Bumping a very old thread but just wanted to thank everyone who contributed to this thread. I was able to find a older T4R switch via eBay ($50) and bought the pins needed here (for the existing 4wd switch connector) via Eastern Beaver...The switch fits into the plastics for a 2015 (which I swapped into my 09) and illuminates now!
    Probably not many folks fixing up/investing in '09 Taco's nowadays but I am until the market calms down.
    #78
    ramonortiz55 and CowboyTaco like this.
  19. Apr 4, 2022 at 5:54 PM
    #79
    CuriousMonkey
    CuriousMonkey Member
    2008 Tacoma 4x4
    Ok…so I did exactly what you did and everything lights up. However, a ball bearing fell out of my switch housing and I don’t know where it goes and my switch knob is looser than before. Also, when I put the truck onto 4wd low a chime keeps going off and doesn’t turn off unless I take it out of low. Also the circuit board has a red and white wire coming out of it, but you didn’t specify which wire goes to green and which wire goes to green striped. Baffled here. Help?
  20. Apr 5, 2022 at 4:35 AM
    #80
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Did you shift into Neutral before switching to 4Lo? That chime means that you aren't in the selected mode, and usually means that you didn't shift to N before the switch.
    My guess is that the switch is still functioning properly or it wouldn't know that you were in that mode.
    Also, my switch hasn't illuminated in years. This was a wasted mod for me.
