DIY LCA Cam replacement 2005+ Tacoma
Discussion in 'Suspension' started by XXXX, May 14, 2012.
  1. Mar 22, 2013 at 5:01 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    26mm for the larger cam
  2. Mar 25, 2013 at 7:27 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Haha, must have missed it
  3. Apr 17, 2013 at 10:37 PM
    skygear
    skygear                    
    Really? It is a 26MM bolt for the cam? Sears don't gots dat!
  4. Apr 18, 2013 at 8:45 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    They have them in a set in store, but individually, you have to buy online and ship to store.
  5. Apr 18, 2013 at 10:22 AM
    skygear
    skygear                    
    Yeah, I found one online n ordered it. Pain in the ass that there isn't a Craftsman store. I'd go to it all the time. Sears don't cut it for me.
  6. Jun 29, 2013 at 9:54 PM
    Taco'09
    Taco'09 Well-Known Member
    One of mine was totally seized and another nearly so at only eight months following the build date. Both were fronts.
    One note that may be of interest to those with this problem. The rear cam bolts on both arms have a slit in them that goes lengthwise and its opening is accessed at the rear next to the hex. I found that a #16 or #18 flat-tipped hypodermic needle will go in a long way. A home-brew of 50:50 acetone and atf can be injected in there. I've done this a number of times and it will seep out both sides of the rear cam bolts and help loosen them. May have to do it for several days.
    This is for those trying to free the rear bolts, not a maintenance item as I believe the Cole-Parmer chemical compatibility charts show that the acetone, and possibly the atf, may be destructive to the rubber bushing.
  7. Oct 1, 2013 at 2:38 PM
    PATACO13
    PATACO13 Well-Known Member
    Ian
    Erie, PA
    '03 V6 TRD 4x4
    stock
    Quick question on old thread. I've installed 5100's in the front and prior to getting an alignment, my shop warned me about the tendency of cam bolts to seize in LCA bushings. After plenty of research on TW, I've been soaking with PB Blaster for a week or so.
    My question is: If they are seized up, will the cam tabs be bent? Or rather, can the cam bolts be seized up without bending the tabs? My tabs are all perfectly straight. I know this thread is for 2nd Gen but I drive an 03.
    Thanks
  8. Oct 2, 2013 at 7:56 AM
    Taco'09
    ^^^ Better: home brew of 50:50 acetone:atf. This came from a well known study done a few years back by Practical Machinist on a bunch of off-the-shelf products and the home brew. The home brew was better by a long shot. BTW, PB Blaster scored bad in the test.
    Shake, shake shake before putting on and put it liberally on both sides of the cam bolts. Note that the rear cam bolts have a slot in them that runs a good way the length of the bolt (on 2nd Gens at least). Clean out if dirty but take a large syringe and 14 gauge needle and you can inject your stuff a long back along the rear bolts.
    That is exactly how bent my right front cam tabs. Make sure you counter-hold the other side of the bolt -- preferably wedged tight against something.
    If you get desperate get out the sawsall and cut the bolt off. Go to the big box store, or a decent contractor's place like Grainger, and get a pack of these blades: Lenox Gold, Bi-Metal, Part No.614G, 14TPI, 6". That cam bolt is super-hard and just laughs at all the other brands of blades. The Lenox one was the only blade I could find that would cut through that bolt.
    Good luck.
  9. Oct 7, 2013 at 4:45 PM
    Drunknsloth
    Retribution
    South West
    I just received my 4 1/2" angle grinder and cut off wheels from Amazon and I didn't think about this at first but it doesn't seem like the wheel is large enough to go all the way through the bushing. It looks the one you're holding in this picture is a similar size to mine. How did you get it to work?
  10. Oct 7, 2013 at 6:14 PM
    XXXX
    XXXX [OP] Well-Known Member
    sKiP
    05 Prius
    Cycle the LCA.
  11. Oct 7, 2013 at 7:45 PM
    Taco'09
    ^^^ In some of the other threads people who have tried used the sparkle wrench :eek: said they were not comfortable with doing it that way and resorted to the technique I describe in Post No. 28 above. Do what works for you for sure, but I felt I had the most control and least potential for collateral damage to me and the control arm mounts using the sawsall and blades technique.
    Good luck.
  12. Oct 8, 2013 at 1:57 AM
    Drunknsloth
    Retribution
    South West
    Thanks, that thought came to me after I typed my question. :)
    Thanks man, I might get a sawzall just in case. Do you think a Harbor Freight sawzall will be enough for this? I really don't have another $100 on a quality one.
  13. Oct 8, 2013 at 6:53 AM
    Taco'09
    ^^^ The HF stuff is hit and miss for sure. The good thing is you can always return it :D. For reference my Sawsall (the real one) is only 4.0 amps and works just fine on this kind of stuff. If you get a HF you might want to step it up some as they are known to overrate their product capacities.
    The biggest thing is don't cheap out on the blades and get just any old metal cutting blade, no matter what the brand. Too many of us have been down this road before. Get only the Lenox blade. They come in 5-packs which makes them reasonably priced. Use the Lenox Gold, Bi-Metal, 614G, 14 Teeth per Inch. Written on the blade itself is "THICK METAL, LONGEST LASTING EVER, T2" Its SKU No. is 21067614GR.
    Go sloooow, not fast. You might also want to use a bit of oil to help keep it cool.
    Good luck.
  14. Oct 22, 2013 at 1:54 AM
    Drunknsloth
    Retribution
    South West
  15. Mar 23, 2015 at 1:40 PM
    #35
    Wpg07TRD
    Wpg07TRD Canadian Member
    Neal
    Winnipeg
    '07 TRD Sport, DCLB
    5100s and 885x coils, Trail Gear Add-A-Leafs/5125s, interior light LED swap, rcbs204 illuminated 4x4 switch
    sub'd to try
