DIY leather arm rests
Discussion in '2nd Gen. Tacomas (2005-2015)' started by reid, Sep 1, 2007.
  1. Nov 6, 2013 at 5:35 PM
    #341
    kavahawaii
    kavahawaii Member
    Hawaii
    06 PreRunner
    none
    Reid, I've got a related question. I'm a tall guy and the arm rests are too low. As a result, I end up driving with my elbow up by the window. I've though about reaising the level of the arm rest with a pad over it but now you've inspired me to remove the rest and replace the fabric but install some way to raie it. Thoughts?, Materials? BTW - the Black Leather is awesome.
  2. Feb 6, 2014 at 11:07 PM
    #342
    gtdad66
    gtdad66 Well-Known Member
    Jesse
    West Ga
    2017 Tacoma Limited
    Front window tint, tool box, bed mat
  3. Mar 11, 2014 at 5:41 AM
    #343
    TTJunkie
    TTJunkie New Member
    Do you have to take entire door panel off to accomplish this, or is there a way to pop panels out without?
  4. Mar 11, 2014 at 6:21 AM
    #344
    jlleiber
    jlleiber Well-Known Member
    Justin
    Indiana
    2019 MGM TRD Sport DC 4x4
    Definitely have to remove the door panel because the arm rest panels are sort of plastic pop-riveted to the door panel. And as shown in the OP, you have to drill out or chisel them off to remove the armrest. Door panel removal is super easy though
  5. Mar 13, 2014 at 9:56 AM
    #345
    waheed
    waheed Well-Known Member
    Waheed
    Vancouver
    2010 Tacoma TRD OFF-ROAD
    Banks power Exhaust, 4x4 LED mod, Duratracs, SNUGTOP, LED insideNout
    Is that Vancouver BC or Washington dude...I am in BC
  6. Mar 18, 2014 at 4:53 AM
    #346
    deadbird8
    deadbird8 Well-Known Member
    Dallas, TX
    14 4x4
    Has anyone tried Hydro Turf as a pad under the outer covering? Its closed cell foam used on PWCs and boats, I have it on the floor and boxes of my Mud Boat.
    They make an under pad that is 5mm (about 3/16) thick as well as other sizes 8mm (~5/16) etc.... This stuff sticks really well (permanently even with my boat stored outside) w/ Super 90 or Weldwood and will take glue on the top for adhering the covering.
    http://hydroturf.com/products/Sheets_of_Hydro-Turf/Underpad
  7. Apr 24, 2014 at 6:41 PM
    #347
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
  8. May 12, 2014 at 9:58 AM
    #348
    belone12
    belone12 Well-Known Member
    Brian
    Long Island, NY
    06 Tacoma Double Cab 6spd TRD OR
    Bilstein 5100s, AAL, heated leather seats, Thule Rack, tow package, anytime foglight, Fold-a-cover
    I thought this was an awesome idea but for the smallest 5mm pad it is $21 shipped + tax. I am trying to find a small pad for underneath all 4, will look for an alternative. Great DIY.
  9. Jun 17, 2014 at 8:54 PM
    #349
    fireheadman
    fireheadman The Abyss
    Denver
    Blk 2015 Taco TRD Offroad
    access original tonneau cover, gentex genk51a review mirror, full leather katskin seats (Tucson), weather tech mats.
    Going on 3rd attempt with armrests.... Any help/advise would be greatly appreciated.
    The 1st attempt, I didn't take my time, I used 2 different spray adhesives over the factory pad. The next day, the vinyl lifted on the inside curve of the arm rest, so I rubbed it back down, that last for an hour..... I had John Huey send me 2 more pieces and tried it again (2nd attempt was last night), this time without the factory pad. I used mineral spirits to clean the glue off, then let it dry. Afterwards used the weldwood contact cement, let it dry for 10 min on both plastic side and vinyl, then put them together... then formed everything.
    I used a yellow sponge (from home depot) to keep pressure into the curve, then bungie corded a board over it and let this sit overnight. This morning it looked perfect! Within 2 hours or so after letting it sit on its own, it starts lifting from the inside curve again.
    ...I could easily rip this thing to shreds right about now, but then I heard you can't just replace the plastic piece, ya have to buy a whole door panel....
    I brought the other 2 pieces of un-used vinyl to a leather furniture store and had them match the grain/color to leather. This is going to run me $35 for 1/2 a yard of leather (not a bad deal).
    The question is...... How and what can I do to make the leather stay down/attached to the armrests?
  10. Jun 18, 2014 at 9:36 AM
    #350
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    if you use the proper glue and use it correctly it achieves adhesion immediately. no weights to hold it down. once you let it down it's stuck.
    watch this video - buy the same adhesive - follow the directions in the video.
    Very simple - just did mine a few weeks ago and they are perfect
    video thats been posted in here by another member
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/2755-diy-leather-arm-rests-17.html#post7340475
  11. Jun 19, 2014 at 4:27 PM
    #351
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    My next project.
    My elbow after 8 years have cracked this bastard too. So plastic-weld and some new fabric needs to be done. Great write-up!
  12. Jun 19, 2014 at 4:40 PM
    #352
    XXXX
    sKiP
    05 Prius
    Mine was starting to crack so I beefed it up with epoxy and lexan before putting them back in.
  13. Jun 19, 2014 at 5:27 PM
    #353
    Fiend13
    Chad
    The material that was used for the door armrest on my frontier had a permanent dip in it from my elbow. I hated that! The underlying plastic on the Tacoma arm rests don't allow that but the material is pretty thin. I'm gonna call Wet Okole soon to order the material so I can do mine and maybe add some padding while I'm at it. By the way, anyone know how much the material from Wet Okole is for this project?
  14. Jun 19, 2014 at 5:37 PM
    #354
    fireheadman
    Denver
    Thanks for the tip!... I watched the video, that will help a lot. I'll try some denatured alcohol next time to ensure all oils are gone.
  15. Jun 19, 2014 at 9:08 PM
    #355
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    It's getting near time for me to do this. My drivers door has cracked.
  16. Jun 20, 2014 at 11:24 AM
    #356
    Oregon TRD
    Ross
    2005 Mall Krawler
    That's what i'll do. The plastic weld is what I will do to fix it.
  17. Jun 20, 2014 at 11:31 AM
    #357
    Oregon TRD
    Ross
    2005 Mall Krawler
    I'm trying to get crazy with what I want to use for cloth????
    I wanted some black Oregon Ducks cloth, vinyl whatever.... but can't find it anywhere so I was thinking one of my black Oregon duck t-shirts......cut out logo part of shirt, wrap the area and glue it down. Wondering if t-shirt material will wear (probably) and tear too much though.
  18. Jun 20, 2014 at 11:45 AM
    #358
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
  19. Jun 20, 2014 at 11:54 AM
    #359
    Bagman
    Area 51
    Looks good. How much material did you use? (assuming you did all 4 doors)
  20. Jun 20, 2014 at 12:34 PM
    #360
    XXXX
    sKiP
    05 Prius
    have you seen the cracks? They are long. I used some 1/4" lexan I had laying around. I basically plated the entire underside of the armrest and the downside.
    I only have two doors and it was left over leather a member had given me for free. you don't need much at all. if your ordering it online I'd get at least (2) 24" x 24" and you should have enough for 2 front arm wrests and a mistake cut or two.
    kgarrett11 likes this.
