DIY oil changes?
Discussion in 'Technical Chat' started by linkfeeney, Sep 24, 2008.
  1. Sep 24, 2008 at 4:24 PM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    was it hard to loosen the oil filter
    was it hard to loosen the oil drain plug?
    just wondering... thx!
  2. Sep 24, 2008 at 4:26 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    Will this be ur first oil change for the car? if so, the oil filter might be a bit hard to take off but it is possible. drain plug is easy.
  3. Sep 24, 2008 at 4:37 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    yeah first time, I have this strap that can loosen it up.
    but it looks like the engine gets in the way.
    I never been under the truck, i guess a socket wrench will take care of it?
    thx
  4. Sep 24, 2008 at 5:14 PM
    Taco's for All
    Taco's for All Well-Known Member
    Lake George, NY
    2019 Tacoma TRD Off Road Double Cab
    Nothing at the moment
    Don't get the cheap Walmart oil filter removal clamp like I did. Tore the filter to hell and back. Glad my landlord owns a repair shop, I walked in an took on of theirs. Came off with ease with theirs. Drain plug.......SIMPLE, didn't have to hold on to the frame with one arm and the ratchet with the other like my old truck. I'm pretty sure it was 14mm.
  5. Sep 24, 2008 at 5:24 PM
    wushaw
    wushaw Well-Known Member
    Texas
    08 AC TRD 4x4 6sp
    It's simple and mine was easy. Remove the engine cover first for more room, 2 - 10mm nuts gives alot more room for a strap wrench.
    14mm for the drain plug, 5.5qts for the v6.
    Oh and you will need a catch can for the oil filter catch drain, I just poked a hole in the rim of a beer can with a ice pick and ran a piece of wire through it and just hung it from the lip of the catch drain after removing the drain cap.....it worked beautifully:) And now I have a beer can as an official tool.
  6. Sep 24, 2008 at 5:35 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    i put my 1/2 wrench into the strap wrench, it does not stay in place...
    I guess I have to play with it a little...
    and a 14mm socket into the drian plug then right?
    word up!
  7. Sep 24, 2008 at 7:49 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    It helps to put something under the strap wrench like sandpaper folded in half. Thats what I had to do the first time, oh and asked a neighbor and we both heaved on it. Also, take off the rubber nub from underneath the shield holding the filter & put a cup there to catch the overflow. If I can change this oil, anybody can! Chris4x4 did a great write up if you search. When you drain the oil make sure its the oil too, not the trans.
  8. Sep 24, 2008 at 8:10 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Oil change is simple!
    I have an oil filter socket that fits perfectly over the filters If I need it.
    I'm a woman, so my strength isn't as good as ya'll mens should be - so I use the socket probably more than usual (if I didn't do the last oil change).
    Before putting the new oil filter on....make sure you rub a thin layer of oil over the gasket on the end of the filter.
  9. Sep 24, 2008 at 8:16 PM
    Jester182
    Jester182 Well-Known Member
    SoCal
    08' Taco SR5 Double Cab - Indigo Ink
    Single-din Sony Xplod, SnugTop SL, AFE Pro Dry
    Just did my first oil change on my Taco about a week ago. Yeah, the filter is pretty tight, but if you get filter strap/socket it's not a problem. Though it is kinda hard to move around since the filter is up close to the engine. Also added a drain valve for easier changes next time around too. And what Xedge said...get a cup ready for the extra oil that's going to come out from the filter. Overall, it took about an hour to do, though it really depends on how long you want the oil to drain out...
  10. Sep 24, 2008 at 8:21 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I removed the plastic like stated above then had to use some pliers to remove my filter.
  11. Sep 25, 2008 at 5:55 AM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    put something under ths strap? I wish my socket wrench would go deeper on that wrench hole so it would stay in place.
    I guess I'll play it around today or saturday morning.
  12. Sep 25, 2008 at 6:17 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    Be careful not to drain the tranny! See this to make sure.
    Also, if you buy a Fumoto Oil Drain you'll never have to worry about the drain plug again. I have one for the truck and for my wife's car. Great for DIY oil changes.
  13. Sep 25, 2008 at 6:39 AM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    I'd be scared to death of that thing getting caught on something, and draining my oil pan.
  14. Sep 25, 2008 at 6:43 AM
    mws4ua
    Birmingham
    It doesn't hang down enough. I don't do much (read: any) offroading, so my opinion might differ if I did, but I don't have any fear of it catching anything at all. It sits up there plenty above the axle, etc.
  15. Sep 25, 2008 at 7:26 AM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    I'm scare to death that I'll break the oil filer and F my beautiful truck! *sobs*
    I knew I should have become an engineer!
  16. Sep 26, 2008 at 3:14 PM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    Does the drain plug have a flat gasket or an o-ring?
    Anybody know what size off-hand? (V-6 model.)
  17. Sep 26, 2008 at 4:49 PM
    Jester182
    SoCal
    Yeah, there's an o-ring with the drain plug. I believe its 12mm, but you can check for the right size on ebay.
  18. Sep 26, 2008 at 5:10 PM
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    Thanks Jester!
  19. Sep 27, 2008 at 7:15 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    man, i got the toyota tacoma replacement filters are SO cheap!! Made in Thailand?!
    Next time i rather order them from LA with the original 90915-20004 filter! what a difference!!!! Made in Japan at its best!
  20. Sep 28, 2008 at 3:01 PM
    wushaw
    Texas
    08 AC TRD 4x4 6sp
    It's a flat gasket and the bolt head size is 14mm.
