DIY Video - Front Camera Install and Demo
Discussion in '3rd Gen. Tacomas (2016-2023)' started by iampraneel, May 7, 2019.
  1. May 12, 2019 at 11:43 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I did this awhile back, works very well. I am planning to use a video switch so I can toggle between the rear tailgate view and the rear behind my trailer view with this when Im towing also. Will update when that’s been tested here too.
    iampraneel[OP] likes this.
  2. May 13, 2019 at 9:23 AM
    BigBeej
    BigBeej Well-Known Member
    Bryan
    Vista, Ca
    I just did the same and also used the Natika camera. Question I have is what wire on the camera do I need to snip? Right now if I go in reverse my backup comes on as normal but when I shift to drive it will go to the front camera until i hit the mode button to shut it off. How do I make it so it only comes on when i double tap the mode button?
  3. May 13, 2019 at 10:51 AM
    HiProofProducts
    HiProofProducts Well-Known Member
    NE Ohio
    2017 Tacoma TRD Sport
    Just finished with the ECT always on module and this system is next on my list of things to do. Hate pulling into a spot only to get out and realize i’m A block away from the car parked in front of me. I learned early on to blame it on the wife so it’s tolerable.
  4. May 13, 2019 at 11:32 AM
    Cercious
    Cercious Active Member
    Texas
    2019 Tacoma TRD OR 6mt
    Infinity speakers in the doors, Alpine 10" sub behind back seat
    Something to add to the list I guess. I'll watch the video when I get home from work. Didn't know I needed this, but going from a 370z to this truck has made parking am adventure.
  5. May 13, 2019 at 11:59 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Damg I would have invited you over had I saw this earlier. I’m only about 8-10 min from HB. I did mine yesterday and it was fairly simple, took about an hour with the learning curb. I can probably do it again inside 30 min now.
    So I ended up mouthing the cam in the same location and seam to work fine with the TSS sensor just below it. I also saw a few others mount it that way as well.
  6. May 13, 2019 at 12:21 PM
    Furball
    Furball Well-Known Member
    Minnesota
    2017 TRD Off Road
    sub'd for later
  7. May 13, 2019 at 12:32 PM
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    Got a pic of how you mounted it. Not sure what year/model/grill you have :notsure:
  8. May 13, 2019 at 12:50 PM
    17TRDSport
    17TRDSport Well-Known Member
    Is this install generally for the purpose of parking your truck?
  9. May 13, 2019 at 2:09 PM
    tacoma.jpg Well-Known Member
    Colorado
    2018 TRD OR Access Cab
    Matte Silver Metallic Vinyl Wrap 2.5" Icon Stage 3 Total Chaos UCA's Rear AAL + Shims 17" Jet Black SCS Ray 10's 285/75/17 Cooper's RCI Offroad Bed Cage RCI Offroad Skid Plates Decked Drawer System C4 Fabrication DOM Welded Sliders Nitro 4.88 Gears ARB Front Air Locker (Not hooked up yet) PIAA SMR 520 6" Lights (Hidden Behind Grill) Prinsu Access Cab Roof Rack
    sub'd
  10. May 13, 2019 at 2:13 PM
    raskal311
    S. Cal
    Not at the moment and the truck is at the installer for some new kings. But it’s just directly above the sensor in the middle. Same spot where those who don’t have the sensor mounts them.
    2019 trd off road 4x4 with knockoff pro grill
  11. May 13, 2019 at 2:27 PM
    MrBrooks
    Midwest
    Ok gotcha I was thinking of how to mount on the OEM 2018/19 style grill but will probably havta figure out a bracket to fit it up.
  12. May 13, 2019 at 4:15 PM
    iampraneel
    iampraneel [OP] Well-Known Member
    2016 DCSB TRD Sport 2WD
    That isn’t possible. You either have to hit the mode button or wait 30 seconds.
  13. May 13, 2019 at 4:17 PM
    BigBeej
    Bryan
    Vista, Ca
    Damn. Kind of annoying but not too big of a deal I guess. I think I should at least cut the white wire though correct? Is that the wire that lets it know its a front camera?
  14. May 13, 2019 at 11:27 PM
    iampraneel
    Yes, cut the white wire.
  15. May 14, 2019 at 5:00 AM
    #35
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    Ordered RFCC TTG2 and Natika camera from Amazon yesterday. :bananadance: Expected delivery 4-24 June for the TTG2. :(
  16. May 14, 2019 at 5:52 AM
    #36
    yoshitanoshi
    yoshitanoshi Well-Known Member
    Hi there! Thanks for the video and demo! Just wanted to ask, did you ever try to program the module so the camera would turn on automatically at low speeds?
  17. May 14, 2019 at 6:01 AM
    #37
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
  18. May 14, 2019 at 6:08 AM
    #38
    itzWicks
    itzWicks Active Member
    Bryan
    Southwest Oklahoma USA
    2019 Silver Tacoma TRD Off-Road 4X4 DCSB
    I am highly interested in getting a front cam for my rig. Subbing to absorb as much info as possible. If only I had the patience to wait for the 2020 models that have OEM options from the get go... :rolleyes:
  19. May 14, 2019 at 6:17 AM
    #39
    iampraneel
  20. May 14, 2019 at 6:19 AM
    #40
    TailHook
    Alan
    Southern UT
    Whoops...forgot to link it...thanks!
