Does the 2012 Lower trim panel fit on pre 2012 trucks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ShaLor, Jul 14, 2012.
  1. Jul 24, 2012 at 5:44 PM
    ShaLor
    ShaLor [OP] Well-Known Member
    Shane
    Burbank, CA
    07 4x4 Doublecab TRD Off Road
    Custom mud flap removal from rock on trail :), Tailgate Hose Clamp Mod, Cobra 75 wx st CB install, 19 more D-Rings in the bed, Satoshi Grill, Fog Lamp on any time mod. Relentless Fab CB antenna hood mount, LED bed lights, Demello Hybrid Sliders, Undercover Tonneau Cover, Lighted 4x4 switch
    That sounds awesome but that is the day my wife flies back into town after being out of state for work, so I don't think I will make it.
    I too would rather have them fit in the original spots, but I think the switches themselves might be too thick. I already have the switches, but don't have the panel yet to put them in.
    I would want to put the 4 switch blank in, but I couldn't find a picture of that one. I was able to add up the dimensions and that's what I posted.
  2. Jul 24, 2012 at 5:59 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Wong Travur brah
    ah gotcha...what are you doing friday?? the 3rd...i may be able to drive out there so you can check it out
  3. Jul 24, 2012 at 6:02 PM
    ShaLor
    Shane
    Burbank, CA
    As of right now, nothing. :D
  4. Jul 24, 2012 at 6:02 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Wong Travur brah
    alright, ill keep you posted what time im of work and stuff
  5. Jul 24, 2012 at 6:19 PM
    ShaLor
    Shane
    Burbank, CA
    :cool:
  6. Jul 24, 2012 at 7:36 PM
    tango down
    tango down Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
  7. Jul 24, 2012 at 9:08 PM
    Buell
    Buell Instagram: @thebuell
    Michael
    Culver City/Santa Monica
    2011 TX Pro MGM 4x4 Tacoma DC
  8. Jul 24, 2012 at 11:40 PM
    Buell
    Michael
    The only thing is this holder thing seems a little crooked, wonder if the 12 would fit and fit better...? maybe I'm wrong though
  9. Jul 24, 2012 at 11:45 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Wong Travur brah
    It's the same lol...mines loose from take it so many times apart to test clusters :anonymous: it's the same from the 12
  10. Jul 25, 2012 at 12:00 AM
    Buell
    Michael
    oh ok
  11. Dec 7, 2012 at 12:19 PM
    VE7OSR
    VE7OSR 'interfering with Natural Selection since 1990'
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, PIAA bulbs, LED bulbs all around, modified flasher unit for LEDs Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. Metal Tech Sliders w/ kickout and dimple die filler plates. swaybar relocate blocks (build my own)
    I went to the local dealer and measured the height of the available flat space for mounting switches etc. on the 2012 lower instrument panel piece.
    The total height of the flat space on the 2012 dash is 50mm (1.96"). This is an outside dimension, so the available space to cut out would be less than this to accommodate the plastic thickness. Reasonable clearance would depend on the thickness of the plastic, and any ribs on the inside, but estimating 45mm (1.77") I think would be maximum available height. This means the Cutout described above at 1.90" in height would not fit the 2012 lower dash piece.
  12. Dec 7, 2012 at 4:53 PM
    ShaLor
    Shane
    Burbank, CA
    Thanks for looking into that.
  13. Dec 14, 2012 at 5:38 PM
    Adreenaleen
    Adreenaleen Active Member
    Texas
    Speedway Blue 4x4
    Hey,
    Any updates or pics? Just got my panel and am looking into the switches also. Thanks,
    Adreenaleen
  14. Dec 14, 2012 at 5:57 PM
    VE7OSR
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
  15. Dec 14, 2012 at 6:10 PM
    #35
    claymore
    claymore Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
  16. Dec 14, 2012 at 6:45 PM
    #36
    ShaLor
    Shane
    Burbank, CA
    So it looks to me like you wouldn't have been able to fit two of the contura switches right next to each other. Am I right? The spacing is too close to each other?
  17. Dec 14, 2012 at 7:04 PM
    #37
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    It is possible. I had to trim some to get them in. I suppose you could trim a little more on opposing sides and make that work. They might look a little off center that way. The two OEM switches were already there, so I put them like they are to keep the intstall easy.
  18. Dec 14, 2012 at 7:11 PM
    #38
    ShaLor
    Shane
    Burbank, CA
    When you say trim the sides, do you mean the sides of the rocker switch or the sides of the lower trim panel to get the switches in?
    My truck doesn't have atrac so that's why I am wondering about putting in more than two switches.
  19. Dec 14, 2012 at 7:17 PM
    #39
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    I meant the side of the trim panel. With no a trac I think you can get 3 switches in there. My pic is not centered just right. There is room between the zombie and the a trac. I dont think trimming the rocker is an option. They are great switches. I didnt get the ones that are lit all the time and now wish I would have. Mine only light up when they are on.
  20. Dec 14, 2012 at 7:39 PM
    #40
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Isn't that Billy the Kid in your sig? With the Doc Holiday Quote?
