Does the V6 alternator fit on the 2TR-FE engine?
Discussion in '4 Cylinder' started by TireFire, Jul 29, 2016.
  1. Aug 5, 2016 at 10:40 AM
    TireFire
    TireFire [OP] Superunknown Member
    Olympic Peninsula
    No sir! I caused that "issue" fully on purpose by adding shit that needs power, a hard wired 800watts (1600peak) inverter among other things. I'm not here to have a fight with you, or anyone.
    That said I have a feeling you cannot answer my original question so I'd appreciate you stay on the sideline from here on out
  2. Aug 5, 2016 at 1:06 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Holy shit I'm gone for like a few hours and this happens lol. For the question pertaining to the es300 alt it ranges from 90 to like 130 depending on the model. The alternators are also in some Camry v6. The reason I say these look like a closer fit is they're on the same side of the engine and appear to have a similar mount. I plan on trying once I can get back out to the junkyard by me where alts are like $25. If you want to go the expensive route I have found a site that make high output alts http://www.m2kinc.com/product-2tr-fe-38-377-2.html. I'd just rather experiment and save money though.
    Also OP are your a 1st or 2nd gen?
    B ill y likes this.
  3. Aug 5, 2016 at 2:02 PM
    TireFire
    Olympic Peninsula
    Gen 2. Thanks keep me posted on your findings. Not lookin to spend hundreds on an alternator
  4. Aug 5, 2016 at 2:07 PM
    TireFire
    Olympic Peninsula
    I had already found that site actually and called them bc they are local to me. Almost a grand for an alternator is fucking madness tho!
  5. Aug 5, 2016 at 2:36 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Fuck that I never actually contacted them about it. I figured it was high but not engine swap high lol It kinda sucks the 2tr-fe doesn't have more support even though a lot of pre-runners have them. I too have a 1000/2000 watt inverter I've been waiting to install lol
    I can only image if any of us wanted to use a winch >___<
  6. Aug 5, 2016 at 2:41 PM
    TireFire
    Olympic Peninsula
    Winch is no problem if you only use it for occasional recovery, just get a deep cycle battery.
    I heard you can also get your alternator re-wound to put out more current but that means being without the truck for a while and I don't know how much it costs or who in SoCal even does it...
  7. Aug 6, 2016 at 4:13 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Hey OP. Something we use to do when similar issues happened was installed a capacitor to help out. It will take the stress off the electrical system and prevent any flickering. The capacitor builds up a high charge and balances the system by making up the difference when needed. Plus they dont cost that much. They can be had for around $100.
    https://www.mtx.com/library-car-audio-capacitors
  8. Aug 8, 2016 at 7:38 PM
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
  9. Aug 8, 2016 at 10:06 PM
    TireFire
    Olympic Peninsula
    Thanks for the link. You did see that it's a rebuilt one? Seems pricey for that... Is that one an OEM one where they changed the output capability?
  10. Aug 9, 2016 at 1:30 PM
    weldo
    Pittsburgh, pa
    Yea man, it puts out 250 amps! The stock one for 4 cyl is like 85 amps.
  11. Aug 9, 2016 at 1:30 PM
    TireFire
    Olympic Peninsula
    Are you gonna buy it?
  12. Aug 9, 2016 at 1:34 PM
    weldo
    Pittsburgh, pa
    I'd like to for an inverter, but money is kinda tight right now. Ironically because of the inverter! Lol!
    Supposedly it's made with better technology too that puts out higher amps at lower speed than stock. It may use a smaller pulley than oem, not sure. If it does you may need a slightly shorter serpentine belt.
  13. Aug 9, 2016 at 1:37 PM
    TireFire
    Olympic Peninsula
    Nah...Belt tensioner should take care of that. However, what are you going to do about wiring?
    Just run one additional wire from the alt to battery?
  14. Aug 9, 2016 at 1:40 PM
    jjustjjosh137
    jjustjjosh137 Well-Known Member
    Josh
    Pensacola
    2010 taco 5speed 2.7l 4wd
    None yet
    Lol round 2 moondeath tgear.shed :)
  15. Aug 9, 2016 at 2:02 PM
    #35
    weldo
    Pittsburgh, pa
    You mean to carry the current? I'm not sure. I haven't researched that yet. There's a guy on the forum that makes kits to replace the big current carrying wires with larger stuff, like the bat cables and starter and alt wires. Lemme see if I can find his thread...
  16. Aug 9, 2016 at 2:04 PM
    #36
    weldo
    Pittsburgh, pa
  17. Aug 9, 2016 at 4:54 PM
    #37
    TireFire
    Olympic Peninsula
    That's definitely the expensive way of going about it. Since he is making these wires for the V6 which has the alternator on the battery side it might not even work for you unless you extend the cables. At that point might as well build your own.
    And his supplier BNR has earned themselves a real shit reputation for making rosy promises which their merch fulfills 30-50% before giving up the ghost entirely a few months later. Btw that's the same company you shared the eBay link with. If you decide to go with them make sure to take a good look at the amp/rpm charts and get a solid warranty.
    I think I'm just gonna stick it out and eventually get my alt rebuilt by a reputable company like singer or mechman
    #37
  18. Aug 9, 2016 at 5:10 PM
    #38
    weldo
    Pittsburgh, pa
    Wow, I had no idea about that! Thanks for the heads up.
  19. Aug 9, 2016 at 5:26 PM
    #39
    TireFire
    Olympic Peninsula
    You bet. Back to my OP, I've compared pictures of the 4cyl and V6 alternators online and they look the same so a swap might still be in the cards. Going to compare physical tomorrow night
    5 Lug Fury likes this.
  20. Aug 9, 2016 at 6:02 PM
    #40
    weldo
    Pittsburgh, pa
    What about the wiring? Does the V6 have the same 4 pin plug like in the pic above?
