Door Sill Protectors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WhyNotFab, Feb 5, 2011.
  1. Sep 29, 2012 at 8:45 AM
    #41
    Cain
    Cain Well-Known Member
    Southern California
    2012 Tacoma
    Chrome don't get you home
    Just sent payment for this type, very cool, thanks
  2. Sep 29, 2012 at 8:53 AM
    #42
    Larry
    Larry CARL
    CARL
    welcome
    take your time w/ the install and they look factory.
    clean the area with the alcohol wipes...let dry...put the sill piece in place...then pull on the double sided tape "tabs". note: be sure all 4 "tabs" are exposed before sticking the 1st one (or you'll have a rough time getting to the others)
    after I had a sill piece in place...I used a blow dryer on it while pressing to make sure the tape glue was good and stuck.
    and, I did it recently in the heat of Florida summer...if it was cold/cool outside...it may be wise to heat up the sill pieces for flexability and a better fit.
    :cheers:
  3. Sep 29, 2012 at 9:16 AM
    #43
    Cain
    Southern California
    2012 Tacoma
    Thanks Larry, will do.
  4. Sep 30, 2012 at 9:45 AM
    #44
    Buck Naked
    Buck Naked Active Member
    WA
    2023 TRD OR DCSB Manual Trans
    Larry,
    Is that a Double Cab you put those on? Would you be able to measure the length of those? Looking to put them on a regular and want to make sure they fit.
    Thanks!
    Dave
  5. Sep 30, 2012 at 12:08 PM
    #45
    Larry
    Larry CARL
    CARL
    yes, double cab.
    the front ones are 27-1/4" long
  6. Nov 26, 2012 at 7:31 PM
    #46
    JirafaBo
    JirafaBo Well-Known Member
    Bo
    Orlando
    '12 Black Access Cab TRD Sport
    Jeez I had the nice ones from TRD Parts in my cart, they want $16 to ship to Florida. NO WAY. Also, their coupon code they advertised for Black Friday didn't work. Booo
  7. Nov 26, 2012 at 8:39 PM
    #47
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Only get the AVS ones since they cover the edge. The Toyota ones and many others don't.
  8. Dec 1, 2012 at 1:45 PM
    #48
    JirafaBo
    Bo
    Orlando
    I went ahead and ordered them, now I see why shipping is $15; I didn't realize they were stiff plastic, I assumed they were sticker-like.
    Anyway I got them today and you can tell they give you the single cab pieces for the fronts. They are curved up on both ends, which does not make for a good fit. Kind of disappointing because it's a simple fix on their end. I don't have a heat gun to help me to warp the back ends down to flat. Would a blow dryer do any good to soften the plastic?
  9. Dec 1, 2012 at 4:36 PM
    #49
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I have the toyota sill protectors too, and I will probably go with the AVS since it protects the edge. Thats where my boots hit the most. I dont actually step on the sill, just occasionally drag my foot against the corner.
  10. Dec 1, 2012 at 4:49 PM
    #50
    goufcustom
    goufcustom 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    I am considering these too, I have the factory sticker ones, and after 6 months they have tons of small air pockets under them, looks terrible, and I spent a long time putting them on to ensure there were no air bubbles under them... :mad:
  11. Dec 2, 2012 at 3:51 PM
    #51
    JirafaBo
    Bo
    Orlando
    Here's what I'm talking about. I'm calling avs tomorrow to see what they have to say.
  12. Dec 2, 2012 at 5:13 PM
    #52
    dexterdog
    Oly WA
    2012 F150
    You have the wrong ones or you have the back door sills on your front doors.
  13. Dec 2, 2012 at 5:55 PM
    #53
    JirafaBo
    Bo
    Orlando
    No those are the fronts. The back ones are much shorter and one end is "almost flat". Also they are labeled for front and rear. I checked the product number and according to the avs site, I have the correct pieces. As you can see, they are not even close to fitting correctly.
  14. Dec 2, 2012 at 7:45 PM
    #54
    bullaculla
    Da big big island!
    looks like supposed to be for a double cab? I didn't notice one for access cab.
    I want to order these but I gotta find someplace else. TRDparts4u wants $44 to ship to hawaii via ground.
  15. Dec 2, 2012 at 8:01 PM
    #55
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    If you find a number for an access cab, post it up please. I haven't been able to find one for the access cab :(
  16. Dec 2, 2012 at 8:09 PM
    #56
    bullaculla
    Da big big island!
  17. Dec 2, 2012 at 9:24 PM
    #57
    JirafaBo
    Bo
    Orlando
    Yep you guys are right. I ordered double cabs assuming they would have same front pieces as access. Duh I'm a tard. Also they don't advertise access cab pieces! Guess I'll be selling these and ordering new ones. Damnit.
  18. Dec 2, 2012 at 11:18 PM
    #58
    bullaculla
    Da big big island!
    Send them to me :D
    Try contacting EODtech08 and see where he got his from. He has pics in the link I posted.
  19. Dec 3, 2012 at 1:06 PM
    #59
    JirafaBo
    Bo
    Orlando
    I talked to him and he used the standard cab version. Which to me would seem to also be curved on both ends. In his picture you can't see either end but it looks like one end goes all the way under the closed half door. I will probably try to sell these without shipping g costs to someone in my area (orlando)
  20. Dec 5, 2012 at 12:22 PM
    #60
    JirafaBo
    Bo
    Orlando
    Spoke with customer service at Auto Ventshade and they do not make an access cab version. However, they do make a universal version which is flat on both ends, 30.5" long with a 1" curved lip running the length of the piece. Comes in a two piece set. This set should work best on the access cabs.
    It is item number 88407.
