Double Cab Long Bed -- Jumpy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cusas6, Oct 15, 2007.
  1. Oct 15, 2007 at 5:45 PM
    cusas6
    cusas6 [OP] Member
    Hey all,
    I've had my Taco for about 6 months now. The only issue I have is that when I get out on the highway the back end of it jumps up and down alot. Its enough to make my girlfriend nausous. I took it back to Toyota and they told me that it is normal for a truck with that long of a wheelbase.
    Does anyone else with a Double-Cab with the long bed have this issue? If it is just because it is that long can anyone think of anything I can do to reduce that jumpiness?
    Thanks,
    Scott
  2. Oct 15, 2007 at 5:55 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    check out this post for the TSB for that issue. print out a copy and take it to ur dealer and stick it!!! haha LINK!!!
  3. Oct 15, 2007 at 6:03 PM
    kristopherl
    kristopherl AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
    Scott,
    That sounds like a BS response from the Dealership. I have a DC LB 4X4 and it rides like a Cady on the highway. Just asked my wife if she thought it was rough and she said she never noticed it being jumpy on the highway.
    I would ask another dealer. You might have some bad shocks.
  4. Oct 15, 2007 at 6:32 PM
    cusas6
    cusas6 [OP] Member
    jhodge83,
    Thanks for the TSB, but I am little concerned by the warning about the "rear suspension firmness", sounds like it could make my issue worse.
    Anyone have any thoughts on this.
    Thanks again,
    Scott
  5. Oct 15, 2007 at 8:08 PM
    The_Hodge
    SC
    if i'm on the highway and hit bumps, my rear end really jumps. i was towing an s-10 on a tow dolly this past weekend and the cab wouldnt bounce, but the bed would, which i thought was odd. but a few people have already had the tsb done and i've got my appointment friday morning.
  6. Oct 16, 2007 at 4:02 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    The added weight and length of a DC long bed should make the ride extremely smooth. I would go back to that dealer and tell them that they need to figure it out. My 4 cylinder Access Cab PreRunner is light with 4WD suspension on it. It has a rougher ride than most Tacomas, but it is still not jumpy.
    Good luck, and let us know how it goes.
  7. Oct 16, 2007 at 7:11 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    Yeah, having a long heavy truck should not make it jump. The dealer is full of sh!t. I know this is a stupid question but have you messed with your rear tire pressure any? If its actually jumping it sounds like your rear tires are over-inflated. you may want to take a few psi out and see how it rides if you havn't already tried this
  8. Oct 16, 2007 at 8:53 AM
    The_Hodge
    SC
    yeah...i run mine at 30, the dealer sticker says 29
  9. Oct 16, 2007 at 9:18 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I've got the same setup and everyone always says it has such a non-truck like ride. I don't have the TSB yet and I'm worried it could make it stiffer.
    I've noticed that the ride gets better with more weight in the truck. Try weighing down the truck a few hundred pounds and see if that helps.
    I could see that if both of you are coming from Lincolns and Cadillacs you might think the Taco is a rough ride.
  10. Oct 16, 2007 at 4:34 PM
    bbarian333
    bbarian333 Well-Known Member
    SoCal
    06, Accesss Cab, TRD Sport
    TRD exh, K&N drop in,TRD seat cvrs,tsb springs
    I have the same issue cusas6. I have an access cab trd sport. I plan on getting the TSB done, but my worries are the same as yours. Will it make it worse?
