DRAINIG REAR DIFFERENTIAL FLUID
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lodawg, Feb 26, 2013.
  1. Feb 26, 2013 at 5:18 PM
    lodawg
    lodawg [OP] Member
    Lithonia , GA
    BLACK 2011 DBLE CAB
    I have been reading posts on the subject. However someone raised concern of having to jack up left side completely to get all of the fluid out . Is it neccessary to do this when changing the fluids on flat service ?:rolleyes:
  2. Feb 26, 2013 at 5:20 PM
    Bennett707
    Bennett707 Station707
    Oregon
    '04 V6 3.4 TRD
    zip ties and scotch tape
    I just changed mine, and couldn't be fucked to raise sides.
  3. Feb 26, 2013 at 5:31 PM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    really doesnt matter much. You can just drain it like doing an oil change. Even if you let it drain over night,theres still going to be oil in the lines or gears of whatever your draining. I didnt worry about "getting everything out" one bit
  4. Feb 26, 2013 at 5:33 PM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    I just drained it and refilled it. The one piece of advice I have is make sure you take the fill bolt off first. It would be a shitty experience to drain it and discover you can't open the fill hole.
  5. Feb 26, 2013 at 5:52 PM
    BradyT88
    BradyT88 Well-Known Member
    ^^^That happens a lot too surprisingly. Have a friend that used to work at Jiffy Lube. haha One time he got the fill plug free but couldn't get the drain plug free so he had to siphon the old stuff out.
  6. Feb 26, 2013 at 5:58 PM
    CrAiG
    CrAiG Well-Known Member
    Tacoma889
    2010 toyota tacoma TRD
    Three inch spacer lift
    i just took mine for a drive to get the oil nice, and warm before i started the draining process. There isnt enough oil left in it to worry about in my opinion.
  7. Feb 26, 2013 at 6:05 PM
    BradyT88
    Try pulling the axles after you have drained the diff. About 1/8th to 1/4th of a quart will come spilling out of one of the sides when you pull both axles. haha
  8. Feb 26, 2013 at 6:22 PM
    BradyT88
    Didn't mean to imply pulling axles was necessary... just mean there is still a fair amount of diff fluid in there after your have pulled the drain plug.
  9. Feb 26, 2013 at 6:34 PM
    68Whiskey
    68Whiskey Well-Known Member
    Richie
    Ft.Bragg NC
    2008 4x4 DC TRD Off Road
    what weight and how much fluid goes in the diff? Ive been thinking about switching my 4x4 OR completely over to Royal Purple starting with the rear diff
  10. Feb 26, 2013 at 6:37 PM
    CrAiG
    Tacoma889
    Thanks for the info didnt know there was that much!!!
  11. Feb 26, 2013 at 6:40 PM
    BradyT88
    Well technically Royal Purple isn't on the list to be compatible with our Tacomas (I think it was gear oil too, may have just been tranny fluid) but I know there are lots of people on here running it without problems.
    I just bought some cheap supertech synthetic 75W-90 from walmart and have been great.
    Rear diff holds 3 qts according to this thread (should be listed in your manual)
    http://www.tacomaworld.com/forum/technical-chat/24545-changing-differential-fluid-step-step-how.html
  12. Feb 26, 2013 at 6:41 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Break-in happens with the rear diff, too. Also, the stock fluid is not synthetic, so it probably started off darker.
  13. Feb 26, 2013 at 6:43 PM
    68Whiskey
    Richie
    Ft.Bragg NC
    Sweet , Thanks. I dont have a manual sadly :(
    I have to put up with the sad search feature here for most of my questions
  14. Feb 26, 2013 at 6:57 PM
    KenLyns
    Belly of the Beast
    I just drain until it's a trickle and pour till it's level with the fill hole. Toyota trucks are meant to be maintainable by illiterate cavemen in Afghanistan. Don't sweat the details.
    And if the fill plug ever gets stuck, you can always unscrew the breather. :D
