Driveline Part
Discussion in '1st Gen. Tacomas (1995-2004)' started by seabeegt, Feb 21, 2021.
  1. Feb 21, 2021 at 7:26 PM
    seabeegt
    seabeegt [OP] Well-Known Member
    Greg
    03 Tacoma 3.4L V6
    4” Lift, Exhaust Pipe
    DD0F8926-5EBB-4BF7-8DFF-EC86AE3CF6B8.jpg Was under the Taco earlier today, doing some inspection after reading up on the double-cardan u-joint replacement and... I see this carrier piece that has rubber in it and it’s almost shot. I looked at schematics and can’t find it. I have an 03’ 3.4L Tacoma w/ extended cab (4x4). Also, if anyone’s replaced this item... do I have any advice?
  2. Feb 21, 2021 at 7:33 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I think that's a little more than almost...
    That's your center support bearing or carrier bearing for the driveshaft.
    I have replaced one before and my advice is take it to a reputable driveline shop, not a mechanic, but specifically a driveline shop.
    The U joint will need taken apart and then a large nut will be removed to slide the joint half off the driveshaft so that the bearing can then slide off.
    The inner bearing surface is often seized to the shaft.
    You will need a new bearing and it's a good idea to do your U joints while you're there anyway.
    This is a major PITA and it's a good idea to take it to a specialist and have the work done so that everything remains in phase and balanced to prevent vibes.
    But yeah, that thing is toasted done been past time to replace it, surprised you don't have bad vibes and a clunking on takeoff and switching to reverse.
  3. Feb 21, 2021 at 7:37 PM
    seabeegt
    Greg
    03 Tacoma 3.4L V6
    So it’s a carrier bearing? Yeah, I’ve got no vibrations. Guess I’m lucky. What sucks is... I’m out in the desert. Not close to a driveline shop.
  4. Feb 21, 2021 at 7:44 PM
    seabeegt
    Greg
    03 Tacoma 3.4L V6
    80EF7AB2-9018-49C7-806C-F351A42EC124.jpg I found this on Rock Auto... this is on the more expensive end of $75. Is this the correct part?
    Rachelsdaddy and Bishop84 like this.
  5. Feb 21, 2021 at 7:45 PM
    Bishop84
    Bishop84 Well-Known Member
    Any shop can do it, as mentioned replace the ujoints while you're at it.
    TIMKEN is a good brand.
    If you DIY, make sure to mark all shaft alignments.
    Key-Rei likes this.
  6. Feb 21, 2021 at 7:45 PM
    Key-Rei
    Key
    Florida
    Looking at yours it might not be as bad, that 6074 should be the spicer part number but you may want to call up O'reilly's to confirm. It should be Spicer as the OEM, even if you buy from Toyota it's just an overpriced Spicer.
    Looks like you could get away with just unbolting the U joint from the shaft flange there and then unstakeing the nut and recording the number of turns for removal, the preload is important IIRC, pull the flange (mark it and the driveshaft so they stay clocked together and thus balanced and then you might get lucky sliding the old one off and the new one on reinstalling and restakeing the nut.
    There's a thread on here in the 2nd gen section about filling the "rubber doughnut" with construction adhesive or sealant for added strength and longevity as that vibration mount rubber always fails long before the sealed ceramic bearing.
  7. Feb 21, 2021 at 7:47 PM
    Key-Rei
    Key
    Florida
    Timken makes good bearings, if that's what RA says fits for your year then it should be correct.
    Typically the difference between a 4WD and 2WD driveline components is nothing more than the 4WD stuff usually has more sealing lips and typically comes with grease fittings for the U joints. 2WD usually does not.
  8. Feb 21, 2021 at 7:49 PM
    Bishop84
    2WD is a slip yoke into the transmission as well.
  9. Feb 21, 2021 at 7:53 PM
    Key-Rei
    Key
    Florida
    I was more referring to the U joint spiders and bearings but you are correct, there's also naturally a length difference as there's no transfer case, and again length differences between AT and MT shafts. So 6 total shafts, 2WD AT and MT 4WD AT and MT and 5 Lug AT and MT.
    That said if you have a TRD PreRunner first gen (2WD with the E-locker) it has a bolted trans flange and a 4WD style driveshaft components.
    The double cardigan is great for preventing vibes and increasing tolerance, wish Toyota pit the DC in the 2nd gens.
    Bishop84[QUOTED] likes this.
  10. Feb 21, 2021 at 7:57 PM
    Bishop84
    I actually skip grease fittings now. My xterra needed front joints and I went out of my way to avoid the greaseable. I went napa heavy duty oddly enough, was too impatient for a splicer.
    I've found sealed is better in my years at toyota, and toyota manufacturing agrees, even the 2nd gen updated ujoints are non-serviceable.
    I always find the greaseable joints have 2 failed caps and the 2 primary grease caps are ok.
  11. Feb 21, 2021 at 9:04 PM
    jonesbt
    jonesbt Well-Known Member
    Brett
    Monroe, La
    01 3.4L DC PreRunner—>4WD
    TRD Headers TRD Supercharger Custom Cavalry Blue Paint
    This carrier bearing isn’t hard at all to replace. I certainly didn’t use a driveline shop. There’s a write up somewhere on this site for how to do it. Go buy yourself the proper sized large socket and knock it out. I changed this and the transmission mount on my 01 at the same time. Both are easy to replace and helped me address some vibrations I was having at the time.
    Rachelsdaddy, nagorb and SLAPS 65 like this.
  12. Feb 21, 2021 at 9:28 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    I might be wrong since I haven't take the time to install it yet and its just sitting on the shelf collecting dust but shouldn't this fit just fine?
    https://smile.amazon.com/gp/product/B00GAPFD2E
    There is a thread on it here -
    https://www.tacomaworld.com/threads/best-center-support-bearing-for-2002-tacoma.689848
    and also here -
    https://www.tacomaworld.com/threads/1st-gen-genuine-oem-carrier-bearing-for-79.583219/
  13. Feb 21, 2021 at 10:17 PM
    seabeegt
    Greg
    03 Tacoma 3.4L V6
    I found one at Autozone for about $50. It’s the Duralast version. Jonesbt, doin remember what size socket is required?
  14. Feb 21, 2021 at 11:20 PM
    Key-Rei
    Key
    Florida
    I don't know about the 1st gens but I want to say mine was a 27mm.
    For mine I had to stick it in the bench vise and use a big breaker bar to get the center nut broke loose, then use a three jaw puller to pull the bearing inside part of the bearing off.
  15. Feb 22, 2021 at 9:12 PM
    jonesbt
    Brett
    Monroe, La
    Here is a pretty good video of the process. It’ll give you a good idea if it’s something you’re comfortable trying.
    https://youtu.be/cw3qeQkKnc8
    seabeegt[QUOTED][OP] likes this.
  16. Feb 23, 2021 at 7:46 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    All the ones I changed over the year if your careful and mark things I never had problems .
    If you pull things apart and have different parts laying at random I could see problems could happen.
  17. Feb 23, 2021 at 8:05 PM
    seabeegt
    Greg
    03 Tacoma 3.4L V6
    Great video, yeah that looks like a can-do job for me. Just gotta be mindful of making markings and what-not. Thx for the help!:headbang:
    jonesbt[QUOTED] likes this.
  18. Feb 24, 2021 at 3:23 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I put that Spicer CB on my truck almost 3 years ago. Been 100% trouble free. Comes with a Toyota P/N stamped in the rubber and says its made in Japan. Id bet money that Spicer is the OEM manufacturer for these for Toyota, I know on the 2nd gens that they are.
    Do your self a favor and do not buy anything but that Spicer bearing or one from a Toyota dealer. While Timken makes good bearings, the rubber housings are a different story. Ive read on here more than a few times of those Timken and other cheaper carrier bearings having the rubber rip apart prematurely.
    Also, pick up a set of extended length (non ratcheting) metric wrenches. I found that a long 14mm was the bees knees for getting the torque needed to break the bolts free on the flanges. A socket + ratchet and a ratcheting wrench wouldnt fit on them, atleast in my case.
    Area51Runner[QUOTED] likes this.
  19. Mar 6, 2021 at 10:48 PM
    seabeegt
    Greg
    03 Tacoma 3.4L V6
    Did the center bearing today (finally)! Job went fairly easy. I was surprised how much smoother the truck runs... didn’t think it was too rough before, but I guess perspective is everything. The nut that secures the the end cap of the propeller shaft is all haggard now. Anyone know it’s proper nomenclature? I need to replace it the next go around. Didn’t replace any ujoints, they all seemed fine. Just greased everything. Even separated the rear propeller shaft and manually greased the splines. I feel way more secure knowing the driveshaft isn’t jumping around freely anymore. :drunk:
    Area51Runner likes this.
  20. Mar 6, 2021 at 10:51 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    It’s called a staked nut, I believes there’s a write on this site with the part number.
