DRL mod for the 2011 model
Discussion in 'Lighting' started by bmet bob, Nov 26, 2010.
  1. Nov 26, 2010 at 9:34 AM
    bmet bob
    bmet bob [OP] Member
    Bob
    Colorado Springs
    2011 access cab 4x4
    Hey guys looking for some help with a nagging issue on my new truck. Just bought a 2011 Taco and noticed there is no way to turn off daytime running lights. My work truck is a 2010 Toyota Sienna and it has a switch on the light stock to turn them on/off. Noticed the threads on this site for earlier models of Taco's but not for the 2011. Anyone got a link or advice on how to accomplish this????
  2. Nov 28, 2010 at 8:16 PM
    TRDSport10
    TRDSport10 Well-Known Member
    Rhode Island & Virginia
    '10 AC TRD Sport 4x4 - Silver
    TRD Exhaust, Tube Steps, Towing Hitch, Paint Protection Film, Bed Mat, Wheel Locks, Spare Tire Lock, First Aid Kit, Ashtray Cup, TRD Air Filter, TRD Oil Cap, TRD Radiator Cap, FJ TRD Hub Caps, FJ TRD Shift Knob, BackFlip F1, TSB Rear Springs, Coupe TRD Battery Hold Down Bar, KatzKin Leather Seats with W.E.T. Seat Heaters, WeatherTech: FloorLiners DigitalFit, Side Window Deflectors, ClearCover License, LampGard
    Bob,
    Lots of threads available regarding install of DTRLs on Tacos that don’t have them stock., search GOOGLE and TacomaWorld, etc. Basically, you need to replace the turn signal flasher relay and add a jumper. The end result is that you will have the same as a factory install. :D Parts needed include
    Toyota Part # 82241-04030 is a relay and Part # 81980-35020 is a jumper both available from your local dealer.
    If you search DTRL, you'll get a bunch threads with good and sometimes useless info, perhaps too much. Several with photos, select:
    http://www.tacomaworld.com/forum/technical-chat/1475-05-drl-daytime-running-lights-install-oem.html
    http://www.toyotanation.com/forum/showthread.php?t=315828
    http://www.toyotanation.com/forum/t164710.html
    You may find these TacomaWorld threads of intrest also:
    http://www.tacomaworld.com/forum/technical-chat/4838-cheap-free-mods.html
    DTRL toggle switch mod (stealth mode)
    Beware :eek: there are a number of people who have complained about the DTRL bulbs causing damage to the lens inside the headlight housing - search this forum, you’ll find them.
    Good Luck with your new truck and these mods.
    jfb
  3. Feb 5, 2011 at 4:45 PM
    enjm10
    enjm10 Well-Known Member
    Eric
    NM
    2020 White Double Cab
    5% Front strip and doors, 20% wrapped around the rest of the truck.
    On the second link from toyotanation do u have to do it to both lights
  4. Feb 5, 2011 at 11:20 PM
    enjm10
    Eric
    NM
  5. Feb 5, 2011 at 11:28 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    [​IMG] like what kind of damage?!?! D:... i ordered some LEDs, will that be safe??
  6. Feb 6, 2011 at 6:27 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    You will be fine.
  7. Feb 6, 2011 at 2:59 PM
    AsianAnts
    AnT
  8. Jul 29, 2012 at 5:11 AM
    foreman
    foreman Member
    Bill
    Missouri
    2011 Toyota tacoma
    Bob did you figure out a fix? I want to disable mine on my 2011 and add a switch to turn them on. I'm sure it's as easy as cutting a wire!! Or Not
  9. Jul 29, 2012 at 5:34 AM
    Tacoma Mike
    Southern Maine
    I did mine a little different I used a switch to disable the DTRL but added a wire to both sockets and now have 4 lights on in the parking light mode. To go back to DTRL if I ever wanted to is to unplug the 2 wire connectors and throw the switch. Myself I like this look a lot better and I have gotten second looks from other owners. A few guys on here have done this mod also and like it as well.
  10. Aug 5, 2012 at 3:37 AM
    foreman
    foreman Member
    Bill
    Missouri
    2011 Toyota tacoma
    Hey all,
    I did get my DRLs turned off on my 011 and it wasn't so bad just cut the green wire with red tracer and there you have it. I wired a switch in so I can turn them on if wanted. Thanks Mike for the parking light idea I like! Now I'm thinking about adding a remote start!! Any ideas on that Mod?? ( probably Artic Start)
  11. Aug 5, 2012 at 5:20 PM
    Tacoma Mike
    Southern Maine
    Here is a pic of the "4-lamp" mod to see what it looks like.
    As far as a remote FWIW, i don't believe in them. I've seen way to many issues with them. Take them out all the time. I'm sure plenty of Members will disagree but you asked. heheheheheh
  12. Aug 11, 2012 at 3:40 AM
    foreman
    foreman Member
    Bill
    Missouri
    2011 Toyota tacoma
    Your truck looks great with the parking light mod,i'm doing mine today. My wifes Toyota Vensa has factory remote and its a dandy you have to be within 25 feet to start it on a good day. Sooo what good is that for $500!! Big complaint but toyota isn't listening. And your right i'm a little hesitant to do this on my taco but if I can do it my self the kits is less than $100 so it wouldn't break the bank . Just figuring out the wiring is my main issue.
  13. Aug 6, 2014 at 5:31 PM
    DrFunker
    DrFunker Well-Known Member
    I have a 2011 with no DRLs. Means that:
    1) they are not there.
    2) the person that owned this truck before me disabled them.
    I know that I need to poke around inside to really find out. But I am wondering,
    Did this feature come "stock" on all 2011s?
