Dropping 100lbs+ off rotational weight.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Razorecko, Nov 5, 2013.
  1. Nov 7, 2013 at 6:06 PM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    I got the best of both worlds. I shed a lot of weight per corner AND went up in diameter. Now I get better MPG from less mass and better MPG on the highway by running lower RPMs. On top of all the other little fine tuning and upkeep I did when I got this Pickup I can easily hit 20-25% above EPA. Only issue is Winter. I drop down to about EPA or a hair under then.
  2. Nov 7, 2013 at 6:28 PM
    Razorecko
    Razorecko [OP] Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    Yea I loved how the 285's looked but this time around i wanted to see how they would do in our crappy winters...not only that the 265's were a good deal cheaper. We'll see how it goes
  3. Nov 7, 2013 at 6:38 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    So were the 285s E rated and 265s C?
  4. Nov 7, 2013 at 7:00 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Did you weigh the Hase Spec wheels? From what I read, they are over 20 lb each.
    Volk TE37 for our trucks is about 16 lb. Konig Countersteer Off Road measured 18 lb on my bathroom scale. It would take a lot more $$$$ to reach 14 lb. ;)
    Rule of thumb for unsprung weight is 1:3.
  5. Nov 9, 2013 at 7:35 AM
    Razorecko
    There is no way the hase specs are over 20lbs each. I got the 15lb info from JdMeF9SiR2 , where I got the wheels from. He seems to know a bit about wheels since he sells a ton of the Konig Countersteers on the forum. I went from 285 e load to 265 c load. We measured the weight and the difference on the tire switch was exactly 13lbs difference for each tire.
  6. Nov 9, 2013 at 7:44 AM
    KenLyns
    Belly of the Beast
  7. Nov 9, 2013 at 12:05 PM
    Razorecko
  8. Nov 9, 2013 at 2:09 PM
    KenLyns
    Belly of the Beast
    ^You are not reading it correctly. He's saying the Weds Hase clone is less than 20 lb, lighter than the original.
    The Weds Hase Spec is still a cast wheel (http://www.wedswheelsna.com/weds/weds-adventure/hase-spec/), which keeps the price reasonable at $1600 for the set. Forged Rays wheels would be about twice that.
  9. Nov 9, 2013 at 3:25 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    U know 63% of all statistics are made up right?
  10. Nov 9, 2013 at 3:44 PM
    Jaime
    Jaime Maibatsu Monstrosity
    James
    Dallas, TX
    2007 DCSB Base 4x4 6spd
    Those new wheels look great OP.
    Sub'd to find out how much these wheels actually weigh...
  11. Nov 9, 2013 at 5:15 PM
    Razorecko
  12. Nov 12, 2013 at 5:10 PM
    Razorecko
    Well you're right. Looks like 15lbs was a "typo"
