DTRL toggle switch mod (stealth mode)
Discussion in 'Lighting' started by Crom, Apr 4, 2010.
  1. Jun 10, 2011 at 1:13 PM
    #61
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
  2. Jun 13, 2011 at 8:37 AM
    #62
    boxxed
    boxxed Well-Known Member
    Denver, CO
    Off Road
    Leer Cap Kenwood DNX 9140 Boyo back up cam HD Raido Sirius Weather Tech Mats Memphis Audio, Valentine One radar,Tinted windows,Wet Okole's, Bed mat.
  3. Jun 17, 2011 at 6:07 PM
    #63
    BradleyJ33
    BradleyJ33 Geaux Tigers
    Brad
    Brandon, MS
    2010 TRD Sport 4x4 DCSB S/C'd
    TRD Supercharger with URD 2.825" Pulley, Toytec Ultimate Lift, LR UCAs, BFG All Terrain 275/70R17s on Procomp 7089 17" wheels, BAMF rock sliders, Viper 5902 alarm/remote start with smartstart, Pioneer Avic-Z110BT dvd/navi head unit, 2 Pioneer 7" monitors in headrests, 2 Rockford Fosgate Shallow-mount 10" subs pushed by RF Punch 500.2 amp, RF 5.25 components (front doors) and 5.25 full range (back doors) pushed by RF Power 400.4 amp, sound deadened, Whistler pro remote radar detector, scangauge II, debadged, Sockmonkey decals, blacked headlights with FX-R projectors, DDM Tuning HID fogs, Grillcraft upper and lower MX grill with Hella 500ffs converted to HIDs behind, AFE Stage 2 Cold Air Intake, Walbro 255 Fuel Pump upgrade, Dynomax Super Turbo muffler, Bestop Supertop, Wet Okole seat covers, Weathertech floor liners, Pop & Lock tailgate handle, Lighted 4x4 switch mod, 2 110v AC outlets in cab mod, Always at 400W mod, Maplights on with dome light mod, homelink in headliner mod, foglight
    I performed this mod this weekend. I found it much easier to remove the nuts holding the fuse panel in place, fold the fuse panel down, and reach behind it to remove the entire harness by disconnecting the 3 plugs. Spliced in my switch then re-hooked everything back up. Awesome mod though, thanks for the writeup! :thumbsup:
  4. Jul 11, 2011 at 6:32 AM
    #64
    Eltacos
    Eltacos Well-Known Member
    BFE CA
    TRD Off Road
    LED conversion on every accessible bulb, TRD exhaust (dealership threw in for free along with the Blu-Logic).
    I just pulled the pin for the red/green wire and insulated it with heat shrink tubing. I didn't want the DRLs at all. If need be I can pull the insulation off and re-insert the pin to bring the DRLs back.
  5. Jul 11, 2011 at 9:50 AM
    #65
    Crom
    Crom [OP] Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    Thanks for reporting that. I modified the OP and quoted you. It would be much easier to do that. :)
  6. Sep 11, 2011 at 1:20 PM
    #66
    jordando89
    jordando89 Well-Known Member
    jordan
    idaho
    2008 white double cab long bed sport 4x4
    3in lift painted sport wheels
    any one know how to do this but hook it up with the trail maker lights on steering column?
  7. Sep 25, 2011 at 7:01 PM
    #67
    BrettA2
    BrettA2 New Member
    Brett
    Orange County CA
    09 PreRunner
    CROM and others...thanks for all of the info you posted on this topic. I was able to complete this mod this weekend and it went real well. I did it on a 2009 Tacoma. Hooked the lights up to a Toyota OEM switch as well.
    Thanks again...this is a great community!
  8. Sep 25, 2011 at 8:09 PM
    #68
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Glad it worked out for you!! Stick around, much more great info on TW!!!:D
  9. Sep 25, 2011 at 8:18 PM
    #69
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Nice write up. Subbd
  10. Sep 26, 2011 at 11:58 AM
    #70
    Eltacos
    BFE CA
    TRD Off Road
    I am confused what "trail maker lights" are.
    I am also subd' to this thread. Mine are disabled by pulling the pin and insulating the pin to avoid shorts. I am still debating on adding a switch, as having them on would disable my switchback LEDs mod.
  11. Sep 26, 2011 at 12:04 PM
    #71
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Just a heads up, be careful when you are wiring this mod up, I wired something backwards and fried something on the truck cause my DTRL's dont work anymore. I replaced the DTRL relay and wiring harness and still nothing so they are permanently disabled. I checked all fuses and found nothing. Everything else still works though, parking lights, turn signals and hazards so I dont know what I messed up.:cool: Anyone know what could have happened?
  12. Sep 26, 2011 at 3:15 PM
    #72
    Crom
    Crom [OP] Outside
    Nick
    San Diego, CA
    Millions
    Glad you found it helpful. :) Welcome to the forum. :wave:
    I'd check the wire that goes from the Body ECU to the junction block. Check it to make sure there is continuity all the way through (no short in it). If it burned up, then that is your problem. See this diagram posted in the OP here: http://www.tacomaworld.com/forum/technical-chat/84105-dtrl-toggle-switch.html It's the Light Green w/ black tracer wire.
  13. Sep 26, 2011 at 3:23 PM
    #73
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh okay got yah. Yeah when I have some time I will have to try this out and see if its the wire thats burnt out. Thanks for the info!!;)
  14. Oct 15, 2011 at 12:06 PM
    #74
    Murman
    Murman Well-Known Member
    North Carolina
    2011 Prerunner SR5 Access Cab 4cyl auto
    Undercover hard tonneau WeatherTech Floor Liners
    I did this mod today after reading just the first page of this thread. I didn't feel like removing part of the dash to get to the back of the fuse panel so I tried to find out where the green and red wire went. I traced the other end of it to the box attached to the passenger side of the fuse panel (photo 1). Unplugging the connector from the box (photo 2), I was able to pull the wire harness down from behind the dash and do my splicing out in the open (photo 3). I thought I had found an easier way to do this until I just read the rest of this thread. Anyway, here are my photos, maybe they will help someone.
  15. Oct 15, 2011 at 10:55 PM
    #75
    Crom
    Crom [OP] Outside
    Nick
    San Diego, CA
    Millions
    Murman, I love it. That rocker switch is great. I'm going to update the OP to link to your post and pics. Very good!
  16. Nov 19, 2011 at 10:23 AM
    #76
    three west
    three west Well-Known Member
    JD
    UP MI
    09 DC SB TRD Sport
  17. Nov 19, 2011 at 12:46 PM
    #77
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
  18. Nov 19, 2011 at 12:57 PM
    #78
    three west
    JD
    UP MI
    09 DC SB TRD Sport
    yeah, just off the fuse block eh?
    I was thinking if I knew the pinouts of the neighboring lit switches that would be easy too
  19. Nov 19, 2011 at 1:11 PM
    #79
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah just off the fuse block. I just used an add-a-fuse line and tied into one of the active fuses.
  20. Nov 21, 2011 at 11:10 AM
    #80
    three west
    JD
    UP MI
    09 DC SB TRD Sport
    ok, done
    couple notes for those that haven't done this yet
    personally I found it easier to just unplug the whole harness that we're tapping into, its only 3 plugs and its less than a foot long. Pulling it out & tapping into it was way easier than trying to snip & re-connect stuff way up under the dash.
    also, remember that if you have a switch that lights with the circuit that this wire we're tapping doesn't carry any juice, its just a ground wire, so if you want a lit switch you're going to have to supply your own juice.
