Dual Battery Questions.
Discussion in 'Technical Chat' started by Ferball, Apr 8, 2022.
  1. Apr 8, 2022 at 7:21 PM
    Ferball
    Ferball [OP] Well-Known Member
    Brent
    Unity, New Hampshire
    2019 Cement TR5
    I have been doing my research for a dual battery setupf for camping, and now I have questions. I was planning on using a smart isolator and run a parallel charging setup. Then I learned about "smart alternators" I am thinking my plan won't work. What are the downsides of disabling a smart alternators? Could I just tap the charging pin on the trailer plug to charge my second battery? Or can I tap off the bed inverter before the inverter and this will give me enough voltage to charge a second battery? I know the easy answer is just plug a charger into the bed inverter, but is it as simple as that?
  2. Apr 8, 2022 at 7:26 PM
    MGMDesertTaco
  3. Apr 8, 2022 at 7:28 PM
    MGMDesertTaco
    On second thought you might want to look into an aftermarket tune that will bump the ecu alternator charge voltage up for agm batteries. A tune might offer the answer you're looking for.
    Bastek likes this.
  4. Apr 8, 2022 at 8:01 PM
    Ferball
    Brent
    2019 Cement TR5
    I had simple solar set up on my previous truck. I upgraded to sn access cab and there are no roof rack options that don't involve drilling holes in my roof so the simple idiot in me thinks there has to be a simple and cheap way to put juice into my charge controller from the truck instead of a panel when driving, and when not driving I can set my panel up and use that to feed my charge controller.
  5. Apr 25, 2022 at 12:14 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    MGMDesertTaco likes this.
  6. Apr 25, 2022 at 12:19 PM
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    What are you trying to power?
    I run a single agm battery
    Kd max tune accordingly
    Cascadia 4x4 solar panel on the hood
    This all allows me to effortlessly run my 45l fridge and even run camp lights for the evening with no issues to crank up and go the next day.
  7. Apr 27, 2022 at 10:03 PM
    4-Day-Work-Week
    4-Day-Work-Week Well-Known Member
    2022 OR DCLB Army Green
    What size battery are you running? I am getting ready to permanently install a Iceco VL45 for work that will be run to my starter battery. I’ll have a Lensun 85w panel to keep stuff topped off for this daily driver.I’m trying to figure out if I need to move to a group 31 (battery tray as well) or if I can run an AGM in stock size.
  8. Apr 28, 2022 at 3:14 AM
    codyjphoto
    Cody
    2015 gx460
    A bunch of junk
    I'm running a 55ah, never had an issue
  9. May 7, 2022 at 2:57 PM
    cactushead
    cactushead Well-Known Member
    San Diego
    2017 MGM DCSB 4x4 TRDOR
    Front hitch, 5100's, 885's, Snugtop XV, Slimline II, Sumos, bed platform, AAL, interior LED lights in cab and bed, exterior camp/backup LED's, Rigid DOT Fogs and D2 Pro Spots, Mega Ultra +130 bulbs, heavy-duty fog light, spot light, and low beam wiring harness, Weathertech mats, Re-routed dif breather and A/C drip line, dash cam, front and side cameras, anytime rear camera and nav, Blue Seas fused bus bars to cab and bed, heavy-duty bus bar w/Anderson quick disconnects under the hood for powering winch, solar, air compressor, and other accessories.
    4-Day-Work-Week likes this.
  10. May 8, 2022 at 3:10 PM
    cactushead
    San Diego
    The short answer is YES, a stock 24 AGM will work, as long as your battery is getting charged from either your alternator or SCC.
    My first solar setup was designed around a 20w mppt charge controller, an X2 24F AGM deep cycle primary battery, and a 100w panel. This configuration worked fine with my Dometic CFX-40 fridge, as long as I got a few hours of sun.
    Unfortunately, my primary parking space at home is in the shade. If I didn’t drive for a few days, I felt compelled to move my truck to a spot in the sun. That’s why my solar redesign included the addition of an auxiliary 100ah LiFePO4 battery and a DC-DC charger.
