Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Jun 19, 2017 at 1:40 AM
    #1641
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Folks have moved the PS reservoir a few inches to fit a tray there. I relocated the air duct and put a Wirthco tray in the space below it. I have a 2007; so, I don't know how different your engine compartment looks like. The other problem with doubling the two batteries together is the extra weight - you have the gas tank, driver, steering, and battery on the driver side, with not too much counter weight on the passenger side.
  2. Jun 26, 2017 at 12:17 PM
    #1642
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Panel: Renogy 100watt monocrystaline, pwm charge controller
    Meter: G.T Power Rc meter inline between solar panel and charge controller
    Load: Fully charged house and starting battery. Starting battery load of Ignition turned to On position with radio, fan, and headlights on, House battery load of a "go pro" and 12v led work light.
    Test 0: Full sun
    Result: 12.97v, 5.28a
    Test 1: Partially shade panel (~20%)
    Result: 13.18v, 0.35a
    Test 2: Fully cover panel (~15%)
    Result: 11.57v, 0.00a voltage changed with different positions of tarp but no current was recorded.
    Test 3: Fully cover panel (~30, 60, 90%) and check output amperage/voltage
    Result: no reading, I changed the position of the tarp which made little difference. Sometimes the meter would light up but not have enough power to function.
    Conclusion:
    A fully covered (percentage) panel will not produce enough voltage/current to power a device or charge a battery.
    A partially shaded panel will produce voltage but may not produce enough current to power a device or charge a battery.
    Bastek, tacomgee, Whitecloud and 5 others like this.
  3. Jun 27, 2017 at 4:09 PM
    #1643
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Has anyone found any reliable info on replacing the voltage limiting diode?
    I've heard that you can buy something on eBay from Australia for $50 but I can't find anything.
  4. Jun 27, 2017 at 4:24 PM
    #1644
    Sandman614
    Tim
    '06 SR5 Off Road
  5. Jun 27, 2017 at 4:54 PM
    #1645
    Iggy
    Northern CA
    Check out the build
  6. Jun 27, 2017 at 7:44 PM
    #1646
    chops749
    chops749 Well-Known Member
    Dan
    Huntersville, NC
    2017 DCSB TRD OR Super White
    SSO Slimline Bumper Smittybilt 10K Winch ICOM ID-5100 Prinsu Design Cabrac Caliraised LED 40" Light Bar Alu Cab Topper Rhino Rack Batwing Awning
    My head is hurting right now from reading this thread. So much good info. I do have 1 question. If I run my arb fridge off of my single battery, and plan on running my rig everyday, do I need to worry about killing my battery?
    foxrcing07 likes this.
  7. Jun 27, 2017 at 8:00 PM
    #1647
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    no sir, but we do recommend having a deep cycle battery
    chops749[QUOTED] likes this.
  8. Jun 27, 2017 at 8:50 PM
    #1648
    chops749
    Dan
    Huntersville, NC
    My eventually goal is a dual battery setup but should I go it. Deep cycle for now? My truck is 6 months old so I don't want to buy a new battery if I can avoid it
  9. Jun 27, 2017 at 8:53 PM
    #1649
    ramonortiz55
    Ramon
    Texas
    stock
    if youre not going to get a deep cycle, i suggest to carry a reliable jump starter, just in case.
    i have my whynter fridge plugged in on two or three day camping trips with my deep cycle battery without issues..and the whynter has more draw than the arb..
    no issues.
    ive never tried it on a stock battery.
    i suggest a jump starter, as mentioned above.
  10. Jun 27, 2017 at 9:01 PM
    #1650
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Without getting into how deep is deep (subjective), regularly discharging a starting battery will eventually kill it. Starting batteries are not designed to take a discharge like deep cycle batteries.
    Sandman614 likes this.
  11. Jun 27, 2017 at 9:03 PM
    #1651
    chops749
    Dan
    Huntersville, NC
    So what battery do you suggest?
  12. Jun 27, 2017 at 9:05 PM
    #1652
    Sandman614
    Tim
    '06 SR5 Off Road
    A starting battery with a solar panel would probably make a half way decent setup.
  13. Jun 27, 2017 at 9:12 PM
    #1653
    Digiratus
    Roaming the PNW
    The RedHead
    The least expensive will probably be an Optima Yellow Top but there are any other choices. In general an AGM type is recommended.
    I am quite happy with my dual Northstars but Northstars are not inexpensive. Maybe Ramon @ramonortiz55 will do another (#5) GB on them soon. :notsure:
  14. Jun 28, 2017 at 10:29 AM
    #1654
    chops749
    Dan
    Huntersville, NC
    Do you still have your spare battery in the bed?
  15. Jul 9, 2017 at 12:57 PM
    #1655
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Those with an ML-ACR, quick question...
    Thought the cooler weather I could hear the audible disconnect within 15 seconds of turning the truck off.
    I've noticed the last few days it doesn't disconnect, even after 15 minutes or so.
    The red led on the remote stays on as well. I have to imagine this is also maintaining draw on the battery.
    Any idea what would be causing this? Is it normal?
  16. Jul 9, 2017 at 1:10 PM
    #1656
    Iggy
    Northern CA
    Check out the build
    That's normal. It means there is no draw in either battery and the voltages are stable. They only disconnect when something draws from on battery and there is no charging current.
    OneFastGeek and seoulja99 like this.
  17. Jul 9, 2017 at 1:12 PM
    #1657
    Kennedyusmc
    Christopher
    2017 Cement Pro
    So even when the truck is off- "no charging current" it will stay on for a while?
  18. Jul 9, 2017 at 1:14 PM
    #1658
    Iggy
    Northern CA
    Check out the build
    Yes, it's all automatic. If it stays in the voltages are equal on he batteries.
    If you want to test it, keep your truck off and turn on your high beams. They will disconnect soon after.
  19. Jul 9, 2017 at 4:14 PM
    #1659
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    @Kennedyusmc what ^^ @Iggy said x2. Completely normal.
  20. Jul 20, 2017 at 6:26 AM
    #1660
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Alright I can finally contribute to this thread.
    I used the blue sea ML-ACR with the switch. I have this mounted on the palfrey battery cage for the starting battery. I have a unfused run from the starter battery to the relay.
    My second battery is mounted in the bed. I decided to put the fuse (150amps) at the second battery. Here is a picture of the battery mounted in a tray that I made using some 1/4 inch aluminum.
    I use my traction boards to keep stuff from hitting it and keep everything protected.
    Now, I have solar setup in this as well. All that is in the cap tool box. So my solar panel is mounted on the roof rack and I used a marine deck grommet to run all the wire into the cap. I used a trailer wire harness which has a cord with 4 12 gauge wires in it. I have one common ground and 3 wires. One of the wires is for the solar setup and the other 2 are for lights.
    solar and wire run
    the switch panel I put together with the solar controller to the left and the terminal posts to the right with my 100 amp breakers for the auxiliary fuse panel the inverter.
    In the cab of the truck I have the blue sea switch, a dual battery monitor that was suggested in this thread (thank you), and a usb thats live all the time. All of this is mounted in @Iggy switch panel from iggycorp. Really cleaned everything up and made this a hell of a lot easier.
    Here is a picture when the truck is off, and the solar is charging both batteries.
    With the truck on
    The wire I used was all 1/0, with marine grade lugs that I crimped on.
