Dual Optimas!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ryhar85, Mar 9, 2010.
  1. Mar 9, 2010 at 8:46 PM
    ryhar85
    ryhar85 [OP] Well-Known Member
    W. WA
    05 TRD 3" lift
    3" Trailmaster lift, 18" rockstars blacked out, 275/65/18 sxt mud terrains, more to come.
    So my factory battery finally crapped out the other day. Guess what I can now justify to myself? That's right :D :
    I will get some better pics up, as well as some of the process tomorrow. I am not quite finished with securing them yet. I am gonna add two more studs like the ones in the middle to each end.
  2. Mar 9, 2010 at 8:48 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    05 TRD Sport 4x4 SR5 V6
    Garage Fabbed +2 LT, FOA 2.5 RR w/ Comp Adj, 35 XMTs on Level 8s, 50T Spring Under w/ 13" Shackles, Elite Front Bumper, AP Rear, Retrofitted, Wicked Flow, Custom Roof Rack, Custom Sliders, Custom Scratches, 12" JL and an Audiopipe amp.
    I like it!!! i should of done this, i didn't think two batteries would fit. Nice!!!
  3. Mar 9, 2010 at 8:53 PM
    sethr21785
    sethr21785 Well-Known Member
    Seth
    Windham Maine
    09 TRD SPORT
    TRD Short Throw, TRD Exhaust, 5100 1.5, Weathertech floor liners, AFE Filter, Projector Head and fogs, Weathertech vent visors
    What are you running that req two batteries?? You have a huge amp or winch or something??
  4. Mar 9, 2010 at 8:55 PM
    ryhar85
    W. WA
    05 TRD 3" lift
    Thanks! Yep, they fit just right. Just took a little bit of finesse ;).
  5. Mar 9, 2010 at 8:57 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    Hmmmm, now you got me thinking
  6. Mar 9, 2010 at 8:59 PM
    C17Guy
    C17Guy Well-Known Member
    Dennis
    Charleston, SC/ Charlotte, NC
    09 SR5 Access Cab 5 Lugger
    Readylift Kit, 245/75/16, HID's, Debadged, Kenwood DNX9960 Double Din Navigation, Image Dynamics Door Components, Pioneer Amp, Dynomax Super Turbo Muffler, Grillcraft Uppers and Lowers
    I don't get it... can someone explain the benefit to me? Big audio? Are they both being charged by the alter. and used?
  7. Mar 9, 2010 at 9:00 PM
    ryhar85
    W. WA
    05 TRD 3" lift
    Main reason is for the camper, Which runs only on 12v. And in anticipation of more power sucking goodies in the near future.:D
  8. Mar 9, 2010 at 9:04 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    like a glove!
  9. Mar 9, 2010 at 9:06 PM
    sethr21785
    Seth
    Windham Maine
    09 TRD SPORT
  10. Mar 9, 2010 at 9:07 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I have one of these and didn't quite think it sucked as much as it did... within minutes my battery was dead - Pretty stupid of me...
  11. Mar 9, 2010 at 9:12 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    that thing is insane, what did u pump up?
  12. Mar 9, 2010 at 9:14 PM
    ryhar85
    W. WA
    05 TRD 3" lift
    ^^ That is a sweet unit! OBA is a future mod for me, for sure. What all does that thing do? Just air?
  13. Mar 9, 2010 at 9:58 PM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    Just curious here, but if it's for goodies like a camper, why'd you go with red tops instead of the deep cycle yellows?
  14. Mar 9, 2010 at 10:13 PM
    HBMurphy
    Paul
    So California Coast
    None
    Just air but nicely. I was sick and tired of the other ones where their performance drops like a rock after you take it out of the box.
  15. Mar 9, 2010 at 11:08 PM
    ryhar85
    W. WA
    05 TRD 3" lift
    Well I wanted a red for daily use, and for the time being I am running them in parallel, so I needed two of the same ones. I hope I don't regret not going with yellows, but I honestly don't think I will. If in the future I decide to isolate them, I may want a yellow as the aux. . . but not sure.
    Nice!
  16. Mar 10, 2010 at 11:58 AM
    bmgreene
    Brian
    L.A. Westside
    I've never tried running dual batts myself. Is there a problem associated with mixing regular/deep cycle when they're paralell? I would've thought that as long as the voltage is the same you should be able to mix/match.
    I've been running a red top in my other car for about 6 months now and am very happy with it, and will almost certainly go to some type of Optima when the stock batt in my taco gives up the ghost (currently the truck is 3 months old and has 2k miles on it so it'd be a waste to swap out at the moment). I've seen some mixed reviews on the red's ability to recover from too much discharge though. Hopefully you won't run into any problems with yours.
    Might even be better to run a yellow on the engine with a red for aux, though since your accessories won't need anywhere near the cranking amps that the starter draws, and could most likely run fine on a battery that's too discharged to turn your engine over in the morning. The way I understand it, the main advantage of the deep cycle is the ability to push big amps at a lower charge level.
  17. Mar 10, 2010 at 12:21 PM
    HBMurphy
    Paul
    So California Coast
    None
    Actually Deep Cycle batteries are designed for 'deep cycle' use like a wheel chair, trolling motor, boat or motor home where ppl may use the dc w/o generator running, etc. They can withstand a 'deep cycle' and be recharged where a std battery would get beaten up with that type of cycling.
  18. Mar 10, 2010 at 12:30 PM
    ryhar85
    W. WA
    05 TRD 3" lift
    ^^I was told never to run different types of batteries in parallel. Something about different charging patterns will constantly be trying to equal each other out, creating a drastically shorter lifespan. Even that the same type of battery hooked to an older one can create this situation. That is why I bought two, even though I wont really need two for a few months, I wanted to make sure they where both new when I hooked them together. And this way I don't have to mess with isolating them if I don't want to.
  19. Mar 10, 2010 at 12:45 PM
    ryhar85
    W. WA
    05 TRD 3" lift
    I guess the pics are a little hard tell, But there is at least 3" maybe even 4" before contact with the oil filter. The only thing that is 'too close for comfort' is by the corner of the radiator support, but that doesn't shift, and I already got shorter terminal bolts that will give about another 3/4" more clearance on top of the 3/4" it already has, just for a little extra peace of mind.
  20. Mar 10, 2010 at 12:54 PM
    ryhar85
    W. WA
    05 TRD 3" lift
    Much appreciated. You never know when someone will catch something you overlooked. ;)
