E LOCKER FOR 3rd gen?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MaxTruck, Mar 19, 2017.
  1. Jul 31, 2020 at 7:43 PM
    ssoulssurfer
    ssoulssurfer Well-Known Member
    1998 Tacoma 4x4 SR5 TRD MANUAL TRANS 3.4L V6
    2.0 FOX COILOVERS FRONT, 5100 BILLSTEINS REARS
    Back to original question, if one had to get an E locker for the rear on a brand new tacoma sport, what would be best choice?
    I live in Nome Alaska and people say since it gets so cold here the air lines won't function properly on the ARB locker.
  2. Jul 31, 2020 at 8:13 PM
    outlaw_taco
    outlaw_taco Well-Known Member
    Houston
    2021 moon rock
    Buy the Offroad
    shakerhood likes this.
  3. Jul 31, 2020 at 10:18 PM
    ssoulssurfer
    Ok, again, me like others want extended cab, v6, manual. Looks like only option is the sport...
  4. Jul 31, 2020 at 10:31 PM
    theluharlifestyle
    theluharlifestyle Well-Known Member
    Parth
    SoCal
    2019 DCSB TRD OR
    You might want to check to see if a OR or Pro will fit, I think they come with a 8.75" rear end vs 8" for the limited. Maybe an Elocker from the 2nd gen? Either way, if i was gonna add a locker I'd go ARB
    whatstcp likes this.
  5. Jul 31, 2020 at 10:42 PM
    IdeaMan
    IdeaMan Well-Known Member
    Jim
    Fresno, CA
    Barcelona Red 2018 Toyota Tacoma SR DCSB 4x4
    Eibach Pro Truck Lift, Icon RXT Leaf Springs, LT255/80R17 Toyo ATIII, Body Armor Hiline Bumper w/OZ LED Light bar and Smittybuilt X20 Synthetic Winch, TRD Pro Skid plate, Shrockworks Sliders/steps, bed mat, some interior storage accessories, cell phone mount, and blacked out emblems.
    I have looked into this several times as well, and I like the idea of the Harrop E-Locker. Click here to see a thread about it. Not a lot of people running them but it seems to eliminate the hassle with air lines and such that you have with the ARB and engages better than the factory OEM E-Locker that comes on the Off-Road and Pro. Click here for some 3rd gen guys that have the Harrop.
    theluharlifestyle likes this.
  6. Aug 1, 2020 at 1:27 PM
    ssoulssurfer
    Thanks those are some great threads. Sounds like a good locker. Probably only thing to change as others have mentioned might be to either put master switch, or push button style, instead of rocker switch.
    You still need to stop, put in neutral, to engage right?
    I guess just not entirely clear since it looks like Harrop doesn't exactly offer 2015+ Tacoma lockers... but that Mike's Custom Toys says they do?
  7. Aug 1, 2020 at 1:40 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    One of the reasons I traded in my 2016 SR5 for a 2020 OR was because of the price of an aftermarket locker. The other reasons were the manual transmission and ATRAC. Although, I have no personal experience with other lockers, I can attest that the OEM locker can be finicky about engaging and disengaging. It’s best to lock it before you get stuck.
    I have also done a number of experiments of the ATRAC vs ATRAC+locker and never found the locker helped anything. Most of these experiments involved mud and/or snow; not big ass rocks where wheels were leaving the ground. My thought for why this was the result is that the front axle has much more traction than the rear (in most cases) because of the uneven weight distribution. The truck is helpless unloaded in 2wd. A front locker might make a bigger difference.
  8. Aug 1, 2020 at 4:35 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    No, it's fine to engage any diff lock at any speed as long as the two wheels are rotating the same speed. Don't engage at speed in a tight turn or while one wheel is slipping/spinning. And don't engage a front at speed when the ADD is disengaged.
  9. Aug 1, 2020 at 9:57 PM
    ssoulssurfer
    Thanks didn't know that.
    Thought I read before on the Toyota card thing that came with my 1998 that supposed to stop to engage/disengage, as well as only using <5 mph
  10. Aug 1, 2020 at 11:33 PM
    Brofessor
    Brofessor Well-Known Member
    huh?
  11. Aug 6, 2020 at 10:14 AM
    fuzzydoodle
    fuzzydoodle Well-Known Member
    Jordon
    Arlington WA
    2016 Inferno Double Cab TRD Sport
    Just poking around in here, separate idea, same concept.
    I picked up a wrecked OR frame, from a manual, with both diffs and 4.30 gears. I'm going to throw those in my sport to re gear it, and get the bigger rear end at the same time. But it's got the e locker in it, I'm thinking of wiring it up to a factory style switch in the cab, my question is, anyone know what size relay I should use for that?
    The cabs got some relays on it still, so I've probably got some factory options, or just grab any old relay. I've got some solder and don't mind the leg work.
    Thanks boys.
  12. Aug 6, 2020 at 10:19 AM
    eon_blue
    Azusa, CA
    The Toyota TRD e-locker on my 04 still works great to this day. I don't understand the hate around the TRD e-lockers, although it's well known that they don't work well after a number of years if you rarely use them. But that can be true about a lot of things.
    The one thing the ARB has over the TRD e-locker is that it locks almost right away when you engage it. The TRD one sometimes takes a few seconds or a few feet of driving to line up. But I've rarely had that be an issue, I engage it before I need it not after.
    And virtually everyone I've known with an ARB has had seal/air leaks or problems with the air lines at some point. They aren't perfect either
    edit - sorry meant to quote the other guy but..meh. It was a 3 year old post anyway lol.
  13. Aug 6, 2020 at 10:26 AM
    mchertel
    mchertel Well-Known Member
    Mark
    Colorado Springs CO
    2020 Tacoma Off-road
    Toytec 2 inch boss lift
    Unless your compressed has an issue, there are pro's and cons to all types.
  14. Aug 6, 2020 at 11:21 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    The factory OR e-locker never sees 12 V when used on a 3rd gen.
    The ECU provides less than 12V to the e-lock coil, with a lower voltage when the coil is locked and higher voltage when unlocked.
    I have been recommending people step down the voltage to the coil by adding a resistor or PWM circuit, and a flyback diode. Will the e-locker be fine at 14V? I dont know.
    Can dig up the other threads if you want to go down this path...
  15. Aug 6, 2020 at 11:30 AM
    #35
    fuzzydoodle
    Jordon
    Arlington WA
    Thanks for that info, i tried doing a little searching, but didn't see any with exactly the info I was looking for aside from this thread, that was old, but had some recent activity.
    So you're thinking no relay, but maybe a resistor?
  16. Aug 6, 2020 at 11:34 AM
    #36
    BigWhiteTRD
    Ted
    Still need a relay, so switches dont have to carry ~10 amps
    Take a look at this
    https://www.tacomaworld.com/threads/2017-e-locker.585669/
  17. Aug 6, 2020 at 11:51 AM
    #37
    fuzzydoodle
    Jordon
    Arlington WA
    Cool, thanks a lot man. I'm not awefully familiar, and by that I mean not at all, with a flyback. So, I'll look into it. I have to truck aide harness too, so I can grab the plug, and run those two wires up to a relay. Then I'll just do my research with that info you sent to find out where to put the resistor and flyback in. I assume between the switch and the resistor, if i understand its to stop any spike from the switch on and off?
  18. Aug 6, 2020 at 12:02 PM
    #38
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    @AY_ARONTRD just had a Harrop e-locker installed in the front diff of his 2019, doesn't seem to be a version for the 8.75" rear diff the 3rd gen has. The 8" diff on some 3rd gens is supported.
  19. Aug 6, 2020 at 12:58 PM
    #39
    Dc2tacoma
    Dc2tacoma Well-Known Member
    Might as well regear also if you’re adding a locker. Two birds and you’re ready for 35” tires.
  20. Aug 6, 2020 at 1:02 PM
    #40
    ShimStack
    Ben
    NC
    The flyback diode goes across the power leads to the lock solenoid to give the voltage spike somewhere to dissipate when the field crashes after removing power. https://en.wikipedia.org/wiki/Flyback_diode
    I just did a couple data logs of the stock Toyota control to the solenoid. I'll get those pulled from the other laptop and you can see exactly what it gets.
    IMO, the solenoid can handle 12V-14V all day no problem (I gleaned this opinion from documentation somewhere I think) but it's just not necessary to hammer it with that much continuously and waste all that power and generate all that heat.
