eBay Halo Projector Headlights Retrofit
Discussion in '1st Gen. Tacomas (1995-2004)' started by BartMaster1234, Sep 6, 2016.
  1. Sep 6, 2016 at 5:47 PM
    BartMaster1234
    BartMaster1234 [OP] American Auto Horns
    Tyler
    San Francisco, California
    Flux Capacitor
    I was planning on replacing the headlights on my taco with some new projector lights (and I don't have enough to go for LSC15's quality retrofit services).
    I was looking at these two assemblies:
    Black Assembly
    Silver Assembly
    They're about $160 for a set. Are these a good idea to install? Am I overpaying? I can't seem to find an assemblies cheaper than these. One more thing, I wouldn't have to alter the fuses or factory wiring harness correct? I'm not too sure (don't want my fusebox to catch on fire).
    Thanks for your help.
  2. Sep 6, 2016 at 6:45 PM
    CaptainMorgan
    CaptainMorgan Custom headlight retrofits
    Mesa, Arizona
    2014 White Tacoma TRD Sport
    17 inch Black Rhino Rockwell Wheels, BFG 275/70/17 Ko2 Tires, 3 Inch Rough Country Front lift 2 inch Rough Country Rear Lift
    I would avoid those kind of prefab headlights at all cost Theyre all garbage with fake projectors and if the come with halos, the halos are dull white/greenish and usually burn out in a few months if they last that long.
    If you want to do projectors, I would just save up and have a proper retrofit done or do it yourself, should be really affordable since you have a 98 and replacement headlight housings are cheap
  3. Sep 6, 2016 at 7:28 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It doesn't have to be completely top of the line, just something better than the stock headlights that will last a while. How hard would fabricating them myself be? Where would I start? I'm not looking to spend much, no more than 165.
  4. Sep 6, 2016 at 7:44 PM
    CaptainMorgan
    Mesa, Arizona
    If wanna spend less than $200, i would say either save that money up and buy some headlights down the road, or see if you can find a used set of retros that you can get for cheap, people sell them all the time here
  5. Sep 6, 2016 at 7:44 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    I have these exact ones on my truck....
    If you like to see well at night these are not a good setup lol. They have been on the truck for about two years. All the halos and bulbs still work fine but the output is not quality. You can get different/brighter bulbs through that vendor though. I'm probably going to go back to stock style headlights eventually or diy my own projector set-up. The ones that Logan makes are sick but I just don't want to drop that kind of money on headlights.
    Search these on YouTube and there is install videos for your questions of install.
    CaptainMorgan likes this.
  6. Sep 6, 2016 at 7:45 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Spyder projector headlights are known for having poor output and seals that fail causing the lights to get condensation on the inside of the lens. I would pass.
    What is your goal? Increased output, looks, replacing worn out OEM units?
  7. Sep 6, 2016 at 8:31 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    To be perfectly honest with you, the look. I saw the same exact pair on a taco at Home Depot and I fell in love with them. The stock lights are also getting a little yellowed and decrepit looking. I don't know if I'm ready to drop 400-500 dollars on headlights. Is it possible to just buy the headlight assembly shell and put in your own lights?
  8. Sep 6, 2016 at 8:32 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    How would you go about DIY'ing it? I just want to match the look of the eBay ones.
  9. Sep 6, 2016 at 8:42 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    There is nothing wrong with wanting the look, and it is good to be honest with yourself about what you want to get out of the setup. You could always go with those lights and try running some brighter bulbs to compensate for the performance loss, and then run an extra bead of silicon around the seals as many do, but it will still likely be a cosmetic 'upgrade' and a functional downgrade.
    TRS has all the components for DIY projectors:
    https://www.theretrofitsource.com/components/projectors.html
  10. Sep 6, 2016 at 8:44 PM
    FirstGen Jer
    Jeromey
