ECO Systems VPE Test Results
Discussion in 'Performance and Tuning' started by 007Tacoma, Nov 17, 2007.
  1. Nov 17, 2007 at 5:57 PM
    007Tacoma
    007Tacoma [OP] I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Finally had to give up on the PDF format as it won't fit. Here is the final report on our observations...
    Please Note: The 2.7L PreRunner numbers are not typical. I found out at the end of the test that my AFE oil/gauze air filter had fouled my MAF sensor.
    Neither Adam, nor I work for ECO Systems. We were just curious. ECO Systems lent us VPEs for testing to share. The above report shows our observations.
    Thanks to Adam (maverick491) for conducting the 4.0L test even though his Tacoma isn't his primary driver. He even threw in two extra runs at the end to compare the winter blend of fuel which adds Ethanol to the gasoline.
    Thanks also to Ben with ECO Systems (ECOTAZ) for lending us the VPEs for testing. You can PM Ben for more information on the ECO Systems product.
    We will be arranging a group buy with Ben soon. For those that are interested.
  2. Nov 17, 2007 at 6:10 PM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
  3. Nov 17, 2007 at 6:19 PM
    m3dragon
    m3dragon Well-Known Member
    Sacramento
    WOW that is one in depth test result you made there.
    From those numbers it looks like it works which if it is the case sign me up.
    Group buy
    1. M3dragon
  4. Nov 17, 2007 at 6:29 PM
    PatheticJoe
    PatheticJoe Well-Known Member
    Sacramento, CA
    07 Prerunner SR5 TRD Sport - Access Cab
    Thanks a ton Mav and 007, very thorough test and great presentation of all the data and results. Now you guys can kick back and enjoy the hoilday.
    Group Buy
    1. m3dragon
    2. PatheticJoe
  5. Nov 17, 2007 at 6:58 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Just a few closing notes related to the 4.0L tests.
    Most of the tanks reported on in my portion of the test were 92 octane from my favorite local gas station. The ones when I was away from home were whatever the super was at those stations. Never less than 91 octane, and never higher than 93.
    Anything in my portion of the test labled as towing was with a 2006 Jayco Jayfeather Sport 197 in tow. It's wet and ready to camp weight is right around 3500 Lbs. It presents a frontal area of 7' 5" wide by 10' 9" high.
    Based on that information I have concluded that towing is a wash more or less, I believe that there is just a point where the air resistance of the trailer does more to dictate fuel consumption than does the engine of the tow vehicle or any devices attached to it. Also, there are just too many variables in towing, such as head winds or tail winds, upgrades, or downgrades, not to mention the time spent with the engine idling while checking into the campground at the office, and backing into the campsite. So please if you tow regularly expect your towing mileage to remain roughly the same.
    An important note about tanks 11 and 12. I intended to conclude my testing of the ECO-2 VPE with tank 11. However, that run took place after the change over to winter blended fuel, so just to make sure that I did a thorough job of it I removed the VPE and re-ran Tank 11. Tank 11 and Tank 12 are the exact same loop under as close to identical conditions as the New Jersey Turnpike would permit, and they were only done two days apart. My point is that I believe that these two tanks are closer in mileage than they really should be, because while I did wind up stuck in a roughly 2 minute longer traffic jam on tank 12 then on tank 11, the highway was much more crowded during the tank 12 run than it was during the tank 11 run. That means that I was forced to accept a little more drafting from semis and other automobiles on tank 12 while I was able to keep the truck’s nose into the wind much more on tank 11. While this is not as scientific as it could be I have spent $50.00 on fuel and $7.50 on turnpike tolls over 3 days for no reason other than trying to do my best to perform this test, so this is as good as it gets.
    I have complete data on all the test tanks such as driving speed, max speed, and average speed as well as driving time and stopped time. If you want that information let me know and I'll send it directly to you, but I do not want to clog up this thread with it as there is already a huge amount of information here for you to digest.
    I thank everyone for their support, and patience while we conducted this test, and I espescially want to thank 007Tacoma for getting the ball rolling on this as well as creating the final report file, Manofs for bringing this up in the first place, and EcoTaz for loaning us the units to test.
  6. Nov 17, 2007 at 7:54 PM
    pivitol
    pivitol Well-Known Member
    Colorado
    99 SR5 TRD Off-Road V-6 4WD de-flapped
    I want to thank both Adam and Mark for taking the time, money, and effort to do this. But I have to say I am glad it is over I was getting really pissed at some posts on the other thread. Many times I had typed in a response in a blind fury and deleted it in fear of being banned from the forum. Great Job and thanks again!!
  7. Nov 18, 2007 at 2:00 AM
    cvillechopper
    cvillechopper Jackass to the masses
    Charlottesville, VA
    '24 DCSB TRD Off-Rd, Premium Package
    Console lock-box, Studly Driver
    Thanks to both of you. Great presentation of the data. Would it be possible to get the details so I can run some analysis and use as a base for the data I'll start collecting on my truck. I'm a numbers dork.
    Thanks again for all the work.
  8. Nov 19, 2007 at 8:19 AM
    boks
    boks From Michigan!!
    Michigan
    2020 4WD TRD-Offroad Double Cab
    Rhino RTS ditch mount roof rack tracks Truxedo Lo Pro tonneau cover Yakima tracks on Bed rails LED Interior Light upgrade Former Vehicle: 2007 4WD TRD-Offroad Double Cab
    Thanks for this report!! I've been a lurker on the "other" thread while skeptical but positive. Went with the can't hurt, might help theory and just ordered one. Even if it just improved emissions, I'll be happy.
    Thanks again for the report.
    Boks
  9. Nov 19, 2007 at 9:24 AM
    cvillechopper
    Charlottesville, VA
    Thanks for the details. Like boks said, if it can't hurt... Just got an e-mail that it's on its way. Once I get a little time I'm going to get your data into a spreadsheet that I can start to populate with my own and see what kind of trends we can see between both vehicles.
  10. Nov 19, 2007 at 12:03 PM
    m3dragon
    Sacramento
    Just ordered mine with free shipping =)
  11. Nov 19, 2007 at 5:25 PM
    PatheticJoe
    Sacramento, CA
    You didn't want to wait for a group buy? I'm sure the savings won't be substantial but you seemed pretty interested in it.
    EDIT: Stupid me, I just now saw the group buy notice in the other thread.
  12. Nov 19, 2007 at 5:44 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i usually get better mpg than mavericks tanksa anyways...wonder what it'd do for me
  13. Nov 19, 2007 at 10:07 PM
    m3dragon
    Sacramento
    You are FIRED!
  14. Nov 20, 2007 at 6:22 AM
    cvillechopper
    Charlottesville, VA
    I'm trying to gather some specific data to really analyze the trends on gasmileage based on several factors (not just the VPE) and add to the report started by Mav and 007Taco. I'm hoping to get as many data points as possible so we can see some real trends and eliminate as many variables as possible. If you think you might be willing to track a tank or 2 check out this thread and help out.
    Thanks
    James
    http://www.tacomaworld.com/forum/performance-tuning/4052-volumized-gas-mileage-trending.html
  15. Nov 24, 2007 at 7:58 AM
    CiCCaTRiCe
    CiCCaTRiCe Member
    San Diego
    00 PreRunner SR5
    K&N drop in,Spin Tech cat back
    Sounds really great but is it legal in California. California has some wacky laws.. If it is count me in!!
  16. Nov 24, 2007 at 12:23 PM
    m3dragon
    Sacramento
    It should be legal as we have 4 cats on the car so don't worry. Mine is in route and I am in Sacramento
  17. Nov 24, 2007 at 5:39 PM
    gsm
    gsm Well-Known Member
    Raleigh, NC
    08 Tacoma Regular Cab, 2.7L, Impulse Red Pearl
    DIY OEM Fog Lights on anytime, DIY OEM Cruise Control, Removed 2ndary Air Filter, Rear Speakers Mod, Traction Bar/Helper Spring Mod, Red Brake Drums and Rotors, Stainless Steel Exhaust Tip, Door Sill Protectors, Taco Bed Mat, Custom Front Mud Flaps (Mudguards), TRD Bucket Seats (pending)
    I'm not very good at searching posts.
    Where is the thread for the group buy? :confused:
  18. Nov 24, 2007 at 6:22 PM
    maverick491
    South Jersey
  19. Nov 26, 2007 at 3:06 PM
    kalib0y
    kalib0y Well-Known Member
    2008 Toyota Tacoma Rugged Trail
    Any DIY steps for installation yet?
  20. Nov 26, 2007 at 3:15 PM
    jgunccrugby
    jgunccrugby Well-Known Member
    Mount Holly, NC
    13 PreRunner SR5 DBL Cab
    Tacoma Seat Covers, Tacoma Kick Guards, Nerf Bars, Front window tint. To come: Bull Bar
    Can you quickly run a calculation on the cost recovery?
    Just off the top of my head I am thinking it is about 60 tanks of gas, or 30,000 miles before you recoup the cost.
