engine fan sounds like it is slapping something
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marioso, Aug 11, 2010.
  1. Aug 11, 2010 at 6:36 PM
    Marioso
    Marioso [OP] Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    stick a paper in a fan and it makes like a slapping sound right? or another example is riding ur bike when u were little and sticking a flat coke can in the rear tire to give it the dirt bike sound.
    the slapping turns off as i drive but in park, neutral, and reverse it starts again. in neutral it makes the sound and in reverse the sound gets louder as the rpms increase.
    anyone have any experience with this?
  2. Aug 11, 2010 at 6:38 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    You checked all around it for anything hitting it?
    :notsure:
  3. Aug 11, 2010 at 6:40 PM
    Marioso
    San diego Ca
    i felt all the blades and nothing, unless something is hanging from the cover idk what it could be, it changes do if i go on dips, it seems like it grinds even more
  4. Aug 11, 2010 at 6:44 PM
    joes06tacoma
    Joe
    Central Coast, CA
    See if the fan is rubbing on the lower edge of the fan shroud. If it is, search on here for 05 motor mount problem. I really hope that's not what's up with your truck, but it is a common symptom.
  5. Aug 11, 2010 at 6:45 PM
    Marioso
    San diego Ca
    holy fuck! u scared me, so give it to me straight, if it is a motormount (someone else mentioned that to me) what would it cost?
  6. Aug 11, 2010 at 6:58 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    If it is a serious slapping than my guess would also be a motor mount since it is a well known symptom of this problem. The mount usually collapses into the frame. Cost of repair usually depends on what route you wish to take - could be as simple as welding/gusseting the mount or as complicated as needing a whole new frame.
    Hopefully this isn't the issue, but the fan hitting the shroud is a known symptom of a broken mount.
    http://www.tacomaworld.com/forum/2n...tor-mounts-failed-failing-14.html#post2048881
  7. Aug 11, 2010 at 7:02 PM
    hansonian
    hansonian swims with fishes
    Tampa, FL
    2010 Double Cab PreRunner SR5
    Stock
    sounds like a bad mount, i'd look at it before i drove it too much.
  8. Aug 11, 2010 at 7:03 PM
    joes06tacoma
    Joe
    Central Coast, CA
  9. Aug 11, 2010 at 7:20 PM
    Marioso
    San diego Ca
    i hate reading lmao im going to a mechanic tomorrow
  10. Aug 11, 2010 at 7:22 PM
    Marioso
    San diego Ca
    can i see if the mount is broken? i saw the pics of a broken mount, i just dont know where to look
  11. Aug 12, 2010 at 9:07 AM
    Marioso
    San diego Ca
    driver side of my engine cover looks slanted :/ waiting for mechanic to arrive
  12. Aug 12, 2010 at 9:25 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Damn, good luck.
  13. Aug 12, 2010 at 9:27 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2
    Good luck
  14. Aug 12, 2010 at 9:32 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
  15. Aug 12, 2010 at 9:39 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    you can have someone hold the break and put the truck in drive. if they press the gas while holding the brake the engine will lift excessively 3-4". happened to my s10.
  16. Aug 12, 2010 at 9:54 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    schit! pass the popcorn..bro.
  17. Aug 12, 2010 at 9:58 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    did u recently jump your truck? after accidentally launching of the razor back of a dune in Pismo going 65 mph (i literally shat my pants), i landed so hard that I bend the radiator in and pushed the fan shroud closer to the fan, causing the fan blades to strike the bottom of the fan shroud. Dremeling off watever hits is a simple solution :thumbsup:
  18. Aug 12, 2010 at 10:12 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
