Exhaust Leak..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kyledamon, Jan 16, 2019.
  1. Jan 19, 2019 at 5:40 AM
    Apex1
    Apex1 Well-Known Member
    Central CT
    2011 DCSB TRD
    Just did that job.
    https://www.tacomaworld.com/threads/got-exhaust-leak.581553/
    You need a round donut gasket for each joint. They are the same size. I was able to save all the hardware off the manifold, but the 2nd joint on the passenger side hardware had to be cut. I recommend pulling the whole y pipe out of the truck with both cats up to the manifold. You do not have to discomnect the 2nd joint on the passenger side to get the pipe out. Once apart the flange surfaces will bu rusty and cleaning them will open the gap. Find the thickest ring gaskets you can. Spec is 1/8” thick but you can find them a bit thicker. Aftermarket is fine, they are pretty much the same.
    This is the kind of job where the vehicle is down when you go source parts or deal with unexpected hardware issues. Having another vehicle to drive is important.
    KTM753 and kyledamon[OP] like this.
  2. Jan 25, 2019 at 9:00 AM
    kyledamon
    kyledamon [OP] Well-Known Member
    Colchester, VT
    2016 AC TRD OR
    Just got it fixed at a local shop. Took them just over an hour. They said no broken bolts with a little heat and just replaced the gaskets. That’s the best $125 I’ve spent in a long time. World of difference just driving down the road. So quiet and I hope this improves my mpg a little bit.
    TearingOut55, KTM753 and ToxicTwin like this.
  3. Nov 1, 2019 at 5:25 PM
    2016Taco
    2016Taco Well-Known Member
    Greater Toronto Area
    2016 Blazing Blue TRD Sport Upgrade DCLB 4X4
    kyledamon[OP] likes this.
  4. Nov 1, 2019 at 5:47 PM
    kyledamon
    Colchester, VT
    2016 AC TRD OR
    Thanks! I’ve since replaced just about everything underneath but for next time
    Currygoat and 2016Taco like this.
