Exhaust, seafoam, oil & spark plug questions. New to Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cryptoxx, Jul 2, 2015.
  1. Jul 2, 2015 at 6:35 PM
    Cryptoxx
    Cryptoxx [OP] Member
    Craig
    '99 Tacoma SR5 xtd cab
    [Purchased 7-2-15]I think much wider tires. & No others am aware.
    I've pretty much only owned turbo charged cars. . I've wanted a Tacoma for years. . I now have a 99 sr5 v6. I did some reading of past posts and have gathered that seeking to get more power from the truck is not a worthy endeavor. 1) do any of u run yours without your catalytic converter? What was the result?. 2) Are NGK V power spark plugs a good choice? 3) what synthetic oil should I run? And what about running Lucas with it? 4) How do you feel about running seafoam?
    opteron likes this.
  2. Jul 2, 2015 at 6:49 PM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    1. Never have
    2. Stick with stock plugs part k16tr11
    3. I ran seafoam gas tank, intake and engine. It got rid of slight idle search.
  3. Jul 2, 2015 at 6:56 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; mattgecko's Underhood Lighting; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  4. Jul 2, 2015 at 7:55 PM
    ThunderOne
    ThunderOne Banned
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    1. Don't do that, it won't help. Someone reviewed a Dynomax superturbo muffler and said they got 10HP from their Taco, not sure if they're blowing smoke or not. http://www.amazon.com/gp/product/B0...oliid=I2ZUPWBRMQWJ68&ref_=wl_it_dp_o_pC_S_ttl
    2. I used stock and have had no issues. The truck was basically built to run optimally from the factory.
    3. I use Mobil 1 0W-30 with stock Toyota filter, and get about 18/16 mpg with 33s and about 400-500lbs of extra armor/shit bolted/welded/somehow attached to the truck.
    4. Seafoam is garbage. If you want a good fuel cleaner, use Chevron Techron concentrate. If you want to clean out the top-end of your cylinders, look up "water decarbonization". Does the same for less money. Or you could just redline it a few times a month.
  5. Jul 2, 2015 at 8:39 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    95 extended cab sr5
    cxracing turbo, fic6, methanol injection, toytec coilovers, skyjacker leafs, rear 12" 5125s, no-slip rear locker, 35" grabber x3, magnaflow muffler, throttle body spacer, retrofit headlights, trans cooler, bed lined exterior, etc...
    1. Yes, removed it when it clogged on me. Gave me a code which i removed and it hasnt come back. No other changes. 2. Use any quality dual electrode plug 3. some people swear by their high dollar synthetic oil but as long as its changed regularly i dont think you will have issues running a cheaper oil in this engine, Ive used a lucas oil additive with a "seal conditioner" in my rear diff and was surprised to see it stopped my seeping pinion seal. 4. Ive used seafoam a few times... not sure if it improved anything or not...
  6. Jul 2, 2015 at 9:42 PM
    Cryptoxx
    Craig
    Wow Thanks for all the reply.
