Finally finished LEDS - cupholders, console, and bed lights
Discussion in 'Lighting' started by Oregon TRD, Jan 27, 2012.
  1. Jan 30, 2012 at 8:57 AM
    Oregon TRD
    Oregon TRD [OP] "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    Heres all the stuff I used for this project for Cupholders and Center console.
    The WAGO clamps (best thing made EVER):These are $3 EACH on Oznium website. This guy on EBAY is badass sells 5 of em for $9.50
    http://www.ebay.com/itm/5-Wago-222-...242?pt=LH_DefaultDomain_0&hash=item20aefae732
    LED holders (a must buy):
    http://www.ebay.com/itm/390380286829?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
    LED'S:
    http://www.ebay.com/itm/390372095349?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    The LED'S I have in my center console I bought from Fred Meyer. They were $20 but I got them on sale for $4.99. You can get them at Vatozone also - These are the ones:
    http://www.autozone.com/autozone/ac...N-25pw?itemIdentifier=60064&_requestid=232879
    ^^^instead of these guys^^^ (they were only $5 so I grabbed them) you can use the LED's I used for my cupholders. Just drill 2 - 1/4" holes in each end of the inside of the center console and put 2 of the 5mm led's in.
    To do the LED in the rear cupholder, I drilled a 1/4" hole on the inside of the console all the way thru to the inside of the rear cupholders. Theres a few tricks (where to run the wires) - when you flip the whole console over, you will see a space between the rear cupholders and the center console box. I ran the rear cupholder led wires down thru there instead of back thru the hole going into the center console. I will put a white LED to fill that hole later.
    Hope all that doesn't sound confusing.
    By the way: all of the lighting under my dash and under two front seats I did a couple years ago....that setup is this:
    http://www.amazon.com/Multi-Color-C...4Z7Q/ref=sr_1_3?ie=UTF8&qid=1327942574&sr=8-3
  2. Jan 30, 2012 at 9:24 AM
    Oregon TRD
    Ross
    2005 Mall Krawler
    Another trick:
    If anyone buys the LED strips from Fred Meyer, autozone, etc.......cut the red button switch with battery off carefully AND KEEP IT!!! It makes a killer tester....
    example
    kydreamers likes this.
  3. Jan 30, 2012 at 9:46 AM
    txtrd
    txtrd Rookie
    Somewhere Down In TX
    07 TRD Off Road
    K&N drop in filter, nerf bars, alarm & remote start with 2-way paging
    Beware of the LEDs from 1michiganer on ebay. I put some in my truck and they only lasted maybe 2 months. Thankfully I bought a 10 pack so I just replaced them Friday night. 2 month life span for LEDs is unacceptable in my book.
  4. Jan 30, 2012 at 9:52 AM
    cverneau
    cverneau Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
    Thanks for the info and links. I just purchased ten of the orange led's and ten of the led holders from him for less than $11 shipped. The orange will most closely match the stock amber dash. I've been looking all over for led's that don't protrude from the surface very far but I wasn't having much luck and didn't want to use the flat surface mount ones. I plan on putting two of these on the surface of the overhang in front of the 12v outlets (2011) downward facing the cupholders and the recessed tray. I'm also gonna put one in the roof of the cubby right above my right knee. Who knows, maybe I'll use the others in the rear cupholders....
    Hey - a quick question:
    I'm assuming these led's are dimmable as I plan on tying them into my dash circuit (at the AC controls) to use with the dimmer switch. Are they in fact dimmable?? It's not a deal breker if they aren't, but it would be nice....
  5. Jan 30, 2012 at 11:23 AM
    Oregon TRD
    Ross
    2005 Mall Krawler
    Oh shiiittt!!!! Thanks for the info. Counting down the days....lol
  6. Jan 30, 2012 at 11:26 AM
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
    Awesome mod and job
  7. Jan 30, 2012 at 11:27 AM
    Oregon TRD
    Ross
    2005 Mall Krawler
    This weekend I will try to mount 2 of these in that cubby in front of gear shift but i didn't want to drill....I'll mess with that later.
    If you can see in the front cupholders, these things were incredible at how flush they (almost) are. I was wayy impressed.
    Dimmable? Not sure but I would bet yes! If they are wired into the dash dimmer then they should dim just fine. LED's take absolutley next to no power and can do about anything.
    If you get to the "cubby" led install be4 me let me know how it goes.
  8. Jan 30, 2012 at 12:03 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I did the same as you want to do, put LED's in the recesses of the 12v outlets [in the little half circles pointing down] the pita was dissassembiling the dash to get that piece out to drill the holes. I used the LED's from radioshack and wired them into the AC controls using the wiring diagram from the lighted 4wd switch mod. It worked out well, the light hits the bar between the cubby and the cupholders lighting the whole area, and yes they dim with the other dash lights
  9. Jan 30, 2012 at 12:12 PM
    cverneau
    Craig
    Cheshire, CT.
    I'm not gonna disassemble the dash to drill the holes. I'll put out the AC control (I also did the lighted 4x4 switch) and use a right angle drill from below. I should be able to see clearly and be able to see straight down in that location when the AC control is removed.
  10. Jan 30, 2012 at 12:26 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    I thought the same thing but theres a support rib that sticks straight up where you would want to drill holes so the lights are back far enuff to hit the cupholders, otherwise the lights will be shining into the cubby. And theres not much room thru the AC controls hole unless you have really small hands.lol
  11. Jan 30, 2012 at 12:28 PM
    Oregon TRD
    Ross
    2005 Mall Krawler
    I'm gonna take my time and look shit over this weekend before I do this. I don't want to drill into too much up there either.
  12. Jan 30, 2012 at 12:31 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    that sucks they charge for the LED holders. My first LED order from oznium they included them for free!
  13. Jan 30, 2012 at 1:01 PM
    Oregon TRD
    Ross
    2005 Mall Krawler
    Yeah..they are cheap ass fragile plastic.....should be free!!
  14. Jan 30, 2012 at 2:45 PM
    txtrd
    txtrd Rookie
    07 TRD Off Road
  15. Jan 30, 2012 at 3:14 PM
    #35
    Oregon TRD
    Ross
    2005 Mall Krawler
    #35
  16. Jan 30, 2012 at 4:00 PM
    #36
    bootboiler
    bootboiler Well-Known Member
    Scott
    Santa Cruz
    Camberg UCA's, locking tailgate, hid driving lights, B 5100's, OME HD Leafs, bud built plates, Relentless rear bumper, sliders with kick, breathers on pumpkins, satochi grill, bed lights, JVC 730BT Head Unit, Finch Four Wheel Camper FWC, 1Up bike rack, 265/75 16 tires
    Can't wait to see the Bed Light work up...
  17. Jan 30, 2012 at 4:15 PM
    #37
    Oregon TRD
    Ross
    2005 Mall Krawler
    Under my bedrails i'm going to use this:
    http://www.amazon.com/Filite-Flexib...ref=sr_1_1?s=hi&ie=UTF8&qid=1327968226&sr=1-1
    And wire it like I have my neons under my truck - with a remote control. This is the same kit I use for my under truck neons. I will wire the bedlights into this and just use the 2 remotes (one on keychain and 1 mounted inside the truck) to turn em on.
    http://www.ebay.com/itm/350528269871?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
    Heres my neon one mounted in my truck (other remote is on my keychain). Eliminates another toggle switch and it'll be nice to be able to turn my bedlights on from 50+ yards away...
    #37
  18. Jan 30, 2012 at 4:31 PM
    #38
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
  19. Jan 30, 2012 at 9:52 PM
    #39
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    RAPR
    That area you circled is exactly where my lites shine, and they don't mess with my eyes
  20. Jan 31, 2012 at 11:14 AM
    #40
    Oregon TRD
    Ross
    2005 Mall Krawler
    So after looking at the cubby last night....i'm going to put a hole right where the red is in this picture.....i'm gonna hook an LED up to my battery tester and see if I put one on each side that the one facing me as I drive doesnt shine in my face. If it does - I'm going to mount it a little higher above that red circle and put a "hood shroud" thing on the led holder that will put a "umbrella" type thingy over the led and just shoot the light straight down. SHITTY DRAWING...lol....but you can prob get the idea i'm thinking bout.
