First post, have a question regarding what technology I have in my Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 13TacomaLimited, Apr 27, 2013.
  1. Apr 27, 2013 at 11:38 AM
    13TacomaLimited
    13TacomaLimited [OP] Member
    2013 Limited Long Box
    Hey! Great forum, lot's of great information. I just have a quick question. I've done a lot of googling and can't seem to find a solid answer.
    I have a 2013 Limited Tacoma. I was under the impression that I had ATRAC, seeing as all 4runners, FJs, and Tundras come with it standard. But I read that it seems only the TRD Offroad package has ATRAC in the Tacoma? Is this true?
    I would be a little disappointed. I've had three 4runners (1st being a 3rd gen and two 4th gens) and two Tundras and thought the ATRAC was great!
    If I don't have ATRAC, what do I have? I'd be OK with a mechanical LSD, but I have a feeling I have Toyotas version of an LSD, the Auto LSD.
    Any info would be great, thanks very much.
  2. Apr 27, 2013 at 11:43 AM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    You have Auto-LSD, but you also have TRAC, which can be modded to work in 4lo similar to ATRAC. From what I hear it is not quite as aggressive as ATRAC, but is definitely better than open diffs
  3. Apr 27, 2013 at 11:54 AM
    13TacomaLimited
    Thanks for the response.
    So basically, I have open diffs in 4 lo?
  4. Apr 27, 2013 at 12:14 PM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    From what I understand, yes, but there is a mod to enable trac in 4lo
  5. Apr 27, 2013 at 1:33 PM
    Sparky73
    Sparky73 Well-Known Member
    Drew
    Washington
    13 DCLB 4x4
    Famous Fabrication Sliders, Duratracs, Painted Grill, BHLM, Devil's Horns Emblem, Derp'd Badges, Wet Okole Covers
  6. Apr 28, 2013 at 5:47 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    What I don't get about the whole system is that if you are stuck it takes more traction to get your vehicle to move than to keep it moving. Now one wheel spins so it applies the brake to that wheel to force the differential to put power to the other wheel and now the nonspinning wheel has to get more traction to move the vehicle and also pull a wheel with the brake on. Sounds like a gimic from the late 70's early 80's where if you were stuck with an open rear in a rear wheel drive car they told you to apply the parking brake to force the differential to put power to the nonspinning wheel. Never worked for me back then and I don't see how it could work that well now. Why didn't they just put a limited slip differential in it to start with. It would cost less and work a lot better
  7. Apr 28, 2013 at 7:03 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    LOL atrac and computerized braking distribution to an open diff is superior to a
    mechanical limited slip in ALL circumstances. Oh yes you may find a situation
    to refute these words, but really...you cannot beat it. technology wins
    it is just a tiny bit more sophisticated than your old-school parking brake trick,
    [where by the word 'tiny' I mean leap years more sophisticated]
  8. Apr 28, 2013 at 7:15 AM
    Hugh Morron
    Bill
    Never mind I will answer my own question. Traction control=death of limited slip differentials. Can't have both. LSD with traction control would cause the brakes to be applied to both rear wheels when wheelspin would occur causing brake wear and differential problems. It would also cause you to just come to a stop in low traction situations.
  9. Apr 28, 2013 at 7:36 AM
    Hugh Morron
    Bill
    127, I wasn't talking about atrac. was talking about traction control and auto lsd. Not here to start a fight either. Everyone is entitled to their own opinion. I won't comment any further.
  10. Apr 28, 2013 at 7:39 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Welcome aboard! Not sure of the changes because I haven't been looking in quiet some time; I'm thinking about it, so I'm subb'ed in to learn.
  11. Apr 28, 2013 at 7:45 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    I think the traction control of the ALSD applies brake force to wheels independently. IE if the drivers rear is slipping, but the passenger rear has traction, brake force will only be applied to the drivers rear.
    I remember a post that made a pretty good statement about how the ALSD was like a weak version of ATRAC system. Same basic concept, but not as powerful.
  12. Apr 28, 2013 at 8:20 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    reread my post
    note the part where I say 'computerized braking distribution' to an open diff'
    that is auto lsd.
    and , traction control is atrac and atrac is traction control
  13. Apr 30, 2013 at 7:24 AM
    13TacomaLimited
    Thanks for the help guys!
  14. Apr 30, 2013 at 7:29 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    sounds like more research was needed before purchase. yellow wire mod is definitely needed in the TRAC equipped models that are not offroads.
  15. Apr 30, 2013 at 9:17 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    So when my VSC / Traction control kicks in around corners , my Sport has ATRAC ?
