Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Sep 9, 2013 at 7:12 AM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    yea good point, i didn't remember any film on it, but i guess i was basically looking through 3 layers of tint/dyed glass
    here was the one i had
    http://www.tacomaworld.com/forum/florida/174106-f-s-topper-double-cab-short-bed-tampa-area.html
  2. Sep 9, 2013 at 7:36 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    The one I had on my F250, I removed the front glass from the shell. I could see out of it a heck of a lot better then. My advice would be to get the shell without the front glass and have them install a gasket that seals the shell to the back of the cab. Barring that, get one that has the fold down front glass so you can clean it and the back window of the truck easier.
    As was said, keeping the glass clean is critical if you're going to be able to see out of it. I know that sounds like a no-brainer, but you have to be extra diligent with the shell glass than you normally do with the truck glass. Or you could just get used to using your outside rearviews. It's really not a bad practice to use anyway.
  3. Sep 9, 2013 at 7:50 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    Oh my god :laugh:
    that's some quality efficiency right there.
  4. Sep 9, 2013 at 8:02 AM
    Taco No Baka
    Lee
    Tampa, FL
    I know, right? And I thought it was bad when it took my wheel spacers 3 days to get out of Oregon. :eek:
  5. Sep 9, 2013 at 8:03 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    I thought it seemed a little out of the way. But the guy who I think is the manager at my local store has really helped me out a lot. Hopefully Thursday, if not then it might be next Monday.
  6. Sep 9, 2013 at 8:04 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    There's a reason i've hand deelivered everything i've built for people that is too large to fit in a box.....
    i'm sure i'll have to fastenal one day to ship something, but i'm not looking forward to it.
  7. Sep 9, 2013 at 8:05 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    That'd be nice to have it for the weekend
  8. Sep 9, 2013 at 8:05 AM
    Toyota Tech31
    Debary, Florida
    Well at least my new LEDs will be here tomorrow for my fogs. Got a pair of the "6 led pods" from okledlightbars. Basically the Chinese version of the Dually 2's.
  9. Sep 9, 2013 at 8:11 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    :popcorn:
    i've been considering swapping out my stock fogs for some D2s (or equivelant) with the amber filters.
  10. Sep 9, 2013 at 8:19 AM
    Toyota Tech31
    Debary, Florida
    I am looking forward to playing with these tomorrow night when it gets dark. They should be pretty bright. And they are running a GB on them right now. Can't argue with a pair of them shipped to your door for $120.
  11. Sep 9, 2013 at 8:23 AM
    Taco No Baka
    Lee
    Tampa, FL
    Got a question: I've almost talked myself into getting a dome mount for my CB antenna and mounting it on the roof. I have a 2' firestik with a spring base and I like the clean look and the large ground plane bonus I'd get from the dome mount. However, I'm worried that even with the spring, dragging the antenna under low hanging limbs and what not on the trails will eventually cause the sheet metal around the mount to work harden and crack. Is this a valid concern or am I just over thinking it?
  12. Sep 9, 2013 at 8:41 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    put a sizeable backing plate on the inside of the roof and you should be good to go. with just the dome mount itsself, i think your concern is valid. most of those mounts are more typically used with a whip, or even spring based whip. the firestiks are just so solid and heavy in comparison.
  13. Sep 9, 2013 at 8:49 AM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Was really surprised and pleased that ATO ships with a normal company. Can't remember if it was FedEx or UPS but should only take a week.
  14. Sep 9, 2013 at 8:51 AM
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
    You could put it on your tool box
  15. Sep 9, 2013 at 8:55 AM
    Toyota Tech31
    Debary, Florida
    I am trying to be as patient as possible. But I hate waiting.
  16. Sep 9, 2013 at 9:02 AM
    Taco No Baka
    Lee
    Tampa, FL
    Yeah, but then I'd have to get a 4 or 5' antenna to get the same height and I'd lose the large ground plane bonus. Also, I'd have to run the coax outside the cab which is a bigger PITA than just dropping the head liner. I've gotten to be an expert with that after installing those cab lights twice, lol.
  17. Sep 9, 2013 at 9:12 AM
    Taco No Baka
    Lee
    Tampa, FL
    I was thinking of sticking a doubler under it. What do you think? A 6"x6" piece of .032 or .040 aluminum (T6 or so)? This dome mount was made by Firestik for Firestik antennas, but it still looks a little small for the thin Taco sheet metal.
    http://www.rightchannelradios.com/firestik-dome-mount-kit.html
  18. Sep 9, 2013 at 9:13 AM
    ckeene9
    Chesterfield, VA
    See Build Thread
    I hear ya, hoping mine shows up before I get to FL. Can only do it on the weekends when there's gonna be extra hands at home to help lift it into place.
  19. Sep 9, 2013 at 9:19 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
  20. Sep 9, 2013 at 9:22 AM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    ^^^^^^..After the headlights ,I would not have guessed that ^^^^^^Some time Ill tell you about the only time I used fastenal to ship a grill to Tenn.:mad:
