fog light mod question
Discussion in '1st Gen. Tacomas (1995-2004)' started by beach_yota03, Feb 9, 2012.
  1. Feb 9, 2012 at 5:40 AM
    beach_yota03
    beach_yota03 [OP] Well-Known Member
    jonny
    wilmington, north carolina
    03 taco sr5
    i am doing this mod and was wondering if there are different size sockets for the bulb because the one i have are smaller than the bulb itself so i have to drill the hole bigger to fit the bulb then try and get the socket to fit and stay tight in the hole i have drilled for the bulb to fit. any help or suggestions
  2. Feb 9, 2012 at 5:47 PM
    fshams
    fshams Well-Known Member
    Columbus, OH
    2012 Tacoma V6 4x4 TRD/TX PRO - DCSB
  3. Feb 9, 2012 at 8:56 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Not sure if you've seen it or not, OP, but I found Beau02's writeup very helpful and easy to follow.
    Links are broken, fshams, but I suspect you meant to link to these:
    http://www.tacomaworld.com/forum/1s...gnals-running-lights-switchback-leds-how.html
    and
    http://www.tacomaworld.com/forum/1st-gen-tacomas/150483-how-install-switchback-leds.html
  4. Feb 10, 2012 at 5:36 AM
    fshams
    Columbus, OH
    Yes.. It's the same one I use... Much much easier than having to drill holes and retrofit different bulb size. I recommend this process.
    I connected the extra power lead (new green wire in the pictures) to the positive lead on my side markers, so the only time the fog lights come on is when I turn the side marker lights on. One thing almost everyone noticed after this install was some voltage spike when you applied the brakes. The driver's side fog light would temporarily flash off and back on. In order to remedy this you would need to invest in LED brake light bulbs as well. This corrects the issue.
    This is the brake light part number you would need and you can order it from www.superbrightleds.com
    1157-R45-T: 45HP-LED BAY15D Tower Bulb, Color: RED | $ 24.95 each|
