Fog Lights anytime I want
Discussion in 'Technical Chat' started by MikeS., Jun 26, 2008.
  1. Jun 26, 2008 at 1:01 AM
    MikeS.
    MikeS. [OP] Well-Known Member
    Far Eastern WVa
    2008 DC LB 4x4 in Speedway Blue.
    Undercover bed topper, Nerf style step bars, Python alarm, Ham radio with 250 watt amp and chrome wheel well bling.
    I too don't like Toyota limiting me when I can run my fog lights. So I found the thread on ToyotaNation that shows just how easy it is to modify the relay. I now can run my fog lights anytime I have the ignition on.
    Here is the thread, it is many pages and offers several variables on how to do this.
    http://www.toyotanation.com/forum/showthread.php?t=79485&page=1
    Here is how I did mine. The fuse is a 3 amp fuse. I was going to go with 5 but didn't have a spare. I'm going to get one later today. Also I'm probably going to switch to this method. My pic to come later, stupid work filters...
    http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=071-580
  2. Jun 26, 2008 at 10:31 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
  3. Jun 26, 2008 at 10:33 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Oh, and for the record the method you posted apparently turns the fogs on for a few minutes after you turn the engine off. In 2 years mine have never done that with the way I did it.
  4. Jun 26, 2008 at 4:08 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    mine either.....plus your way took me like 2 minutes to do the mod!!!
  5. Jun 26, 2008 at 7:14 PM
    MikeS.
    Far Eastern WVa
    Yep, I've already had a neighbor call and tell me my fog lights were on.
    I'll take another look at your mod.
    Thanks
  6. Jun 26, 2008 at 7:16 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hey man, its really easy, and the lights, as far as i have seen, never come on,on their own. great mod indeed.
  7. Jun 26, 2008 at 7:23 PM
    lakewoodbilly
    lakewoodbilly Well-Known Member
    Bill
    Lakewood, CO
    White 08 DC V6 SR5 4WD TRD Sport
    Factory DRL's, Underhood Flood LED's, Underbody Multi-color LEDS, Red Line Tuning Elite Hood Struts, Anytime Fog Lights, PIAA 4100 Intense White, Luminics JDM Yellow H10 Fog Lights, OBX Sport Pedals, Sill Protectors, Bed Net, Front Bed Tie Downs, iPod and Aux Factory HU Interface, Sirius Sportster 5, Satellite Antenna through third brake light
    Hey guys - what is the best type of quick connect to use to splice into the green wire? Or did you cut and re-splice?
  8. Jun 26, 2008 at 7:25 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i used one of the blue quick connects....the type you put the wire thru the back side, close it, then slide the connecting wire thru the side, then use a pair of pliers to push the metal piece down thru both wires. i call them alligator clips, or quick splices.
  9. Jun 26, 2008 at 7:28 PM
    piercedtiger
    Jon
    Southern Tier, NY
    This is what I use. Just get a pack of them where ever's cheap. lol I'm starting to put liquid electrical tape around them now to seal out moisture since the road salt corrodes wires real bad here in NY.
  10. Jun 26, 2008 at 7:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    same thing i use there.
  11. Jun 26, 2008 at 7:32 PM
    lakewoodbilly
    Bill
    Lakewood, CO
    Do these wrap around the wire you are tapping into or do you need to cut that wire? Sorry to keep asking :confused:
  12. Jun 26, 2008 at 7:38 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the wire you are splicing into goes into the open channel in the back, then you use a piece of wire thru the side of the connector, then clamp down on the metal piece. then you are done.
