FOG LIGHTS ANYTIME THE SIMPLEST WAY
Discussion in 'Lighting' started by o0oSHADOWo0o, May 31, 2014.
  1. May 7, 2015 at 11:43 AM
    #101
    FABRICK8
    FABRICK8 Active Member
    Rick
    UTAH
    14 Pyrite DCLB Sport
  2. May 11, 2015 at 5:51 AM
    #102
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    15 TRD Sport (DCLB-BRM) - 88 ///M3 (Zinnoberrot)
    OME 887/Dakars/NV305s/33" Duratracs/+
    UPDATE:
    Swapping wires worked on a 2015 Taco....BUT.....
    I swapped the wires around (and to be honest, getting them out was not that hard once you study the back of the pins and see the tab that needs to be pushed down to release the wires) and got the fog lights to work on their own with DRL, with parking lights and with headlights or with nothing but the fogs. However, once I turned the truck on, a CEL and TARC OFF light came on. Using the ScanGaugeII I read the code, P0144 (02 Sensor Circuit High Voltage (Bank I Sensor 3)). I cleared the code, the CEL and TRAC OFF light go away, only to have it come back on 5-6 seconds later.
    I swapped them back to clear the CEL and keep things stock for now, but I want to get to the bottom of things and see what I can do to run fogs independently.
    Question I have is, why did this pop a fuel/air metering code? Is one of the wires from some emissions control like the secondary filter or an EGR valve? Any suggestions and or recommendations would be greatly appreciated.
  3. May 11, 2015 at 7:00 AM
    #103
    Weis1
    Weis1 Go Ducks!
    Phoenix AZ
    2019 DCLB TRD Sport Cav Blue
    Instead of swapping the wires, couldn't you just tap into the blue and white and jumper over to the red? Will that work?
  4. May 11, 2015 at 9:20 AM
    #104
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    I am hoping some one like o0oSHADOWo0o can respond and see what he has to say
  5. May 11, 2015 at 9:21 AM
    #105
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    I have a hard time following you bud.
  6. May 11, 2015 at 2:52 PM
    #106
    Weis1
    Weis1 Go Ducks!
    Phoenix AZ
    I was going to try this on my 2015. This picture was posted earlier on this thread.
  7. May 16, 2015 at 5:02 AM
    #107
    tony jewell
    tony jewell Well-Known Member
    Tony
    The 1st State
    2015 TRD Off-Road Double Cab
    Additions: Bright Ass Led Fog & Headlights, LED Switchbacks, 20% Tint on Front Windows, Led's Inside & Out, Toyota OEM Bed Mat, ImMrYo Mirror Bracket, Gentex Mirror W/Compass & Temp, Husky Front & Rear Floor Mats, Navigation Entune Radio Upgrade, Salex Glove Box Organizer, Antennax Shorty 15" Antenna, Pop & Lock PL8521 Tailgate Lock, Bar Caddy and Grid-It Center Console Organizers, MattGecko Waterproof Under Bed LED Lighting Kit, Anti Dark LED Hood Lights, Flipkey, Cool Start Remote Starter, Access Lorado Tonneau Cover... MODS: Fogs on Any Time, Dome & Map Lights on at same time, Dipped All Badges, Turned off Seat Belt Chime..... In The Future: Blistiens 5100's, OME Coils, Tire & Wheels.....
    I also have a 2015 and would like to do this mod. Thanks in advanced
  8. May 20, 2015 at 8:12 AM
    #108
    tony jewell
    Tony
    The 1st State
    Did you try this MOD? Did it work? I want to do this MOD to my truck also
  9. May 20, 2015 at 8:48 AM
    #109
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    tony jewell likes this.
  10. May 20, 2015 at 9:37 AM
    #110
    tony jewell
    Tony
    The 1st State
  11. May 22, 2015 at 1:29 PM
    #111
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
    Just a quick question from a someone who knows just enough to be pain in the ass but not enough to be helpful. When you look at this picture the fog relay has four wires: a +12v to the coil, wire from the coil that goes to ground when fog light switch is turned on, and then the larger +12 v from source, and when the coil is powered 12v to the load. Which of the two coil wires comes from the +12v? When testing with multimeter it shows 12v on both sides of the coil because it registers 12 volts going into the coil and 12 volts coming out of the coil. In the picture you mention the red wire with black stripe and the blue wire with the white stripe. The red with black stripe wire is on the right side which I assume is the +12v. The blue with white stripe is on the left which seems like it would be the +12v coming off the coil. If you are tapping into the airpump relay to supply +12v the the fog relay, shouldn't you use the wire to the right side of the airpump relay. It probably makes no difference. You're getting +12v no matter which side.
  12. May 30, 2015 at 7:46 PM
    #112
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    loving the look:
  13. May 31, 2015 at 1:27 AM
    #113
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Still haven't quite figured this out
  14. Jun 19, 2015 at 7:52 AM
    #114
    Jon147
    Jon147 Well-Known Member
    Jon
    Orange County
    '13 TRD Sport-Vader
    Bilstein 5100 RHA/OME 887s/LR UCA's, 5100's in rear w/ Wheelers 3 leaf progressives, wrinkle black/silver TRD front skid plate, emblem removal, LED third brake light, remove/replace TRD Sport stickers with custom black TRD stickers, tail gate lock mod, BLHM & BLTM, VLED 430lm DTRLs, VLED LED rear turn signals, LED headlights from BadAssLED's, black mesh grill, AVEC LED light bar behind grill, AVEC LED light bar lower valance, 91' Cadillac Deville Horns, Hood Scoop LED from C4 Fabrication, Procomp 5001's Satin Black, FlowMaster Dual Exhaust American Thunder, Blue Sea Aux Fuse panel, AVEC 12" ultra slim light bar in bed, Undercover Flex bed cover
    I have a '13 DCLB with this setup. If I followed the directions correctly (I pulled the Red w/Black stripe wire and capped it, then T-Tapped the Blue w/ White stripe and ran the wire to where the Red w/ Black stripe wire is), I am wondering why my fogs produce 2 oddities, at least me for my knowledge:
    1. the fogs delay shut off when I shut the truck off
    2. the fogs have come on at random while the truck is off and then shut off some time later. Most recently this morning they were on apparently for 45 mins.
    Any insight would help?
  15. Jun 19, 2015 at 9:25 AM
    #115
    evansb2
    evansb2 Well-Known Member
    Evans
    LA, CA
  16. Jun 19, 2015 at 12:13 PM
    #116
    Jon147
    Jon
    Orange County
    '13 TRD Sport-Vader
    ^^^This fixed my problem. Was tapped into the EFI. Just ran an Add-a-Circuit from the A/C fuse to the under side of the smaller relay box housing the fog relay and added a terminal so I could plug straight into the relay. Thanks evansb2.
    evansb2 likes this.
  17. Jun 19, 2015 at 4:43 PM
    #117
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    Special shout out to BlackErryThing for the walk through and help it was really appreciated got it modded out and can turn them on whenever I want now love the look thanks for taking time to walk me through this and helping a confused guy out
    BlackErryThing likes this.
  18. Oct 2, 2015 at 6:24 PM
    #118
    rjjencke
    rjjencke Well-Known Member
    Robbie
    Arizona
    '15 MGM DCSB OR 4x4 JBL
    Wait! So the blue/white wire is for the EFI?
    I just did this mod on my '15. My fogs shut off about 10 seconds after killing the ignition.
    Am I gonna have problems?
  19. Oct 2, 2015 at 10:29 PM
    #119
    Jon147
    Jon
    Orange County
    '13 TRD Sport-Vader
    Well, for me, my fogs would delay shutting off, and at times would kick on while I was inside or parked at the store something. I forget why it does that but it can happen when tied into the EFI. If someone remembers why feel free to chime in.
  20. Oct 3, 2015 at 12:26 PM
    #120
    hcm
    hcm Well-Known Member
    2007 AC 4x4 TRD Offroad
    This is the fuse box in the engine right? I disconnected all the nuts but there are so many wires going into it, I can't flip it over. Please help
