Fog lights don't work
Discussion in 'Technical Chat' started by Bobcat, Sep 14, 2009.
  1. Sep 14, 2009 at 3:55 PM
    Bobcat
    Bobcat [OP] Well-Known Member
    Montana
    Bulbs & fuse are good, what would be the cause. Bad relay? Please help.
  2. Sep 15, 2009 at 6:34 AM
    Warren Thompson
    Warren Thompson GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    I had this problem. Pissed me off. They only work when the headlights are on low beam. I know, dumb, but that is how they are wired I guess. Sucks. I know of a mod to wire them on with the high beams, but none with them wired to be on without the headlights on low beam.
  3. Sep 15, 2009 at 6:39 AM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    That's just BS. I can run my fogs whenever I want. The mod is good for any setting. This is with parking lights only.
    [​IMG] [​IMG]
  4. Sep 15, 2009 at 9:28 AM
    Bobcat
    Montana
    Ok so maybe I don't have a problem. I just need to see if they come on when my low beams are on, right? If they work I will look into the fog lights on whenever I want mod.
  5. Sep 15, 2009 at 9:34 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
  6. Sep 17, 2009 at 5:23 AM
    Warren Thompson
    Warren
    Elko, Nevada
    I want to do this mod. My question is this... The relay terminal is bent at a right angle and connected to the wire, so this terminal is unnecessary in the operation of the lights??
    Thanks for any help you can give.
  7. Sep 17, 2009 at 5:30 AM
    tanktodd
    tanktodd Well-Known Member
    Todd
    back on the right side of the bay, Ala
    08 Prerunner w/TRD Sport Pkg
    Limo tint in back w/ 20% on doors. Removed all badges. Stereo headunit, all new door speakers, 2 amps, and 10' sub...so far Black bullbar MotoMetals and 285/70/17 Duratracs. 3" OME springs in front and aal in back with tsb springs Black UWS tool box 5100's all around Plasti-dipped evo front end Fog light anytime mod OEM steps (for sale) HID fogs 55w 3000k HID heads 35 w 6000k "Cool white" dome & map lights
    I tried to do the fog light mod and did it just like it said and my fog lights wouldn't work at all...(lights on or off) so i had to put it back to normal and they worked fine. Any thoughts on that?
  8. Sep 17, 2009 at 7:31 AM
    Slygrin
    Slygrin Well-Known Member
    Moses Lake, WA
    2010 Access cab V6 SR5 Timberland Mica
    De-badged, Foglights on anytime, Tailgate hose clamps, GPS semi-permanent mount, WeatherTech mats, Front mounted hitch, Blacked out front emblem, Color matched grille, Running boards, Bed mat, UWS low profile toolbox, Scanguage II, Prestige Alarm w/remote start, Snowsport snow plow
    When I did the mod the other day I used a quick splice on the green wire. It worked for a bit then the fog lights would not come on at all. I found the splice had cut the wire and it had an intermittent connection, I could wiggle the green wire and the lights would come on. I removed the splice and soldered the connection and all is well now.
  9. Sep 19, 2009 at 3:20 PM
    Warren Thompson
    Warren
    Elko, Nevada
    I did the mod today. Easy, quick and it all works. Yahoooo!!!
